toe brakes
aireupora(at)sbcglobal.ne
PostPosted: Mon May 26, 2008 10:56 am    Post subject: toe brakes Reply with quote
I'm in the process of installing my toe brakes, but the book talks about putting the cylinders on the port side of the bracket.
I installed the two cylinders between the two bracket supports. Now I'm questioning myself. Any picture out there? I measured the 4 1/2 inches and there does not seem to be enought room to put the left brake cyinder on the outside of the bracket.
Any help would be nice.
budyerly(at)msn.com
PostPosted: Tue May 27, 2008 6:48 am    Post subject: toe brakes Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Rick,
Both pedals go between the rudders with the mounting brackets between the rudders with the horizontal flanges facing one another. I have the old manual with the brakes between the rudders pages with drawings which are quite clear if you need it (Page 33T-3 of the old manual). If you don't have that, I can scan the sheets and send them via email Wed night.
Bud Yerly
Custom Flight
