tbonsell(at)luxuria.com Guest
Posted: Wed May 14, 2008 5:40 am Post subject: Damper? |
Hi guys, I have a stupid question.
Back in the day, I used to ride motorcycles. Anyway, on a
particularily nasty kawi triple, it had a steering damper to minimize
the terrifying speed wobble that would try and kill you from time to
time. It looked like a tiny shock absorber.
How come they don't use these to damp out flutter in control surfaces?
ashontz
Posted: Wed May 14, 2008 5:55 am Post subject: Re: Damper? |
I actually thought about this too. Good point. I know I've seen them on the nose wheels of Cessnas. I've had a nosewheel shimmy and shake while going down the runway (like a shopping cart wheel) and it REALLY shook the plane hard too. I turned around and took it back to the shop. The owner/rentee fixed it on the spot, was a bad damper or connection or something.
| tbonsell(at)luxuria.com wrote: | Hi guys, I have a stupid question.
How come they don't use these to damp out flutter in control surfaces? |
Al Hays
Posted: Wed May 14, 2008 6:40 am Post subject: Damper? |
Tony,
I remember being invited to test ride one of those in while
stationed in Japan when they were new on the market. My first and
only unintentional wheelie from the wicked power curve.
That must not be such a stupid question since I thought of the same
thing myself. I didn't give it much consideration after remembering
a few occasions of frozen (seized up) shock absorbers
on land vehicles. Those devices are used as well for sway dampening
for trailer hitches and shimmy control. The consequences of having
one stick or freeze up in flight would be more dire than on a ground
vehicle. However, I have not researched and don't know if they have
in fact been used on control services.
Al Hays
N5892H reserved
On May 14, 2008, at 9:37 AM, Tony Bonsell wrote:
minimize the terrifying speed wobble that would try and kill you
from time to time. It looked like a tiny shock absorber.
ashontz
Posted: Wed May 14, 2008 7:01 am Post subject: Re: Damper? |
How about a damper made of two pieces of nylon that clamp down on an aluminum plate with springs under the bolt heads? That would be light and would never freeze up or lose oil. It would just provide some consistant stiffness to the actuator in both directions.
I could see an arrangment like this working well with the push-tube style aileron control. Use the existing horn that's mounted on #7 rib inside the wing, and with the unused side of the horn (being that there's no cable there) attach the damper to gently clamp down on the unused portion of horn. Very little adjustments to be made for the installation, there's already an access hole for getting to the linkage.
Plus that rib is already beefed up to handle the cable actuator and horn.
You'd probably need to make a different style horn that has a longer arm on it to go back into the damper.
| Al Hays wrote: | Tony,
Al Hays
N5892H reserved
Gig Giacona
Posted: Wed May 14, 2008 7:49 am Post subject: Re: Damper? |
I am curious. How is that any better than a cable running all the way to the horn in the other wing that applies and releases pressure as needed?
| ashontz wrote: | How about a damper made of two pieces of nylon that clamp down on an aluminum plate with springs under the bolt heads? That would be light and would never freeze up or lose oil. It would just provide some consistant stiffness to the actuator in both directions.
601XL Under Construction
ashontz
Posted: Wed May 14, 2008 7:56 am Post subject: Re: Damper? |
I'm talking about a damper on each aileron horn, particularly in the push-tube setup.
In the cable setup, the cable running to the other aileron doesn't provide any damping, it's just a hookup to the other side. There may be some friction there, but not like a damper would provide. What I'm talking about is a friction plate as a damper which would help resist out of control high frequency movement of the ailerons (flutter). The skin aileron hinge may be inadvertantly acting as a damper in that it's a stiffer joint to move.
| Gig Giacona wrote: | I am curious. How is that any better than a cable running all the way to the horn in the other wing that applies and releases pressure as needed?
Al Hays
Posted: Wed May 14, 2008 8:32 am Post subject: Damper? |
Do not archive.
Several aspects of that to consider.
1. It would make more resistance and therefore more force to be
carried by the cables and probably more frequent adjustment due to wear.
2. As I recall, shock absorbers usually give more resistance to
movement in one direction than the other. Push down with all your
weight on the front end of the Buick with worn out shocks and it will
bob up and down for awhile. Replace the shocks and you still push it
down easily but it will not bounce. The harder you try to push that
air and fluid through the orifice inside the shock the more
resistance it seem to have. Conversely, the harder you push
something on a nylon bearing surface, the less effect it will have on
controlling that movement.
3. The resistance, or dampening, provided by spring loading friction
would make the control feel heavier but probably be overcome easily
by a flutter condition.
4. Sounds like a handy way to keep linkage snug on a lawn tractor but
not up to the demands of flight controls.
Please don't take offense. Better to bounce these ideas around
before implementing them and being the test pilot.
On May 14, 2008, at 11:01 AM, ashontz wrote:
Al Hays wrote:
> Tony,
> Al Hays
> N5892H reserved
>> surfaces?
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.com/viewtopic.php?p=183123#183123
ashontz
Posted: Wed May 14, 2008 8:37 am Post subject: Re: Damper? |
Has no one noticed I said, push-tube?
| Al Hays wrote: | Do not archive.
Al Hays wrote:
> Tony,
> Al Hays
> N5892H reserved
>> surfaces?
Andy Shontz
CH601XL - Corvair
Gig Giacona
Posted: Wed May 14, 2008 10:34 am Post subject: Re: Damper? |
Yes and you probably need it even less with a push tube than cables.
| ashontz wrote: | Has no one noticed I said, push-tube?
ashontz
Posted: Wed May 14, 2008 10:36 am Post subject: Re: Damper? |
Maybe so, I was just responding to ways a damper could be implemented.
| Gig Giacona wrote: | Yes and you probably need it even less with a push tube than cables.
Ron Lendon
Posted: Wed May 14, 2008 4:54 pm Post subject: Re: Damper? |
Andy,
Are you using an alias? Are you a US Certificated Pilot? Do you have and engineering degree or are you a student like the rest of us?
The reason I ask these questions is I like to know who I'm listening to. You have been a very active participant in many of the discussions and you appear to be redesigning your airplane. If I am to consider your proposals I would really like to know more about you.
What say you?
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Posted: Wed May 14, 2008 5:08 pm Post subject: Damper? |
Listed in the FAA registry ?
Take a look. Amazing results...
Posted: Wed May 14, 2008 5:29 pm Post subject: Damper? |
Ron,
I'd recommend you stay the course and not change anything shown by the
drawings. The changes that have been proposed are all contentious without
approval from Zenith. The vast majority of the 601s flying today will
be flying years from now if they were built to the drawings. Trust the
designer, not
the instinct to arbitrarily strengthen or complicate things suggested by
others. You don't have a reason to become a test pilot for anyone!
Larry McFarland
601HDS at www.macsmachine.com
Ron Lendon wrote:
Andy,
What say you?
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder
