dlm46007(at)cox.net Guest
Posted: Thu May 29, 2008 10:11 am Post subject: Useable fuel |
what have flyers found to be the useable/unusable fuel in the 10? Any variability in the tank capacity?
bcondrey
Posted: Thu May 29, 2008 10:25 am Post subject: Useable fuel |
4.5oz unudsble in my left tank and 5oz unusable in my right tank. Tanks will hold 30 gallons easy with a little room available for expansion due to temp changes.
Bob N442PM flying
Tim Olson
Posted: Thu May 29, 2008 10:26 am Post subject: Useable fuel |
I don't consider this "safe" fuel levels, but useable is
everything it will hold, except for about 1/4 quart.
I flew both tanks dry, independently, and there was
maybe a cup of fuel or so out of each tank that I
could get out of the sump. It amazingly can use almost
everything in the tank. Of course, if you ran it that
low, any slip or maneuver you did would probably unport
the fuel inlet...so under 5 gallons I'd be really careful
for sure.
David McNeill wrote:
| Quote: | what have flyers found to be the useable/unusable fuel in the 10? Any
Posted: Thu May 29, 2008 11:25 am Post subject: Useable fuel |
Yes just checking. Landing without 5 in each tank would worry me.
Dave(at)AirCraftersLLC.co Guest
Posted: Thu May 29, 2008 11:53 am Post subject: Useable fuel |
We intentionally ran one tank dry in flight, and found what others are reporting. We refilled it with 30 gallons, as close as the pump could measure.
I've pumped each tank dry on the ground a couple times. Each time it left only a few ounces drainable from the sump. I'd say less than a cup.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
N921AC 136 hours
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, May 29, 2008 11:08 AM
Subject: Useable fuel
