pilotdds(at)aol.com Guest
Posted: Wed May 21, 2008 8:25 am Post subject: Rigging-ailerons v flaps |
I am reassembling control surfaces after new paint and have discovered the ailerons are about .125 of an inch higher than the flaps in the reflex position when measured at the trailing edge.The aircraft has 175 hours since my first flight.It has required significant rudder trim-solved with a fixed tab,and a slightly heavy right wing-3 gallons of fuel.The ailerons are symetrical when the stick is neutral that is both trailing edges are above the flaps by an equal amount.Any thoughts from other builders.
rene(at)felker.com Guest
Posted: Wed May 21, 2008 9:09 am Post subject: Rigging-ailerons v flaps |
This might not be much help, but I did have to readjust my right flap due to airframe contact. It had a heavy left wing. So I would think that it may be your flap rigging.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Wednesday, May 21, 2008 10:22 AM
Subject: Rigging-ailerons v flaps
sfdarton(at)yahoo.com Guest
Posted: Wed May 21, 2008 9:35 am Post subject: Rigging-ailerons v flaps |
I would not worry about the aileron rigging as much as
being sure that the flaps don't need to be raised to
be in the proper position. The Citation I fly has the
ailerons rigged both about .375" up, it flys great.
I've heard of aircraft racers intentionally rigging
ailerons this way to reduce drag.
Steve 40212
--- pilotdds(at)aol.com wrote:
[quote] I am reassembling control surfaces after new paint
VHMUM(at)bigpond.com Guest
Posted: Wed May 21, 2008 1:37 pm Post subject: Rigging-ailerons v flaps |
Following the directions from Vans mine were also up about the same so I ajusted the push rods at the wing route.
Chris 388
