cutting holes in the firewall
rv10(at)sinkrate.com
PostPosted: Fri Jun 13, 2008 12:30 pm    Post subject: cutting holes in the firewall Reply with quote
I am wondeing what methods people used to cut holes in their firewall. I’ve seen some pretty bunged up holes and some real clean ones. I’m interested in knowing how to make “clean ones” in case that wasn’t clear. I doubt a unibit cuts them very cleanly and I imagine the stainless toasts them quickly. Are there punches that work better and where did people buy them if so? Harbor Freight has a cheap set but I don’t know if it works on stainless very well. I need to punch the holes for the battery cable and the throttle/prop/mixture.
Ben Westfall
#40579
PDX
msausen
PostPosted: Fri Jun 13, 2008 1:01 pm    Post subject: cutting holes in the firewall Reply with quote
Actually the type of stainless in our firewalls isn’t too bad to drill. I use regular drill bits and step bits in mine without a problem. Only way you are going to get extremely clean holes are with lots of patience, a punch tool like used for panels, or a CNC machine. I think you will find the normal methods to be just fine though.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall
Sent: Friday, June 13, 2008 3:25 PM
Subject: cutting holes in the firewall
Ben Westfall
#40579
PDX
; - The RV10-List Email For --> http://www.matronics.bsp; - MATRONICS WEB http://forums.matronics.com</==================[/b]
=   -Matt Dralle, List Admin.[/b][/quote]http://www.matronics.com/con[/b] [b]
davelammers(at)mchsi.com
Ben,
The set from HF works great on the FW SS. I used it on mine. Made two nice holes.
Dave Lammers
Forever Finishing.
Ben Westfall wrote: [quote]
Ben Westfall
#40579
PDX
Tim Olson
PostPosted: Fri Jun 13, 2008 2:24 pm    Post subject: cutting holes in the firewall Reply with quote
My unibit holes weren't all I wanted them to be. I think greenlee
punches would be great for the job. If I were doing it again I'd
check out the harbor freight punches and at least give that a shot
first. But, a unibit will do OK if you're willing to do some heavy
deburring.
Ben Westfall
#40579
PDX
rnewman(at)tcwtech.com
PostPosted: Fri Jun 13, 2008 3:05 pm    Post subject: cutting holes in the firewall Reply with quote
I have greenlee punches and some high quality uni-bits, I found that hands
down the uni-bit was the way to go. With the punches, at the very end of
pulling the punch through the metal the slug would get bound up between the
punch and the die. With the uni-bits I found the secret to success was
drilling a little at a time from both sides. This would keep the burr
from getting very big, the result was very clean accurate holes.
-Bob Newman
TCW Technologies
www.tcwtech.com
Tim Olson
PostPosted: Fri Jun 13, 2008 3:25 pm    Post subject: cutting holes in the firewall Reply with quote
I think you're definitely right there about drilling from both
sides. My holes were good other than that big burr. But, my
major mistake was letting 2 unibit holes touch....once they
hit eachother, it was all down hill from there. I had to
cut out the area and rivet in a stainless patch with fresh
holes drilled in it.
hands down the uni-bit was the way to go. With the punches, at the
very end of pulling the punch through the metal the slug would get bound
up between the punch and the die. With the uni-bits I found the
secret to success was drilling a little at a time from both sides.
This would keep the burr from getting very big, the result was very
-Bob Newman
TCW Technologies
www.tcwtech.com
AV8ORJWC
PostPosted: Fri Jun 13, 2008 5:06 pm    Post subject: cutting holes in the firewall Reply with quote
Ben, I have the Harbor Freight punches (which you are welcome to borrow) and found them inferior on aluminum. At work, we use a hydraulic punch which I might be able to borrow.
the unibit and possibly multiple are the best bet for 10 builders. Sharing the size and locations with future builders would allow them to use other techniques before the wall is installed.
John Cox
#40600
PDX - UAO
Sent: Friday, June 13, 2008 1:25 PM
Ben Westfall
#40579
PDX
[quote] [/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b]http://forums.matronics.com[/b]http://www.matronics.com/contribution [b]
ricksked(at)embarqmail.co
PostPosted: Sat Jun 14, 2008 5:01 am    Post subject: cutting holes in the firewall Reply with quote
