Fab Bypass Filter
Goto page 1, 2  Next
emrath(at)comcast.net
PostPosted: Wed May 28, 2008 6:15 pm    Post subject: Fab Bypass Filter Reply with quote
Starting around late 2003, or so I think, Van's put out a modification for
bypassing the filter in the FAB should the filter get clogged. This is for
the vertical induction carb or FI-servo installations. The original method
utilized a magnet and then a revised version utilized a cable operated by
the pilot. At the time, when I first fabricated the FAB, I modified it
according to the original method using the magnet. Today, as I finish up my
panel and get prepared to put the forward top skin on, I began thinking
about this once more. So, I'm wondering if anyone still has the magnet
version of this modification on their ship and can tell me if the bypass
magnet releases and lets air bypass the filter under NORMAL operating
conditions or not. I'm driving myself crazy trying to determine what the
NORMAL psi differential might be on this door to compare the calculated
force needed to open the door and the amount the door will see during NORMAL
operations. Anyone/everyone have some thoughts on this?
Marty in Brentwood, RV6A
bobbyhester(at)newwavecom
PostPosted: Wed May 28, 2008 6:40 pm    Post subject: Fab Bypass Filter Reply with quote
Marty, I did not put a bypass door in. I was told that the reason they changed from the magnet was because it was opening during normal operations. After giving it some thought I decided that I would put one in at all. I am not going to be flying in conditions that will cause the filter to ice over.
Surfing the web from Hopkinsville, KY
Visit my flying RV7A web page:
http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm
Emrath wrote: [quote]
--> RV-List message posted by: "Emrath" <emrath(at)comcast.net> (emrath(at)comcast.net)
Checked by AVG.
Dale Ensing
PostPosted: Thu May 29, 2008 3:21 am    Post subject: Fab Bypass Filter Reply with quote
The by-pass door, with magnet, on my O-360 was opening frequently. I suspect
on high MAP settings. It has been fixed closed. I have the cable control for
the door but have chosen not to put in on. I think this was another CYA
issue brought on after Van's became an employee owned business.
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
timb
PostPosted: Thu May 29, 2008 3:51 am    Post subject: Fab Bypass Filter Reply with quote
Wow, I didn't realize the door was opening under normal conditions. How did
you determine this? I fly off a grass runway and the thought of all that
crap getting in my engine is a bit frightening. Also how did you (what
method) close it off permanent?
Tim Bryan
RV-6 Flying
N616TB almost 100 hours now
[quote] --
Tim Bryan
RV-6 Flying
N616TB
Dale Ensing
PostPosted: Thu May 29, 2008 4:22 am    Post subject: Fab Bypass Filter Reply with quote
The area where the door made contact with the airbox showed signs of
opening/closing. I semi-permanently closed it by bonding the door to the
airbox with fluorosilicone sealant which is resistant to gasoline. You could
do the same thing with a bit of Proseal from Van's.
I attributed my situation to the O-360 with spark advance from LASAR
ignition which puts out a lot of power on take off. Other engine set-ups may
not have the problem. However, if I remember correctly, Van's went to the
cable control set-up because they also discovered the magnet was not strong
enough to hold the door closed.
RV-6A N118DE
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
rv6n(at)optonline.net
PostPosted: Thu May 29, 2008 4:50 am    Post subject: Fab Bypass Filter Reply with quote
I recently finished my condition inspection and discovered the magnet missing E 6nbsp; Obviously it vibrated off E 6nbsp; I too have received the new cable mod but refuse to put it on because it 7s design worries me E 6nbsp; The thought of a rivet 6nbsp;getting sucked into the induction system is scary E 6nbsp; So I removed the remaining parts of the original system and fiber-glassed 6nbsp;the opening closed because I would do a 180 and stay clear of weather that would call for the need of a bypass in the first place E 6nbsp; 6nbsp; Before I sign off on the inspection a simple note will be made in my POH 6nbsp;explaining why my plane should not be flown in conditions that will cause the FAB 6nbsp;to be blocked E E 6nbsp;
6nbsp;
mrobert569(at)hotmail.com
PostPosted: Thu May 29, 2008 4:58 am    Post subject: Fab Bypass Filter Reply with quote
We found signs of the door openeing during high power setting on our IO-320. Once I prosealed the door closed there was a very noticable increase in manifold pressure during take-offs and the engine ran much better.  We decided to leave the door closed and replaced it recently with a new FAB without a door cutout. Much better!!
Mike Robertson
Das Fed
[quote] From: densing(at)carolina.rr.com
To: rv-list(at)matronics.com
Subject: Re: Fab Bypass Filter
Date: Thu, 29 May 2008 08:18:47 -0400
--> RV-List message posted by: "Dale Ensing" <densing(at)carolina.rr.com>
RV-6A N118DE
Dale Ensing
brad.reak(at)verigy.com
PostPosted: Thu May 29, 2008 7:02 am    Post subject: Fab Bypass Filter Reply with quote
When I built my air box (RV7A) I followed the directions and built the alternate air door with the magnet. After flying the first 20 hours and reading that Van’s had redesigned the alternate air door, I decided that for my type of flying, the benefit of an alternate air door was non-existent but the cost of having the door open when it should closed could be high ($$$). So I sealed the door shut and am not loosing any sleep over the decision.
Brad Reak – RV7A, 70 hours.
Terry Watson
PostPosted: Thu May 29, 2008 7:33 am    Post subject: Fab Bypass Filter Reply with quote
I removed the door and magnetic latch and installed one of Van’s oil cooler shutters instead. It looks like it will work fine, when it flies.
Terry
RV-8A
Seattle
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Reak, Brad
Sent: Thursday, May 29, 2008 7:56 AM
mr.sun
PostPosted: Thu May 29, 2008 8:21 am    Post subject: Fab Bypass Filter Reply with quote
I've got a -7 with the forward facing injection and no bypass installed. I've been considering installing one. My thought had been to put in a cable operated air door with some scat tubing feeding it from a NACA vent under the front of the cowl. My thought was that it wouldn't clog or ice up when the air filter does even though it would be cold air. The other use for it would be to increase my MP when I open it during cruise.
Any thoughts on this one?
Greg
On Wed, May 28, 2008 at 7:08 PM, Emrath <emrath(at)comcast.net (emrath(at)comcast.net)> wrote:
[quote] --> RV-List message posted by: "Emrath" <emrath(at)comcast.net (emrath(at)comcast.net)>
Greg RV-7
Dale Ensing
PostPosted: Thu May 29, 2008 10:06 am    Post subject: Fab Bypass Filter Reply with quote
Greg,
Connecting the bypass door via SCAT tubing hooked up to a NACA vent would give you fresh, unheated, unfiltered air but why open the bypass door in normal cruise? Van's ram air scoop supposedly gives a minimal amount of MAP increase. Don't think the NACA vent would give any ram air pressure. And would the NACA vent also be prone to freezing up to some degree in a cold rain just as the filter in the airbox? Maybe not but worh thinking about.
Dale
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
mr.sun
PostPosted: Thu May 29, 2008 5:20 pm    Post subject: Fab Bypass Filter Reply with quote
My thought is that the air filter robs some pressure and by providing fresh air from a scoop or NACA vent might make up for some of this loss. I've thought about the vent being prone to freezing or ice but since it is on the bottom of the cowl and "facing" downward it would accumulate ice slower than the air filter which sits just inside the engine air inlet facing upwards just waiting for ice to cover it up. This whole idea wouldn't be the best for preventing ice from suffocating the engine compared to warm air from inside the cowl but I think there might be some benefit from the ram air. Maybe I need a larger NACA vent & tubing. I don't want Van's lower snout, though. Just don't like the looks of it.
Greg
On Thu, May 29, 2008 at 11:03 AM, Dale Ensing <densing(at)carolina.rr.com (densing(at)carolina.rr.com)> wrote:
[quote] Greg,
Dale
Greg RV-7
timrvator(at)comcast.net
PostPosted: Thu May 29, 2008 6:21 pm    Post subject: Fab Bypass Filter Reply with quote
There's been one RV-6 fatal accident (that I personally know of) traced
to a snow-clogged air filter. Pilot and passenger killed.
I was lucky to survive the same thing in my RV-6A several years ago.
Van's bypass came out shortly thereafter.
Observations:
- Snow at night or while IMC may not be visible or recognized.
- The air filter can be blocked even when there is absolutely no visible
moisture accumulation on the airframe exterior.
- "I'll remember to use carb heat as a preventative" can be
overlooked/forgotten.
- Once blockage has occurred, the carb heat in an RV (using the carb
heat muff) will not melt the snow sufficient to restore required air
flow into the engine.
Omit a filter bypass at your peril.
Tim
P.S.
Other observations:
- There exists a breed of FAA "investigator" who will manufacture
fantastic stories if the facts don't support his pet views.
- A closed mouth and the AOPA legal services plan can be effective tools
against this sort of FAA fiction writer.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction
suspect on high MAP settings. It has been fixed closed. I have the
cable control for the door but have chosen not to put in on. I think
this was another CYA issue brought on after Van's became an employee
owned business.
PostPosted: Thu May 29, 2008 6:42 pm    Post subject: Fab Bypass Filter Reply with quote
Well, seems the consensus is to just not use a bypass for the filter based
on the responses. Thanks to everyone.
for
for
method
by
it
up my
thinking
magnet
bypass
the
calculated
NORMAL
ronlee(at)pcisys.net
PostPosted: Thu May 29, 2008 7:03 pm    Post subject: Fab Bypass Filter Reply with quote
Don't fly in snow/cold clouds.
Ron Lee
pitts_pilot(at)bellsouth.
PostPosted: Fri May 30, 2008 4:40 am    Post subject: Fab Bypass Filter Reply with quote
Not exactly RV-related, but my Pitts has an alternate air flapper as
standard equipment. Much like the heat flapper on the firewall.
Remember that besides snow/ice, the filters have been blocked by swarms
of bugs, and toilet paper ('ribbon cutting' for the masses that like to
play) and even balloons (again playing with our airplanes) .......and
because I like to play ...... well, I'll have and alternate air source
for my engine. I don't mind an extra cable or fab time if it'll save my
butt because I participated in some activity at a flyin.
YMMV.
Linn
traced to a snow-clogged air filter. Pilot and passenger killed. I
Observations: - Snow at night or while IMC may not be visible or
recognized. - The air filter can be blocked even when there is
absolutely no visible moisture accumulation on the airframe exterior.
overlooked/forgotten. - Once blockage has occurred, the carb heat in
an RV (using the carb heat muff) will not melt the snow sufficient to
restore required air flow into the engine.
Tim
P.S.
Other observations:
tools against this sort of FAA fiction writer.
mr.sun
PostPosted: Sun Jun 01, 2008 7:15 am    Post subject: Fab Bypass Filter Reply with quote
So it sounds like the consensus is a bypass air flapper is a good idea for things in addition to ice. However, does opening one while in cruise help with MP and power? How about if it is getting cold air from below the prop somewhere? Greg
On Fri, May 30, 2008 at 5:36 AM, linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
[quote] --> RV-List message posted by: linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Not exactly RV-related, but my Pitts has an alternate air flapper as standard equipment. Much like the heat flapper on the firewall. Remember that besides snow/ice, the filters have been blocked by swarms of bugs, and toilet paper ('ribbon cutting' for the masses that like to play) and even balloons (again playing with our airplanes) .......and because I like to play ...... well, I'll have and alternate air source for my engine. I don't mind an extra cable or fab time if it'll save my butt because I participated in some activity at a flyin.
YMMV.
Linn
Tim Lewis wrote:
--> RV-List message posted by: Tim Lewis <timrvator(at)comcast.net (timrvator(at)comcast.net)>
There's been one RV-6 fatal accident (that I personally know of) traced to a snow-clogged air filter. Pilot and passenger killed. I was lucky to survive the same thing in my RV-6A several years ago. Van's bypass came out shortly thereafter.
Observations: - Snow at night or while IMC may not be visible or recognized. - The air filter can be blocked even when there is absolutely no visible moisture accumulation on the airframe exterior.
- "I'll remember to use carb heat as a preventative" can be overlooked/forgotten. - Once blockage has occurred, the carb heat in an RV (using the carb heat muff) will not melt the snow sufficient to restore required air flow into the engine.
Tim
P.S.
Other observations:
- There exists a breed of FAA "investigator" who will manufacture fantastic stories if the facts don't support his pet views.
- A closed mouth and the AOPA legal services plan can be effective tools against this sort of FAA fiction writer.
Greg RV-7
carl.froehlich(at)cox.net
PostPosted: Sun Jun 01, 2008 9:50 am    Post subject: Fab Bypass Filter Reply with quote
I believe the Van’s FAB/cowl arrangement provides a slight increase in MP. Running with the filter bypass open would both drop MP and increase air temp to the engine – both are negative attributes for engine power.
If you are suggesting adding another ram air intake for operations when bypassing the filter, some thoughts:
<![if !supportLists]>- <![endif]>You would not be able to measure the increase in MP if there is any. The large air filter used by Van’s is very efficient.
<![if !supportLists]>- <![endif]>The extra intake would be hard to configure without the cowl looking ugly (at best) or adding unnecessary drag (at worst).
<![if !supportLists]>- <![endif]>You will end up with the same ice/bird blockage problem that the bypass was intended to prevent, except in this case your normal intake may have experienced the same blockage, thus you end up with no engine.
Carl Froehlich
RV-8A (425 hrs)
RV-10 (flaps)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of mr.gsun(at)gmail.com
Sent: Sunday, June 01, 2008 11:11 AM
Not exactly RV-related, but my Pitts has an alternate air flapper as standard equipment. Much like the heat flapper on the firewall. Remember that besides snow/ice, the filters have been blocked by swarms of bugs, and toilet paper ('ribbon cutting' for the masses that like to play) and even balloons (again playing with our airplanes) .......and because I like to play ..... well, I'll have and alternate air source for my engine. I don't mind an extra cable or fab time if it'll save my butt because I participated in some activity at a flyin.
YMMV.
Linn
Tim
P.S.
Other observations:
mr.sun
PostPosted: Sun Jun 01, 2008 4:43 pm    Post subject: Fab Bypass Filter Reply with quote
Carl, I now have the horizontal induction with fuel injection and the filter is in the right engine intake. I love the looks and wouldn't want to add the "snout" underneath. I'm not sure how much loss, if any, I get by not having the ram air intake underneath.  The K&N filter is approx 6" x 6" and it is just inside the cowl opening. I question how much ram air pressure I get in that spot. Greg
On Sun, Jun 1, 2008 at 10:46 AM, Carl Froehlich <carl.froehlich(at)cox.net (carl.froehlich(at)cox.net)> wrote:
I believe the Van's FAB/cowl arrangement provides a slight increase in MP. Running with the filter bypass open would both drop MP and increase air temp to the engine – both are negative attributes for engine power.
- You would not be able to measure the increase in MP if there is any. The large air filter used by Van's is very efficient.
- The extra intake would be hard to configure without the cowl looking ugly (at best) or adding unnecessary drag (at worst).
- You will end up with the same ice/bird blockage problem that the bypass was intended to prevent, except in this case your normal intake may have experienced the same blockage, thus you end up with no engine.
Carl Froehlich
RV-8A (425 hrs)
RV-10 (flaps)
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of mr.gsun(at)gmail.com (mr.gsun(at)gmail.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
YMMV.
Linn
Tim
P.S.
Other observations:
Greg RV-7
Dale Ensing
PostPosted: Mon Jun 02, 2008 5:16 am    Post subject: Fab Bypass Filter Reply with quote
Very interesting Fred. Could you give us a little more info to get a mental picture of the bypass around the filter? Did you create an additional air passage on the fiberglass airbox?
Dale
do not achieve
[quote]   Instead, I implemented my trap door to source it's air supply from the airbox (yes, there is plenty of space between the filter and the lower level of the airbox..). This method allowed for the continued use of carb heat if/when the filter was blocked, preventing the secondary carb ice failure mode, and possibly melting the ice/snow that was blocking the filter.
Fred Stucklen
RV-6A N926RV (Sale Pending)
RV-7A N924RV (ready for an engine)
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
Goto page 1, 2  Next
Page 1 of 2
