wayne.e(at)grandecom.net Guest
Posted: Wed May 21, 2008 7:44 pm Post subject: Gascolator |
I'm just finishing up my annual condition inspection and I've had two A&P's ask me why my plane isn't equipped with a gascolator, to which I didn't have a very good response other "I dunno". I searched the archive a there were a couple of entries, one being from Randy DeBauw saying he didn't know of any RV10 with a gascolator installed, but his post was nearly three years ago. Has anyone installed or considering installing a gascolator?
I know that the plans don't show or call for the installation of a gascolator. The point they made with me is where does any accumulated water in the fuel go then.
Wayne Edgerton N602WT
Heading up through Alaska next month with the 10.
dlm46007(at)cox.net Guest
Posted: Wed May 21, 2008 8:27 pm Post subject: Gascolator |
I owned a C177RG for 29 years and the FAA ADed a gascolator after about 1977. In all those years I never had water in the gascolator or lower fuel sumps. In fact I found water in the wing fuel tank sumps only twice after an FBO pumped in the water from contaminated fuel/water. BTW; one of those times was during OSH.
The only thing the gascolator provided was another maintenance item which required changing the seals every few years which was always located in a very difficult position on the firewall.
another A&Ps view
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Wednesday, May 21, 2008 8:41 PM
Subject: RV10-List: Gascolator
wcurtis(at)nerv10.com Guest
Posted: Wed May 21, 2008 8:42 pm Post subject: Gascolator |
Let me guess, these A&P's are used to working on high wing airplanes right? I tell you, you give some guy a hammer and everything looks like a nail.
The primary purpose of a gascolator is to "filter" water out of fuel that settles. It can capture settling water but even a gascolator cannot capture water being forced by a pump. Since water is heavier than fuel, in order for a gascolator to the perform its function, it needs to be at the lowest point in the fuel system. In a high wing aircraft, gascolator placement at a point lower than the fuel tanks is relatively easy. In a low wing aircraft it is difficult to place a gascolator lower than the fuel tanks so any benefits from filtering out settling water is negligible. You can certainly put one on a low wing aircraft, however the benefits are typically not worth the effort.
The accumulated water go out the individual tank drains. Those are the lowest point in the fuel system.
William
http://nerv10.com/wcurtis/
dougpflyrv(at)gmail.com Guest
Posted: Thu May 22, 2008 7:20 am Post subject: Gascolator |
HAVE A SAFE, FUN TRIP WAYNE. BE SURE TO GIVE US A TRIP REPORT WHEN U GET BACK. A FEW OF US ARE PLANNING A WEST COAST TRIP IN SEPTEMBER. ANYONE WANT TO JOIN THE GAGGLE?
DOUG PRESTON
N372RV
BHM
On Wed, May 21, 2008 at 10:41 PM, Wayne Edgerton <wayne.e(at)grandecom.net (wayne.e(at)grandecom.net)> wrote:
[quote] I'm just finishing up my annual condition inspection and I've had two A&P's ask me why my plane isn't equipped with a gascolator, to which I didn't have a very good response other "I dunno". I searched the archive a there were a couple of entries, one being from Randy DeBauw saying he didn't know of any RV10 with a gascolator installed, but his post was nearly three years ago. Has anyone installed or considering installing a gascolator?
millstees(at)ameritech.ne Guest
Posted: Thu May 22, 2008 10:36 am Post subject: Gascolator |
Wayne:
You'll love the Alaska trip...I did it a few years back in my Arrow, and it was the best vacation we have ever done. If you would like, give me a call, and I will give you a few insights, suggestions, and do's and don'ts. My cell is 630-308-7476.
Steve Mills N750SM (reserved)
RV-10 40486 Slow-build Eggenfellner E-6TI
Naperville, Illinois
Finishing kit, engine install
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doug Preston
Sent: Thursday, May 22, 2008 10:18 AM
Subject: Re: RV10-List: Gascolator
DOUG PRESTON
N372RV
BHM
