Avionics-List Digest: 3 Msgs - 05/12/08
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
hdwysong(at)gmail.com
PostPosted: Tue May 13, 2008 9:55 am    Post subject: Avionics-List Digest: 3 Msgs - 05/12/08 Reply with quote
I have a Horizon Instruments, Inc. P-1000 Digital Engine Tachometer. It has a
6-pin connector labeled "Amphenol 14S-6PF". Does anyone have a source to buy
a matching connector to build its hardness?
Hello Robin,
Try www.mouser.com and search for "amphenol 14S-6". They will point
you to their catalog and Amphenol datasheets that will assist you in
finding a mating connector.
D
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
douglist(at)macnauchtan.c
PostPosted: Tue May 13, 2008 10:59 am    Post subject: Avionics-List Digest: 3 Msgs - 05/12/08 Reply with quote
Hello Robin, #!
I have in my hands an MS3106A - 14S -6S, A relic of World War II, in my hands. Pins are letters A through F with pin A aligned with the alignment slot.
Where are you. Anywhere near Colorado Springs?
Digikey lists a mate to your connector but they have a $25 minimum charge. I donno about Mouser. You'll need a cable clamp to go with it.
Hit me off line at dmcnutt(at) (the from line) Colorado Springs, CO, US of A.
--> From the U S of A, the only socialist country that refuses to admit it. <--
retasker(at)optonline.net
PostPosted: Tue May 13, 2008 11:35 am    Post subject: Avionics-List Digest: 3 Msgs - 05/12/08 Reply with quote
Digikey doesn't actually have a $25 minimum. What they have is a $5
extra handling charge if your order is less than $25.
Mouser has no minimum charge or handling charge - but their prices are
typically a little higher.
Dick Tasker
> Hello Robin, #!
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
