rowil(at)clara.net Guest
Posted: Mon Jun 09, 2008 2:04 pm Post subject: rudder pulley access holes in cockpit module |
I'm just starting to highlight the trimming lines on the cockpit
module with a fine felt-tip pen so I can see where to cut.
I'm puzzled by the marks on the starboard side of the centre tunnel,
at the side of the seat area. My printed manual does not identify any
individual holes, but the PDF manual from the factory website marks
it and the corresponding one on port as "rudder pulley access holes".
The approximately-horizontal flanges on which they appear are
asymmetrical - wider on the starboard side than the port. The port
side hole is clearly outlined and also cross-hatched. On the
starboard side are 2 oval areas about the same size and slightly
overlapping. The outboard one is cross-hatched and the inboard one is
not.
Do I cut out just the hatched one, or just the unhatched one?
My guess would be only the hatched one, as it appears to be in about
the same relationship to the seat-pan as the port one. The central
narrow part of the tunnel is veering off to port as it reaches the
seat-back and that is what makes the starboard flange wider there,
and I assume the rudder pulleys are located equidistant from the
centreline or from the outside edge of the fuselage/cockpit module -
thus the outboard (hatched) outline is the one that's needed. Perhaps
the inboard position was marked in error and both correct ones have
been hatched to better identify them.
Roger at the factory says he thinks it should be the hatched one, but
does anyone know any better before I start cutting?
regards
Rowland
| Wilma & Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
fklein(at)orcasonline.com Guest
Posted: Mon Jun 09, 2008 6:44 pm Post subject: rudder pulley access holes in cockpit module |
On Monday, Jun 9, 2008, at 15:00 US/Pacific, Rowland Carson wrote:
| Quote: | The approximately-horizontal flanges on which they appear are
side hole is clearly outlined and also cross-hatched. On the starboard
side are 2 oval areas about the same size and slightly overlapping.
The outboard one is cross-hatched and the inboard one is not.
seat-back and that is what makes the starboard flange wider there, and
Rowland,
Though I can no longer see the hairlines indicating the access hole
locations, you are correct in reasoning that the holes want to be in
the same relationship to the seat flanges, NOT in the same
relationship to the central narrow part of the tunnel which I
mistakenly used when I made my initial cuts. (Easily remedied w/ a
small patch and some 5 min. epoxy.) Take the starboard side as a guide
and duplicate it on the port side and you'll be good to go.
Fred
believed to be clean.
g-iani(at)ntlworld.com Guest
Posted: Tue Jun 10, 2008 1:51 am Post subject: rudder pulley access holes in cockpit module |
I remember my tunnel was confusingly marked. I think it was the hatched
one. The logic is can you get a spanner on to the pulley nut via the
hole.
Something to think about is the need to make removable covers for these
holes. You do not want you favourite pen falling into the pulley
wheels.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
