Trim Tab Rigging and SB Write-Up Posted
Tim Olson
PostPosted: Sat Jun 28, 2008 11:04 am    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
I finally am on the road and had my wife drive so I could finish a write
up I've had planned to show the issues with Trim Tab rigging and then a
brief summary about the Service Bulletin. I may revise it later a bit,
but here is what I have. Also, none of the other many links that I
updated are ready yet, so the only way to this page right now is by
this link:
http://www.myrv10.com/N104CD/maintenance/20080622/
Feel free to discuss. I'd like to thank Bill DeRouchey for his input in
the "twisted tail" arena. I don't know that it will be a major issue
for most people, but it definitely is worth reading the link and
checking it on your own plane. If you haven't yet done the SB, just
wait until it's all assembled.
Enjoy!
johngoodman
PostPosted: Sat Jun 28, 2008 1:28 pm    Post subject: Re: Trim Tab Rigging and SB Write-Up Posted Reply with quote
Tim,
That was an excellent article. You answered a lot of questions but, as always, it brings up more questions. My first one is easy. The doubler looks like it interferes with the longeron, but obviously it doesn't. Is it touching the longeron?
My next question is about the operation of the two trim tabs. You explanation was excellent, but it begs the question - why two trim tabs in the first place? I am NOT an aeronautical engineer, so I'm allowed to ask stupid questions (g). Could we not operate with just one tab? If it is too small, could it have been made bigger? If two tabs were necessary, why not sync them together and limit the nose down travel (tab up) to something less?
Probably dumb questions, but it sure has been crossing my mind lately.
John
Deems Davis
PostPosted: Sun Jun 29, 2008 5:11 am    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
Tim, EXCELLENT write-up & synopsis. THANKS ! I also believe that Bill
DeRouchey deserves a lot of credit for identifying the 'potential' for
problems down the road and the likely (IMO) link between trim tab
rigging and the SB. Your write up does a very good job of tying all of
this information together. To the best of my knowledge, no one that is
flying has reported any cracks, But the pictures of the 'working rivets'
in your plane further reinforce the evidence of a twisting force in the
tail. IMO compliance with the Service Bulletin should be tied to an
examination and potential re rigging of the trim tabs.
THANKS for the service you provide this community.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
speckter(at)comcast.net
PostPosted: Sun Jun 29, 2008 10:16 am    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
I know that I will get some flames on this, but I am not convinced that the
twisting caused by trim tab rigging is the issue. All of the other RV
series have a single trim tab on one elevator only as do many other general
aviation aircraft. Yes this does cause twisting, but not to the extent that
it should be worrisome. I suspect that there are other design issues going
on in the 10 tail and that the trim tab torque only made it show up as a
fatigue crack earlier than it normally would have if both tabs moved in
parallel.
Steady even torque is not as rough on structures as is osculating torque
such as comes from turbulence. Even the lowly beer can takes a lot of
torque but not so much bending back and forth. Additionally the bulkhead in
Van's pix looked bent to me like it was over stressed.
All I am saying is that we don't have enough info or engineering data to
make a definitive diagnosis. Many possible theories but no proof.
Gary
40274 Flying
AV8ORJWC
PostPosted: Sun Jun 29, 2008 12:24 pm    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
As Tim knows, I have discussed in detail with the former manager of the
VANS Proto-type shop the history of the build of N220RV. He was not
receptive to the possibility of workmanship as the cause. Seems N220RV
had quite a history on the removal and experimental research of multiple
tail designs directed by management. (Not unlike six attempts to get a
wing that worked on the RV-12). The histrionics of single tab and dual
tab were discussed in detail. Using the airframe for demos and the
repeated demonstration of stalls to John Q. Public had something to do
with it. The horizontal tips deflect 3" positive and negative with a
noticeable buffet.
Alex D has not had a problem, Mike Seager did not have a problem, so I
have concluded it is unique to N220RV. No one is mentioning the other
issue of the J stringers in contact with the frames and bulkheads.
I am following the respected advise I received and using a modified and
doubled two F-1010s back to back construction technique. Others should
be fine installing the SB patch and sleeping at night. Been to the
mountain, read the tablet, listened to Moses and returning to prayer.
There is history, engineering and information on this issue. It is not
available for public consumption. That is proof enough for me.
John Cox
40600 KUAO
rene(at)felker.com
PostPosted: Sun Jun 29, 2008 12:38 pm    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
One note.....Mike Seager normally trains in N220RV, so technically he did
have a problem. When I went up for my transition training, I did it in
410RV, but Mike told me that he normally does it in N220RV but could not
because it was in the shop.......that was the end of Feb this year.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
AV8ORJWC
PostPosted: Sun Jun 29, 2008 2:51 pm    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
Flying the aircraft and having a problem are two entirely different
events. I was not aware that Mike had any problem other than the lack
of availability. He has been great to point out the horizontal
performance and airmanship issues which can improve safe flight.
I would love to hear more about his having a problem and think many
builders would like to know more about cause and effects on N220RV.
So far, I have not heard of any aircraft other than N220RV which an
inspection finding. It was valuable learning of the development
history.
John
Tim Olson
PostPosted: Sun Jun 29, 2008 3:15 pm    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
Oh I totally agree that it isn't likely to be a cause.
And I agree fully regarding the fact that other planes have
a single tab too, which is why I mentioned it. I don't
think it's likely to cause many builders a problem. The thing
is though, having one tab going one way and the other going
opposite isn't at all what a person would want, so I wanted
to point out how just doing things "normally" may result in
a slight amount of this situation. I know I had it, and
I didn't see the twisting and the asymmetry. I can only
think though that the further one's tabs are off, very
quickly the forces could get higher and higher. So, it's
just plain good sense to make sure everything is rigged right.
I'm not sure what caused the cracks on that plane, but I can
easily see it being a combination of: Some big turbulence
hits, lots and lots of tail shuddering stalls, and potentially
maybe not deburring well around that notch. Hard to blame
the deburring much though, because there is definite deformation
of that bulkhead. Oh well, it happened....I'm just glad
it's stronger now.
parallel.
Gary
40274 Flying
rene(at)felker.com
PostPosted: Sun Jun 29, 2008 5:38 pm    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
Now that I am not at work and have a couple of minutes......before the kids
come and attack me....
As I reported here, I had a heavy left wing during my initial flight
testing, and in the end I attributed it to three things.
1. Me being to fat and not giving enough credit to that fact. I have since
always burned the left tank down when I am the sole occupant. That was the
easy one.
2. Flap rigging, my right flap was 1 degree lower than the left flap. It
was do to a little interference between the inside edge of the flap and the
fuselage. I was able to file down the flap a little, getting a better fit
and got the rigging right. I also re-rigged the ailerons, but it was very
minor. After that I felt I still had a heavy left wing. Trim handled it,
but I felt I was using to much trim and I could see the ailerons were not in
trail in level flight.
3. The last thing I did was re-rigged the elevator trim. When I first
flew, I felt I was using way to much nose down trim after takeoff and in
cruise flight. After to talking to some other flyers, I felt that may be
more normal. I walked through the rigging procedure several times and was
not happy with the way the left trim moved......so I tried to fix that. At
about a degree at a time I changed the starting position from 35 down to 34
down and so on. Did a test flight each time, trying to determine if I was
changing anything. Handling stayed the same. In the end, if I remember
correctly, I ended up a little under 33 degrees. With that, the left comes
up and then goes back in trail as I go to full nose down.
Now after doing all that, I do not notice the heavy left wing.....and I am
still fat, so at least I kept one variable constant.
Tomorrow is my first real cross country, me and my wife are headed to Vegas
for a couple of days to met up with my Brother and friends. It will be the
first test where I have not had something else to do except pay attention to
the plane.
Rene'
801-721-6080
PostPosted: Mon Jun 30, 2008 6:07 am    Post subject: Trim Tab Rigging and SB Write-Up Posted Reply with quote
This is in the department of SWAG. It looks to me like someone pushed down
on the horizontal stab and bent things doing so and it was flown like that
for a while. But as I pointed out in my comments this is all conjecture.
Gary
40274 Flying
