mcjon77
Posted: Sat May 17, 2008 2:50 pm Post subject: Seat height and width for new Lightning interior |
Hi everyone,
I'm new here and will be purchasing and building a homebuilt aircraft this fall. I read on this forum that there were previously concerns regarding seat height and width for tall/wide pilots. I have heard that the new interior provides much more room, but haven't found any specific numbers yet. Does anyone know the seat height (height from the seat cushion to the canopy) and seat width of the new interior?
I have a sitting height of 38 inches and I would like to know If I will fit. I'll be at Oshkosh to check it out personally, but it would be nice to have the numbers beforehand.
Thanks in advance,
Jon
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
pennington(at)gainusa.com Guest
Posted: Sun May 18, 2008 6:09 am Post subject: Seat height and width for new Lightning interior |
Good morning
It is my understanding that you must cut the seat base and drop it to the
floor of the fuselage, then re-glass it for the lowered position to gain
more clearance for tall pilots. I am 6'3" tall and I too had problems with
head clearance in the standard Lightning. This procedure sounds like a
workable solution.
Gary
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Sun May 18, 2008 7:19 pm Post subject: Seat height and width for new Lightning interior |
I am 6'-2", but have a torso/sitting height of 39.5". I fit with just enough clearance for my headset. I lowered my seat by cutting out the seat support and center console where is rests on the spar box enought so it sits flat. I think I have pics on my build log site. Go to www.jimslightning.com and then go to the build log. It is hosted oin mykitlog.com
Jim!
On 5/18/08, Gary & Laura Pennington <pennington(at)gainusa.com (pennington(at)gainusa.com)> wrote: [quote]--> Lightning-List message posted by: "Gary & Laura Pennington" <pennington(at)gainusa.com (pennington(at)gainusa.com)>
Good morning
It is my understanding that you must cut the seat base and drop it to the floor of the fuselage, then re-glass it for the lowered position to gain more clearance for tall pilots. I am 6'3" tall and I too had problems with head clearance in the standard Lightning. This procedure sounds like a workable solution.
Gary
mcjon77
jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Thu May 22, 2008 10:14 am Post subject: Re: Seat height and width for new Lightning interior |
I have also been trying to drop the seat pan to gain head room, but am running into the spar box torsional support tube. I could probably gain an extra inch or more if the seat pan weren't blocked by the tube. I'm wondering if the tube represents the limit to seat lowering or whether there is some clever work around.
I am only 5'10" tall, but with a 30" inseam, I have a freakishly long torso and a sitting height of 39.5"; about the same as Jim. With 2" of Conforfoam as a cushion, compressing to perhaps an inch, and the seat pan dropped as much as the tube will allow, I just fit with a headset on. If I can't find another inch, I will probably switch to an in the ear headset.
John Eynon
Lightning kit #53
mcjon77
tlhuffy(at)aol.com Guest
Posted: Thu May 22, 2008 6:04 pm Post subject: Seat height and width for new Lightning interior |
I widened the center arm rest to make more room in the seat. You can drop the seat by cutting out the bottom past the support and drop it to the floor , you can gain almost 3". Make sure you drill all the holes you can in the flute tube. You have to angle the forwarded holes to let the pin slip into the tube this will give you more leg room and head room.
jstewart(at)inebraska.com Guest
jeynon2
Posted: Fri May 23, 2008 7:50 am Post subject: Re: Seat height and width for new Lightning interior |
For some reason I'd rather think of myself as a short guy with a long torso than a tall guy with stubby legs.
John Eynon
Lightning kit #53
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
