Jimmy Young
Joined: 24 Nov 2007 Posts: 182 Location: Missouri City, TX
Posted: Sun May 25, 2008 3:30 am Post subject: engine out...uh oh |
Kolbers,
Yesterday I had an engine out forced landing after about 15 minutes
into my flight. I was at about 1000 ft. and the engine started
coughing a bit and dropped most of it's power. I made an uneventful
off-field landing in a hayfield. It was my first engine out
experience, and I will be the first to admit that once I landed and
stopped, my thoughts were that any other good news is just a bonus.
Your priorities will change rapidly depending on your situation.
I called a friend who came out to pick me up, after a good walk
through the country. I contacted the owner of the property and
returned to stake her down and put a tarp over her. I'll be going out
this morning to fold her up and haul her home for diagnosis. I'll
update the List with my findings later.
Jimmy Young
FS II
Houston TX
_________________ Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700 |
planecrazzzy Guest
Posted: Sun May 25, 2008 6:39 am Post subject: Re: engine out...uh oh |
Hi Jim,
Glad to hear things turned out alright....
How many hours on the engine ? 503 ?
Gotta Fly...
Mike & "Jaz" in MN
| Jimmy Young wrote: | Kolbers,
off-field landing in a hayfield. It was my first engine out experience,
Jimmy Young
FS II
Houston TX |
Posted: Sun May 25, 2008 8:30 am Post subject: engine out...uh oh |
Hey Jimmy, join the club. This morning I had a trip to a fly in
b'fast cut short.
In my case the push-in fitting on the carb decided to part ways with
the top cover.
(that guy will get threads now!)
good news/bad news: this hay field was long alfalfa (bad news)
The last few feet of the slide was with a good view of the hay out
the windshield as the
old Kolb tipped up on the nose. -lots of drag.
Some cosmetic blems on the nosebowl, bent pitot assy.
-and the aluminum tailwheel spring snapped off. A visual inspection
revealed
that an old fracture at that point, just where it emerges from the
steel receiver tube.
A generous neighbor and new friend gave me a lift back to my car and
tools.
I stuck the spring back in, drilled one hole, shortened the chains
and flew it
back out of a soft, bumpy cornfield. It took about 40 bounces to get
the right levitation.
15 minutes round trip. No breakfast.
On 25, May 2008, at 7:26 AM, Jimmy Young wrote:
Kolbers,
out this morning to fold her up and haul her home for diagnosis.
I'll update the List with my findings later.
Jimmy Young
FS II
Houston TX
Jimmy Young
Posted: Sun May 25, 2008 2:48 pm Post subject: engine out...uh oh |
All,
I spent all day getting my plane out of the field and back to the
hanger with the help of a good friend. When I got there this morning,
I changed out the plugs to see if it would turn over & run. It fired
up after some coaxing, but it was not running well at all. I watched
the engine temps and within less than a minute it was obvious the #1
cyl is not running. I shut it down and proceeded to move on with the
task of transporting her home. Tomorrow I'll see if I can figure out
what happened.
For planecrazy; you asked how many hrs. on the engine: it's a 503 DCDI
with 205 hrs. I checked the rings thru the exhaust ports at 175 hrs,
and they were fairly clean and moving freely. I plan to check for
spark at the plugs tomorrow and move on from there. I did look at the
carb bowls out in the field, both were full of clean gas, no water or
visible contamination. The #2 cyl plugs looked good, nice tan color,
but the #1 cyl plugs were a darkish metallic grey color, not wet or
oily, but a color indicative of either no ignition or way too rich.
Jimmy Young
FS II
Houston
Missouri City, TX
DAquaNut(at)aol.com Guest
Posted: Sun May 25, 2008 8:22 pm Post subject: engine out...uh oh |
In a message dated 5/25/2008 6:31:11 A.M. Central Daylight Time, jdy100(at)comcast.net writes:
Kolbers,
into my flight. |
Jimmy,
So glad to hear you were up to the task at hand, and you had a suitable spot to land and those great big tires on her! I will be at the hanger in the next couple of days. Glad You and your bird are OK!
Ed Diebel
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
