jareds(at)verizon.net Guest
Posted: Mon Jun 02, 2008 7:46 am Post subject: STalled |
The other day i was landing on the missouri river here in SD to fish and
had never pulled the flap handle all the way up when taking off.
Fortunately i had plenty of room but on a 80 degree day with thin air
the left wing stalled and i nearly wrecked had i not aborted the landing.
How does one know what "full flaps" are on the model IV and where is the
full flap setting?
Guy Buchanan
Posted: Mon Jun 02, 2008 12:40 pm Post subject: STalled |
At 08:40 AM 6/2/2008, you wrote:
| Quote: | How does one know what "full flaps" are on the model IV and where is
the full flap setting?
I set mine so maximum flap just allows full aileron travel both ways.
With this setting I've never had a premature stall.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Jun 02, 2008 2:06 pm Post subject: Re: STalled |
I put a stop on my flap handle at 20 degrees. I used an angle finder on the flaperon to find the 20 degree setting.
Edited: I think my answer is not what you were asking.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
gary.algate(at)sandvik.co Guest
Posted: Mon Jun 02, 2008 3:21 pm Post subject: Stalled |
I carried out some flap tests a few years ago and gradually increased the flap setting on approach from nil to full to see effects.
At full flap setting ie) handle up as far as it would go I didn't have any problems with a premature stall but found that when I touched down I couldn't get the tail top come down and I bounced along on the main gear a few times with the tail high in the air. The aileron movement was a bit restricted with the flaps full down.
Is their any chance that with full flaps you lifted off early and then stalled the wing once you were out of ground effect?
I have used full flaps on floats and wheels Take off and landing with no real problems however when I am landing I lift the flaps just before touch down on a short field approach - serves two purposes as it gives you better elevator authority once you lift the flaps and it also dumps lift so that you can land really short.
Gary
Gary Algate
Classic 4 Jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
jareds <jareds(at)verizon.net>
Sent by: owner-kitfox-list-server(at)matronics.com
03/06/2008 01:24 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
STalled
--> Kitfox-List message posted by: jareds <jareds(at)verizon.net>
full flap setting?
LarryM
Posted: Mon Jun 02, 2008 5:59 pm Post subject: Re: STalled |
I also.
[/quote]
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.[/quote]
kitfoxmike
Posted: Mon Jun 02, 2008 6:45 pm Post subject: Re: STalled |
At this point I'm going to have to disagree that the flap angle is what caused you to stall. I've taken off with full flaps and done correctly the airplane sort of just shoots up in the air and feels like it's level. You have to resist the urge to pull back on the stick, just let it lift off on its own, you might even have to push forward on the stick. the key here is NOT to lift off with a bunch of up angle on the wings, that will stall you. If you are in a float plane and want to get off sooner, you will need to cross control and lift one of the floats out of the water as well as keeping in ground effect until air speed allows for lifting off.
dave
Posted: Tue Jun 03, 2008 5:46 pm Post subject: Re: STalled |
Jared,
If the left wing stalled the pilot induced that stall not the flaps .
For the record mine go full down 33 degrees and they work awesome for takeoffs. For landing over 20 degree is of no gain and you will lose some aileron control.
| Quote: | How does one know what "full flaps" are on the model IV and where is the
full flap setting? |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
kirkhull(at)kc.rr.com Guest
Posted: Tue Jun 03, 2008 6:04 pm Post subject: STalled |
Another thing that could have caused the left wing to stall is improper
washout built into the wing and or it is out of rig
Posted: Fri Jun 06, 2008 7:02 am Post subject: STalled |
At this point i am leaning towards the fact that originally skystar
apparently had a sticker for flaperon handle that indicated an upper limit.
Full up on handle is just too far on a take off.
But a comment in one of the responses about the flaperons being "out of
rig" made me wonder.
If a flaperon is out of rig, wouldnt the plane drift or have a tendancy
to tip if they were not set evenly?
How about the twist of the wing?
Comments welcome.
Guy Buchanan
San Diego, CA
http://forums.matronics.com/viewtopic.php?p=185973#185973
[/quote]
MichaelGibbs(at)cox.net Guest
Posted: Fri Jun 06, 2008 7:33 am Post subject: STalled |
The construction manual details the procedure for rigging proper
flaperon travel. I have seen quite a few Kitfoxes that were not set
per the instructions or were done by other seat-of-the-pants methods.
You should get the instructions out and set them properly.
After I started flying mine I ended up making several adjustments to
the lift strut rod ends to get the wing twist right, independent of
the flaperon rigging.
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
| Quote: | At this point i am leaning towards the fact that originally skystar
limit.
of rig" made me wonder.
tendancy to tip if they were not set evenly?
dave
Posted: Fri Jun 06, 2008 1:11 pm Post subject: Re: STalled |
| Quote: | | Full up on handle is just too far on a take off. |
Says who? I can show you a full flap take off anytime that will get your weight from gear/floats to wings quicker that without full flaps. Mine go 33 Degrees down , some I understand set a limit to only 20 degrees down. The extra few degrees will make a huge difference. ASk any bushpilot or other experienced pilot he will tell you the same thing.
You wing stalled from too high of an angle off attack, sure there is the small amounts thast can be added up from washout, flapperon rigging etc but correct me please , who stalled the airplane ? The pilot or the airpane ? PIC is in charge ?
Dave
Michel
Posted: Fri Jun 06, 2008 11:03 pm Post subject: STalled |
Guys, I went for a few traffic pattern yesterday. I needed to check my radio/intercom with the nearby CTR tower. Anyway, since I read about the Kitfox flaps on this list, I thought I should try it. My flaps are adjusted to move only 10 degrees. I never use them because I don't see the point and I don't really like the feeling of it; it pulls the nose downward without really adding much drag. I always adjust speed and altitude with sideslips on final.
Anyway, I was on final with 10 degrees flaps and did a sideslip ... oops, it felt like my tail stalled! I am not sure and I didn't want to try again. Are you, guys, sideslipping with the flaps on?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
_________________ Kitfox 3 - Jabiru 2200 |
dave
Posted: Sat Jun 07, 2008 2:18 am Post subject: Re: STalled |
| Quote: | | Anyway, I was on final with 10 degrees flaps and did a sideslip ... oops, it felt like my tail stalled! I am not sure and I didn't want to try again. Are you, guys, sideslipping with the flaps on |
Yep !! I sideslip with 20 degrees down. That is the most i use for landing.
Remeber I have a model 4 which is an entire different control system that the Models 1,2 and 3 . They we not nearly as useful as the IV model.
Dave
Tom Jones
Posted: Sat Jun 07, 2008 6:46 am Post subject: Re: STalled |
| jareds(at)verizon.net wrote: | The other day i was landing on the missouri river here in SD to fish and
Jareds,
Here is a link that contains so good information on the theory and proceedures to rigging the Model 4 flaperons.
http://www.sportflight.com/cgi-bin/uploader.pl?action=main&category=Text/Articles
Classic IV
Ellensburg, WA |
7suds(at)Chartermi.net Guest
Posted: Sat Jun 07, 2008 7:33 am Post subject: STalled |
Michel,
I would pull about 30% flaps (not sure what that was in degrees) on my 4 and
do forward slips on final with no problems.
Lloyd C
Model 5 912
Northern Mi
Lynn Matteson
Posted: Sat Jun 07, 2008 8:49 am Post subject: STalled |
I am, Michel. I've done it with 10 and 20° (my plane's limit) of
flaps, but usually use only 10° if landing crosswind...I like a bit
more aileron availability in a crosswind. Did you maybe slip away
from the wind? I have to think my slip through before I do it, and
sometimes find myself putting the wrong wing down...quickly
corrected, of course. But then, mine is a Model IV, not 3.
Lynn
Kitfox IV Speedster w/Jabiru 2200 w/520+ hrs.
On Jun 7, 2008, at 2:58 AM, Michel Verheughe wrote:
| Quote: | Guys, I went for a few traffic pattern yesterday. I needed to check
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Jun 07, 2008 9:15 am Post subject: STalled |
From my experience, the most important aspect of rigging is to have
a digital inclinometer (level) or Smart Level, and those wooden
blocks that clamp around the flaperons. Then read and follow the
directions in the builder's manual. If you can't get the exact angles
called for....26° on the right side, and 32° on the left side,
according to my manual...they (Skystar via phone call way back when)
said to split the difference, that is, 27 and 31 for example, with
the 15049 bellcrank at 11.4 degrees from bottom of aircraft. This was
changed to 10 degrees in the later-published manual.
What limits my flap deflection is the length of the slot in the
console (I had to lengthen it a bit), and 20° is plenty of flap for
me and considered maximum for the Model IV, I read somewhere.
Lynn
Kitfox IV Speedster w/2200 Jabiru w 520+ hrs
On Jun 6, 2008, at 10:58 AM, jareds wrote:
upper limit.
"out of rig" made me wonder.
Comments welcome.
LarryM wrote:
> I also.
> ways. With this setting I've never had a premature stall.
> Guy Buchanan
> San Diego, CA
> quote]
[/quote]
N369LM |
Michel
Posted: Sat Jun 07, 2008 11:10 am Post subject: STalled |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Did you maybe slip away from the wind?
.. Er, what do you mean, Lynn? When I sideslip on final to either slow down or increase to sink rate, I push on the right pedal and push the stick to the left. That's what gives me the best view of the runway from the left-hand seat. The wind is usually ahead. Of course, in a crosswind, it's different. But ... I don't fly much in crosswind. My wife doesn't allow me!
Michel Verheughe
Lynn Matteson
Posted: Sat Jun 07, 2008 12:16 pm Post subject: STalled |
I always did the same thing...right pedal, and stick to the left,
until my instructor and I were on our dual x-country, and I did just
that, but the wind was from the right, and he grabbed the stick and
went right stick (right aileron down) and left pedal, explaining
"always put the wing down on the windy side." We had always slipped
with right pedal, left wing down, because it just happened that the
wind was always from the left when we needed to slip, and I got it
into my head that that was always the way to do a slip. But it turns
out that you have to figure where the wind is coming from before
deciding which way to slip. Better teach your wife the old saying:
"he who does not fly in crosswinds, does not fly often." (but don't
let it get into a family feud)
I feel more comfortable slipping R pedal, L aileron, but the wind
direction has the last say.
Lynn
On Jun 7, 2008, at 3:05 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
... Er, what do you mean, Lynn? When I sideslip on final to either
Michel Verheughe
</b></font></pre>
N369LM |
Michel
Posted: Sat Jun 07, 2008 1:27 pm Post subject: STalled |
Oh but I agree, Lynn! I also side slip always with the wing low in the wind, if it comes from the side. The R pedal, L aileron is only when the wind is in the axis of the runway. Incidentally my wife sends her regards and say that I am not allowed to listen to other men!
Seriously, I wonder why I felt that strange feeling that my tail was stalling with the flaps on. There wasn't much turbulence that day but, sometimes, there is a bump on final as we fly over a row of trees. Could have been just a coincidence. Still, I'll try again but this time at high altitude.
I couldn't fly today and probably not tomorrow either. The reason is silly: The nearby CTR tower we need to call before take-off has one operator sick and because of that, they don't allow any GA flying. The operator has a hard job: about 20 commercial arrival/departure in 16 hours ... what a stress!
Michel Verheughe
Norway
