gord601(at)yahoo.ca Guest
Posted: Mon Jun 02, 2008 6:36 pm Post subject: Importing a 601 from Canada to the U.S. |
Hello,
I currently own a 601HD. It is registered as an advanced ultralight in Canada. Does anyone know if I can import this airplane into the U.S. I am moving to the U.S. and want to take my plane but may be forced to sell if it cannot be imported.
Gord
CH601 on amphibs rotax 914 turbo
[url=]Gord601(at)yahoo.ca[/url]
kar.fre(at)verizon.net Guest
Posted: Tue Jun 03, 2008 8:55 am Post subject: Importing a 601 from Canada to the U.S. |
My 601HD, Rotax 912 was built in Canada. You just have to go through the paper work and have the inspections. Sounds easy yes, there will be a time or two when you wonder what you are doing but it will all work out. Fred kar.fre(at)verizon ([email]kar.fre(at)verizon[/email])
cndmovn(at)gmail.com Guest
Posted: Tue Jun 03, 2008 10:47 am Post subject: Importing a 601 from Canada to the U.S. |
Karen: Was it registered as a homebuilt or Aula?
On Tue, Jun 3, 2008 at 12:51 PM, Karen Johnson <kar.fre(at)verizon.net (kar.fre(at)verizon.net)> wrote:
[quote] My 601HD, Rotax 912 was built in Canada. You just have to go through the paper work and have the inspections. Sounds easy yes, there will be a time or two when you wonder what you are doing but it will all work out. Fred kar.fre(at)verizon ([email]kar.fre(at)verizon[/email])
Posted: Tue Jun 03, 2008 11:45 am Post subject: Importing a 601 from Canada to the U.S. |
It was registered as experimental amateur built.
Posted: Tue Jun 03, 2008 11:54 am Post subject: Importing a 601 from Canada to the U.S. |
That I think is going to be the issue. The plane in question is registered as an advanced ultralight.
On Tue, Jun 3, 2008 at 3:42 PM, Karen Johnson <kar.fre(at)verizon.net (kar.fre(at)verizon.net)> wrote:
[quote] It was registered as experimental amateur built.
Gig Giacona
Posted: Tue Jun 03, 2008 12:44 pm Post subject: Re: Importing a 601 from Canada to the U.S. |
A call to the EAA at 888-EAA-INFO or its' Canadian counterpart would probably get you a solid answer.
| cndmovn(at)gmail.com wrote: | That I think is going to be the issue. The plane in question is registered as an advanced ultralight.
601XL Under Construction
