gcarnforth
Posted: Fri May 16, 2008 9:54 am Post subject: Dynon , sl40, pm1000II, and GTX327 Pinout numbers |
Hello!
I have been motoring along on my RV7 and have always been able to find answers in the archives.
I am having troubles firing up my panel and am in the process of going back through the harness.
Does anyone have the pin numbers for connecting these units?
Flightdek to GTX327
SL40 to PM1000II
I have the diagrams but anyone with the pin numbers would help verify what I have done right/wrong
G carnforth RV7 louisville KY
_________________ G. Carnforth
Louisville, KY
RV7 |
longg(at)pjm.com Guest
Posted: Fri May 16, 2008 11:36 am Post subject: Dynon , sl40, pm1000II, and GTX327 Pinout numbers |
G.
Not to confuse you, but I have them for the Dynon, sl30 and GTX330. Not
exact, but close family.
If you get stuck, they may help. They are hard copy so I'll need to scan
them in (Monday).
I'll bet the sl40 is the same as the sl30 w/o the nav junk. Don't know
about the 330 since it has different options than the 327.
rshannon
Posted: Fri May 16, 2008 6:04 pm Post subject: Dynon , sl40, pm1000II, and GTX327 Pinout numbers |
On Fri, May 16, 2008 at 10:54 AM, gcarnforth <greg(at)chesterpools.com (greg(at)chesterpools.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "gcarnforth" <greg(at)chesterpools.com (greg(at)chesterpools.com)>
Flightdek to GTX327
SL40 to PM1000II
SL-40 pin outs are:
1 DC power
2 (reserved)
3 RS232 serial data out (TxD)
4 TxKey,pulled low to transmit
5 (no contact -- do not connect)
6 speaker
7 mic ground
8 Mic 1 input
9 DC power ground
10 RS232 serial data in (RxD)
11 RS232 signal ground
12 Intercom select, pulled low to turn on intercom
13 Audio ground (speaker & headphone)
14 Headphone terminal out
15 Mic 1 input
