Kelly McMullen
Posted: Thu Jun 05, 2008 6:35 pm Post subject: Almost a Builder |
Tail Kit order was faxed to Vans today, so I suppose I'll have a
builder number shortly and start worrying about picking up the kit and
inventorying it. Looking forward to it.
A&P/IA, EAA Tech Counselor
KCHD |
Kearney(at)shaw.ca Guest
Posted: Thu Jun 05, 2008 7:47 pm Post subject: Almost a Builder |
Kelly
6nbsp;
Welcome to the dark side E I guess I 7ll have to rat you out to the Piper list E E E
6nbsp;
Cheers
6nbsp;
Les
pascal(at)rv10builder.net Guest
Posted: Thu Jun 05, 2008 8:16 pm Post subject: Almost a Builder |
I doubt you'll worry too much about the pick-up but I assure you there will
be moments you will worry when building, but don't worry than either since
this forum is a great resource for all those perplexing steps.
Make sure you pay attention in the empennage because the instructions get
less detailed in the wings and even more so in the fusellage. THAN you'll be
worrying about steps you come across that the plans don’t even mention.
It will be a great experience, enjoy the journey of building it has been a
real blessing for me so far and I trust it will be equally satisfying for
you.
Pascal
Sent: Thursday, June 05, 2008 7:32 PM
Subject: Almost a Builder
Kellym
Thanks. Turnabout is fair play. Some of them already know about it.
Heck, John Galban was Doug Peterson's "rivet boy" while Doug was
building his -10.
Tool kit from Isham is due in Sat or Mon.
LES KEARNEY wrote:
[quote] Kelly
Welcome to the dark side. I guess I'll have to rat you out to the
Piper list...
Cheers
Les
KCHD |
Bldgrv10450(at)comcast.ne Guest
Posted: Thu Jun 05, 2008 10:13 pm Post subject: Almost a Builder |
Good news Kelly,
Welcome aboard. You will love building the RV10.
Are you planning to will call your order?
Paul Grimstad
RV10 450
Portland, Or.
Jack.Phillips(at)cardinal Guest
Posted: Fri Jun 06, 2008 3:28 am Post subject: Almost a Builder |
Ah, Kelly - your life will never be the same.
Jack Phillips
#40610
Wings (slow build)
jeff(at)westcottpress.com Guest
Posted: Fri Jun 06, 2008 7:47 am Post subject: Almost a Builder |
It'll be kind of like having kids... the best/worst thing you've ever
done...
Jeff Carpenter
40304
Metal Work Almost Done
On Jun 5, 2008, at 7:32 PM, Kelly McMullen wrote:
Posted: Fri Jun 06, 2008 6:30 pm Post subject: Almost a Builder |
Welcome aboard.
The tool kit I got from Isham a couple of years ago turned out to be a
good one. The only waste was some rivet tape that looked it should be
used on a 747.
building his -10.
LES KEARNEY wrote:
> Kelly
> Piper list...
> Cheers
> Les
