		johngoodman
				 Posted: Mon May 12, 2008 7:55 am    Post subject: Brake line question |
				I'm going to install some of the brake lines up to where they leave the tunnel and I'm trying to pull the F 1067A Seat Floor for better access. I can get it to slide aft about 1/16th of an inch and that's about it. Has anybody run into this?
 John
  _________________ #40572 Phase One complete in 2011 |
		rv10(at)sinkrate.com Guest
				 Posted: Mon May 12, 2008 9:40 am    Post subject: Brake line question |
				John,
 I had a similar issue when I fit mine originally.  It is due to the F-1067A
 being too wide (just barely) to actually fit between the tunnel and the
 F-1016 side panels.  I was able to work mine out with a minimum of force and
 not too much primer removal.
 To make re-installation easier I use the scotch bright wheel and cleaned off
 a bit of the F-1067A's on the inside edge on the back corner.  I also
 slightly (just a hair maybe a millimeter or so ) increased the size of the
 joggle out the outside rear corner of the F-1067A's to help it clear the
 F-1016 side panels.
 My plane, if it ever flies, will probably fly crooked now
 -Ben
 #40579
		johngoodman
				 Posted: Mon May 12, 2008 4:16 pm    Post subject: Re: Brake line question |
				Thanks, I got it. The problem was the nutplates get blocked by the main spar and prevent sliding the piece fore and aft. You have to flex it to get it out.
 John
