RV8-List: Settting the correct Spacing (Gap) between VS Top
bifft(at)xmission.com
PostPosted: Sat May 10, 2008 8:00 am    Post subject: RV8-List: Settting the correct Spacing (Gap) between VS Top Reply with quote
On Fri, 9 May 2008, Garey Wittich wrote:
Greetings:
The construction of my RV8A (RV7 and RV9 are the
same) the Rudders Top Rib swings OVER the top Rib of
the VS. There is suppose to be a "Gap" between the
two Ribs so that there is no interference (rubbing of
them together) as the Rudder is moved.
My question is - how do you set this Gap up ???
On mine, I had to file the top of the VS down a bit to get the needed
gap. Given the pre-punched holes, there isn't a lot you can play with,
other than changing how far the rod ends are screwed in, move the top ones
a bit further out than the bottom (keeping them in line of course).
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 riviting fuse.
1/4 Starduster II N23UT flying
