CJohnston(at)popsound.com Guest
Posted: Thu Jun 05, 2008 8:32 pm Post subject: wire tying inside conduit? |
Here's a funny question that I've been asking myself this afternoon... when you run wires inside a conduit (under the rear floors, etc) do you need to tie them up together before you run them through? you know, with zip ties or wire lacing tape? Seems like overkill, but i can't help but think about wires flopping around in there. what say you all?
cj
Posted: Thu Jun 05, 2008 8:46 pm Post subject: wire tying inside conduit? |
Chris Johnston wrote:
| Quote: | Here's a funny question that I've been asking myself this afternoon... when you run wires inside a conduit (under the rear floors, etc) do you need to tie them up together before you run them through? you know, with zip ties or wire lacing tape? Seems like overkill, but i can't help but think about wires flopping around in there. what say you all?
No ties within the conduit. They won't really flop around ..... and if
they do, you've got more important things to worry about .
Lacing up bundles of wires serves to make a neater installation instead
of looking like someone tossed spaghetti behind the panel . It also
serves to keep the wires from moving around and creating fatigue cracks
in the wires where the crimped lugs or soldered connections are. Being
contained inside a conduit is best looked at like a loose-tied bundle.
Deems Davis
Posted: Thu Jun 05, 2008 9:05 pm Post subject: wire tying inside conduit? |
CJ, I would definitely NOT tie the wires within the conduit. Having just
gone through the exercise of running additional wires in an already
'full' conduit, the ties would make installing the new wires difficult
to impossible.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
cj
Posted: Thu Jun 05, 2008 9:56 pm Post subject: wire tying inside conduit? |
Deems Davis wrote:
just gone through the exercise of running additional wires in an
already 'full' conduit, the ties would make installing the new wires
difficult to impossible.
And the same for removing one!!!
Linn
Deems Davis # 406
> cj
AirMike
Posted: Sun Jun 08, 2008 4:33 pm Post subject: wire tying inside conduit? |
Secure them at the ends with a cushion clamp or a bit of RTV after you put a bit of tension on the wires. The kinks and bends in the conduit will keep the wires from jumping around with a bit of tension on the ends. Like deems said don't look for trouble.
Also if you are concerned, always add an extra #18-22 wire to provide for any future add-ons.
_________________ OSH '10 or Bust
Q/B - finally done |
