				 Posted: Fri May 23, 2008 2:23 am    Post subject: wing problem |
				Pat- Did you fix your wing problem yet, and have you test flown it again?
                                       Bill Sullivan
                                       FS/KX/447
                                       Windsor Locks, Ct.
				 Posted: Fri May 23, 2008 3:04 am    Post subject: wing problem |
				Pat- Did you fix your wing problem yet, and have  you test flown it again?>>
  Hi Bill,
  Yes thanks. I reversed the swivel fitting on the  port wing attachment enabling me to lower the trailing edge a bit more. This  seems to have done the trick. I got in a nice 80 minute cruise around the area  the night before last. Quiet evening, the wind finally changed from about 15 mph  across the strip which I didn`t think I could handle at the moment to about 5  mph straight down the runway. There was about12 mph when I got to 1500  ft.
  I still have the Hauk designed  bungy   trim on the stick but as she will fly at 70mph at 2650revs hands off I think  that will do nicely.
  Thanks everybody for their  suggestions.
  Cheers
  Pat.
