Hobbs Meter Switch Location on O-360-A1A?
bobair8(at)msn.com
PostPosted: Mon May 26, 2008 11:13 am    Post subject: Hobbs Meter Switch Location on O-360-A1A? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Folks,
I'd like to install a Hobbs meter in my experimental GlaStar. Does anyone know where the oil pressure switch can be placed on this engine? Page 7-8 of the Lycoming Operator's Manual doesn't seem to help me. I have the oil pressure gauge sender installed where it says "Oil Pressure Gauge Connection".
Best regards,
Bob
N248BF
GlaStar
davelammers(at)mchsi.com
PostPosted: Mon May 26, 2008 11:34 am    Post subject: Hobbs Meter Switch Location on O-360-A1A? Reply with quote
Bob,
You can "tee" it in at the same place..
Careful to structurally support it to the engine (not the mount). You do not want a lot of unsupported weight on a long lever--you could break the fitting with vibration.
You could use flex hose from that location to the Hobbs switch and p-sensor ganged together and structurally mounted somewhere off engine.
Or,
There may be other available ports, look for 1/4 NPT galley plugs.
Good luck,
Dave Lammers
r falstad wrote: [quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Folks,
Best regards,
Bob
N248BF
GlaStar
href="http://www.matronics.com/Navigator?LycomingEngines-List">http://www.matronics.com/Navigator?LycomingEngines-List
