dlm46007(at)cox.net Guest
Posted: Sun May 18, 2008 11:04 am Post subject: wheel pant and tire clearance |
what clearance have builders left between the wheel pant and tire? mains? nose? Is one inch adequate or too much?
coop85(at)cableone.net Guest
Posted: Sun May 18, 2008 1:00 pm Post subject: wheel pant and tire clearance |
David,
1” sounds pretty good to me. I probably have a little less in mine, I basically created a gap I could slide my fingers into comfortably. I started off with the gap a little too small on the aft side of the wheel and it didn’t work out so well. While a tight gap would be nice, having a buffer for the wheel distorting will be a much better thing in the long run.
I highly recommend you measure the gaps with weight on wheels to make sure it’s valid.
Marcus
Do not archvie
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Sunday, May 18, 2008 2:00 PM
Subject: wheel pant and tire clearance
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
