a.s.elliott(at)cox.net Guest
Posted: Thu May 15, 2008 6:20 am Post subject: Avoiding strobe noise? |
I am building a 601XL (all aluminum), and have located the COMM antenna on the bottom of the fuselage between the seats. (It's a taildragger, so this is behind the gear.) I have the primary battery under the right seat and am holding off locating the second battery until I see how the W&B turns out.
It has turned out to be convenient, wiring-wise, to locate the strobe power supply, an XPAK-604X-HR, under the left seat. In this location, the coax to the COMM antenna and at least one of the wires to the strobe heads will end up in close proximity.
My question is: Assuming the coax is properly terminated and the strobe cables' shields are properly grounded at one end, is there going to be a problem with strobe noise interfering with communications? (The strobe cables have a foil shield with a drain wire. The drain wire is grounded to the wing structure at the tip.)
If a problem is likely, are there any additional precautions I could take to avoid one?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD, Corvair, building...
nuckolls.bob(at)cox.net Guest
Posted: Thu May 15, 2008 11:40 am Post subject: Avoiding strobe noise? |
At 07:16 AM 5/15/2008 -0700, you wrote:
| Quote: | I am building a 601XL (all aluminum), and have located the COMM antenna on
turns out.
to avoid one?
Every time someone reports a "noise problem cured
by repositioning wiring" it was a demonstration of
some OTHER root cause.
When products are qualified to be used on airplanes,
they are qualified to both control emissions and
withstand certain stresses that are known to exist
in the aircraft environment.
The wiring you've cited are not particularly
communicative with respect to noise . . . assuming
that the installation of said wires is in accordance
with manufacturer's instructions.
In the heavy iron birds, we are seldom blessed with
enough room to run all the wires that are necessary
for operation much less comb them into potentially
antagonistic and/or victim systems.
The short answer is run them neatly together and
you'll be fine.
( -Thomas Paine 1776- )
hammer408(at)comcast.net Guest
Posted: Fri May 16, 2008 1:37 pm Post subject: Avoiding strobe noise? |
So Bob:
as long as all wires are installed and grounded per maunfacture's spec,
running (stringing) wires like Strobe Power Supply, Nav/Com, Transponder,
Flaps, Pitot Heat together along the bottom of a fuselage and thru bulkheads
together are OK ?
Hank
Posted: Fri May 16, 2008 6:31 pm Post subject: Avoiding strobe noise? |
At 05:40 PM 5/16/2008 -0700, you wrote:
<hammer408(at)comcast.net>
So Bob:
together are OK ?
yup . . /
Posted: Sun May 18, 2008 6:49 am Post subject: Avoiding strobe noise? |
Thanks.....
