WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sun May 18, 2008 10:09 pm Post subject: Information on EA-81 |
My wife and I are searching for a plane and we keep coming across planes with EA-81s and I can't find much about them. I like the 4 stroke reliability and the price is WORLDS better then a Rotax 912. How does it compare as far as reliability, overhaul cost, life expectancy? Any information or first hand experience would be greatly appreciated.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
dave
Posted: Mon May 19, 2008 2:45 am Post subject: Re: Information on EA-81 |
| Quote: | | I like the 4 stroke reliability and the price is WORLDS better then a Rotax 912 |
Rotax 912 very dependable and better power to weight than a EA-81.
You can buy a Kitfox IV with 912 for under 25k usually used. Good bargain in my opinion. If you want a 2 stroke same plane with a 582 will be 15 to 20k . My 582 has over 450 hours now since this last engine in June 06 and never been apart yet. So that give credit to the reliability of the 582 once again.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
WurlyBird
Posted: Mon May 19, 2008 10:01 am Post subject: oops |
oops, double post
WurlyBird
Posted: Mon May 19, 2008 10:03 am Post subject: Re: Information on EA-81 |
So that brings up another question I have about two strokes. My initial reason for wanting a four stroke is, like many people who have been around aviation for a while, it is ingrained in me that four strokes are more reliable then two strokes. I don't have to many issues with landing in a field due to an engine failure, that is just natural after flying gliders for years, but I didn't want that to be a concern of mine when my wife and son are out tooling around without me. I realize the two strokes have made huge leaps in performance and reliability but it is still hard to find any real statistics. So how has your experience been with the 582? How strictly do you follow the 150/300 hr rebuild schedule and have you had any flame outs? I also read a really good article, it is a bit old now but it breaks down the cost of operating a 582 vs a 912. Based on purchase price, fuel, routine maintenance, and oil it actually showed that it is cheaper to go with a 912 after less then 1200 hours. I will link the article but I am curious what your response would be since you have obviously flown a good amount on a 582. Thanks for the info.
http://www.ultralightnews.ca/articles/912vs582.html
Guy Buchanan
Posted: Mon May 19, 2008 10:53 am Post subject: Information on EA-81 |
At 11:03 AM 5/19/2008, you wrote:
| Quote: | I realize the two strokes have made huge leaps in performance and
is cheaper to go with a 912 after less!
I have been flying my 582 powered Fox for almost two years now. Here
are my opinions:
1. The 582 is very reliable if cared for both while in flight and on
the ground. (Two strokes are, in general, equally reliable if cared
for, in my experience.) There is currently no more excuse for
"flame-outs" with a 582 than with any other aircraft engine.
2. The 582 requires more care in flight due to the necessity of
maintaining high, but not too high EGT's. Modern electronics make
this quite easy. (I use a GRT engine monitor with a BIG RED LIGHT.)
All else remains quite similar to four strokes operationally.
3. The 582 requires more maintenance on the ground due to the 300
hour rebuild schedule. Most are recommending against the 50 hour
de-carbons now and some even recommend running the engine without
inspection the full 300 hours. (I pulled my top end apart at 150 hours.)
4. You are correct in stating that a 912 is cheaper in the long run.
I've just run the numbers for modern costs and it's still true.
5. Having to carry and/or find oil for your two stroke is a PITA. For
my long trips I carry oil. This reduces payload and increases anxiety.
6. The 582 has the highest power to weight of any aircraft engine out
there. A close second is the 912S. However, as in all things, theres
no substitute for horsepower so the 912 will beat the pants off a 582
every time.
I love my 582. It's been a great engine- reliable, easy to
start, easy to maintain, and lots of grunt. That said, I'll be
switching to a 912S primarily because of #4 and 5 above.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
clint_bazzill(at)hotmail. Guest
Posted: Mon May 19, 2008 11:11 am Post subject: Information on EA-81 |
Add to that, faster and a lot more range, and a lot cheaper to operate.
Clint
912ULS 1320 hours, also had 912UL before.
| Quote: | Date: Mon, 19 May 2008 11:48:37 -0700
Subject: Re: Re: Information on EA-81
--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
are my opinions:
every time.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Duca=======================
&g==
Lynn Matteson
Posted: Mon May 19, 2008 11:17 am Post subject: Information on EA-81 |
I'm not a Jabiru dealer, nor do I play one on TV or here on this
group. But I AM a satisfied owner/operator of a Kitfox IV with Jabiru
2200 power with 510 hours of operation, flying from mid-America to
each coast. I offer this info just to offset all the talk of the
"other" brand. Just because they are the most-used engine doesn't
mean they are the only engine. Keep the 4 cylinder, 4 stroke Jab in
mind while you're shopping.
Lynn (NOT a Jabiru dealer)
On May 19, 2008, at 2:09 AM, WurlyBird wrote:
<james.t.trizzino(at)us.army.mil>
Prospective Kitfox buyer
Here for information on airframes and engines
http://forums.matronics.com/viewtopic.php?p=183767#183767
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
WurlyBird
Posted: Mon May 19, 2008 11:22 am Post subject: Re: Information on EA-81 |
Jabiru is another name that seems to come up a lot. i am very unfamiliar with them though. What kind of engine sizes/hp do they come in and what are their purchase prices like? If you know of a dealer site that has good info a link would more then suffice.
Michel
Posted: Mon May 19, 2008 12:21 pm Post subject: Information on EA-81 |
| Quote: | From: WurlyBird [james.t.trizzino(at)us.army.mil]
with them though.
Like Lynn and a few others, I am a happy Kitfox/Jabiru owner.
Five years ago I bought a Kitfox 3 with a Rotax 582. I had no previous knowledge of aviation or engines. The 582 was a fine engine but when I had 270 hours on it, I decided to change it for a four-strokes engines because I wanted to do some long distance flying in Europe and I was told that real pilots flew behind 4-strokes engines.
The 912 was the first choice. But it is heavy for my very light model 3. The Jabiru 2200 was a good alternative since it was about the same weight as the 582. It was also cheaper. But what made me decide for it is this: I don't know about engine and therefore it made sense that I did what generations of pilots have done for decades: Choose a direct drive air-cooled engine.
The Jabiru is very simple and easy to install. The only problem I had was that the boxer engine needed more place under the cowling. Now I had seen several modifications and even the Skyfox cowling. But I went for making my own cowling and I don't regret it. The plane doens't have anymore the sweet rotaty look but it works very well. Like all air-cooled engine, the key to success is to make a good vacuum chamber so that the engine is kept cool at any time.
The Jabiru has been through several changes during the years, each time trying to improve a bit the engine. The 2200 is nominal 80 HP but it went from an actual 75 to 85 HP by improving details, even if in the process the compression has been reduced.
The latest improvement has been hydraulic lifters. It created a problem in the oil pressure in the rocker chamber but it is now fixed. Those with the the first models had to drill holes in the engine.
The only real drawback with the engine is that you should have a fixed pitch wood propeller. That's a price you have to pay to avoid harmonic vibrations on the direct drive. Some composite propellers are reported to work well too. But I have the original Jabiru wood propeller since I don't have the nerves to be a test pilot.
The TBO of the Jabiru is 2000 hours with a rebuild of the heads at 1000 hours. I have 260 hours on mine and maintenance is only an oil and oil filter change every 50 hours.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
Posted: Mon May 19, 2008 12:25 pm Post subject: Information on EA-81 |
They come in 4 cylinder.....85 hp, and 6 cylinder....120
hp.....www.usjabiru.com or www.jabirupacific.com or just google
"jabiru"
They also have an 8 cylinder, but I understand they are not producing
them at this time, in order to put all efforts into producing the 4's
and 6's.
Lynn
On May 19, 2008, at 3:22 PM, WurlyBird wrote:
http://forums.matronics.com/viewtopic.php?p=183865#183865
N369LM |
kirkhull(at)kc.rr.com Guest
Posted: Mon May 19, 2008 3:19 pm Post subject: Information on EA-81 |
I have a classic 4 with a stratus converted ea-81. it is a little heavy
but with 100 hp she is still a stellar performer our performing just about
everything in her class. The sub has 160 hours on it with no problems. The
basics of the engine are factory Subaru so parts are easy to get from any
auto parts store. TBO is 2000 hours and I would assume the parts are cheap
since they are stock auto parts. As far as reliability ,I was unable to
find any body that has had any problems with one.
