		msausen
				 Posted: Fri May 30, 2008 6:22 am    Post subject: removable co-pilot stick |
				I didn’t seem to document this in my build log but what I ended up doing is using a recessed push button pin, much like what Linn described, on the pax stick.  Specifically it was a SS Recessed Push-Button Quick-Release, Mcmaster-Carr part number 92385A015.  With a 4600# shear strength I’m not overly concerned about it breaking.
 Michael
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters
  Sent: Friday, May 30, 2008 7:43 AM
  Subject: Re: Re: removeable co-pilot stick
 Why not a ball pin???  Check out http://www.reidsupply.com/catalog.aspx?pn=277 ......
  Linn
  orchidman wrote:    	  | Quote: | 	 		  --> RV10-List message posted by: "orchidman" <gary(at)wingscc.com>  n277dl wrote:   	  | Quote: | 	 		  | Anyone made the copilot control stick removable?  My wife enjoys the stick being pulled for long cross countries in the -7.  Doug     | 	   There was a thread like this I believe over on VansAirForce some time ago.  I am thinking about it but have not come to any conclusion yet nor has it come to the time when any decision must be made.  From the thread I noted and stored one thing that might be able to be used.  It is from McMaster.com (McMaster-Carr) and is called a 'Telescoping Tubing Quick-Release Button connector'.  The part numbers of note are 92988a650 and 92988a730.  Not sure if they would work but it is floating around in the mush between my ears.  [Laughing]  | 	  0123456789012345678901234
    567=                              -Matt Dralle, List Admin.[/b][/quote]http://www.matronics.com/con[/b]n277dl wrote:[/quote]8
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Fri May 30, 2008 7:22 am    Post subject: Re: removable co-pilot stick |
				 	  | msausen wrote: | 	 		  I didn’t seem to document this in my build log but what I ended up doing is using a recessed push button pin, much like what Linn described, on the pax stick.  Specifically it was a SS Recessed Push-Button Quick-Release, Mcmaster-Carr part number 92385A015.  With a 4600# shear strength I’m not overly concerned about it breaking.
 Michael   |
 Michael,
 What kind of clearance do you have with the head?
 On another slightly different subject, did you route your wiring through the curved part of the stick and then exit before the pin or were you able to route it past the pin/bolt, or did you go external all the way?
 I am wondering what most others are doing.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		msausen
