Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Mon Jun 02, 2008 5:37 am Post subject: Where you guys buying transponders from.Boy they're expensiv |
I cannot go with the long ones. No panel space. I need the smaller profile, like Becker sells but everything is over a grand. I didn't realize they were so expensive. Can anyone help with the price......Thanks Geoff
Originally posted on 701 list but I should get more help from here until the 701 list grows more
"I introduced into my ears two metal rods with rounded ends and joined them to the terminals of the apparatus. At the moment the circuit was completed, I received a shock in the head and heard a crackling and boiling noise. This disagreeable sensation, which I feared might be dangerous, has deterred me so that I have not repeated this experiment."
-- Alessandro Volta
Every thing built…Working on the Electric City stuff. Getting myself educated. SLOW.
Rotax 80hp/Dynon D180/Garmin 296/Icom AC-A210/Dual controls
Gig Giacona
Posted: Mon Jun 02, 2008 5:44 am Post subject: Re: Where you guys buying transponders from.Boy they're expe |
Check out E-Bay. Add a e-mail alert for which ever models you are interested in. There have been some very good deals on non Mode S Xponders out of Europe since they have started requiring Mode S over there.
601XL Under Construction
notsew_evets(at)frontiern Guest
Posted: Mon Jun 02, 2008 8:19 am Post subject: Where you guys buying transponders from.Boy they're expensiv |
I installed the basic VFR instruments along with GPS and EIS. Came at over
$7K.
My 601 XL is pushing $53K...
Darn....
Gig Giacona
Posted: Mon Jun 02, 2008 10:12 am Post subject: Re: Where you guys buying transponders from.Boy they're expe |
What made up that $7K?
| notsew_evets(at)frontiern wrote: | I installed the basic VFR instruments along with GPS and EIS. Came at over
$7K.
Darn....
Posted: Mon Jun 02, 2008 11:40 am Post subject: Where you guys buying transponders from.Boy they're expensiv |
Becker transponder/mode C
XCOM radio
EIS
Compas
Altimeter
Airspeed
VSI
Data system for power/time/etc
fuel gauges
switcher
breakers
ELT
Misc jacks/plugs
more but I m brain dead just now....
Oh Garmin 296
Geoff Heap
Posted: Mon Jun 02, 2008 12:31 pm Post subject: Re: Where you guys buying transponders from.Boy they're expe |
OK that settles it. I'll pass on the Transponder. I'm not interested in IFR anyway. As long as I have a radio I can enter D class without one and C class with permission (and follow explicit ATC directions). I have no wish to enter A class at all
Posted: Mon Jun 02, 2008 1:10 pm Post subject: Where you guys buying transponders from.Boy they're expensiv |
It is more than just class C. It is the 30 nm radius mode C "veil". In my
case the edge of the Salt Lake City veil passes right through my home
airport. A reasonable summary of the regs can be read here:
http://members.eaa.org/home/homebuilders/operating/articles/No%20Radio%20No%
20Transponder%20Operations%20in%20Class%20D%20Airspace%20in%20a%20Mode%20C%2
0Veil.html?
(or as a tiny URL: http://tinyurl.com/68js8v )
-- Craig
Posted: Mon Jun 02, 2008 1:31 pm Post subject: Where you guys buying transponders from.Boy they're expensiv |
Airports that I frequent are inside the vail....
If you fly outside the vail yet above 10K, transponder is required.
Sport pilots dont need to worry unless inside the magical vail....
Posted: Mon Jun 02, 2008 1:53 pm Post subject: Where you guys buying transponders from.Boy they're expensiv |
Assuming you flying "sport pilot" ????
at or below 10K MSL, outside the mode C veil...........
rhansen16
Posted: Mon Jun 02, 2008 2:26 pm Post subject: Where you guys buying transponders from.Boy they're expensiv |
I would not skip the transponder because I enjoy flight following on cross countrys. Also if you are in an area like mine, the military aircraft have a better chance in seeing you. It is worth the investment.
Rob
_________________ Rob Hansen
http://websites.expercraft.com/rhansen/ |
Posted: Mon Jun 02, 2008 2:32 pm Post subject: Where you guys buying transponders from.Boy they're expensiv |
But the FAA proposed sport pilot rule change may modify the "above 10,000
ft" limit to be "above 10,000 ft or 2000 ft agl". Given where I live if this
change goes through I will commonly be a sport pilot flying above 10,000 ft
msl.
-- Craig
Geoff Heap
Posted: Tue Jun 03, 2008 8:44 am Post subject: Re: Where you guys buying transponders from.Boy they're expe |
Last word on the subject
It's back in. I gotta put the money out. Thanks for the advice. While waiting for responses I also queried EAA. Joe Norris wrote...
" Short answer: Yes, you’ll need one.
Longer answer: If your aircraft has an engine driven electrical system you are required to have a altitude reporting transponder anytime you are within the Mode C veil, even if you don’t plan to enter the class B airspace itself. "
Pretty cut and dried. Hope this helped other listers too....Geoff
