Boost pumps
Dennis Jones
PostPosted: Wed Jun 11, 2008 8:06 pm    Post subject: Boost pumps Reply with quote
In the information you sent on the smoke pump wiring, you showed the ground being switched and the positive going directly to the pump. Should the electric fuel be wired the same way?
Jonsey
PostPosted: Thu Jun 12, 2008 5:23 pm    Post subject: Boost pumps Reply with quote
[quote]Jonsey,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> How many fuel pumps do you have and where are they located? Are there two batteries with alternate feed paths to the fuel pump(s)? Is there an engine driven fuel pump? Or is it gravity fed with an electric boost pump? Joe G.[b]
Joe Gores
Dennis Jones
PostPosted: Thu Jun 12, 2008 7:12 pm    Post subject: Boost pumps Reply with quote
One electric backup pump, one battery with one feed. Pump on pump off no solenoid.
Jonsey
PostPosted: Fri Jun 13, 2008 4:17 am    Post subject: Boost pumps Reply with quote
You can switch either the hot wire or the grounded wire. The fuel pump doesn't care. One method might have an advantage over the other as far as the length of the wires (weight) goes, and thus the length of hot wire exposed to possible short circuits. As long as the hot wire is protected by a fuse and is protected against mechanical damage, it will not matter much how the fuel pump is switched.
Joe G. [quote][b]
Joe Gores
Dennis Jones
PostPosted: Fri Jun 13, 2008 8:24 am    Post subject: Boost pumps Reply with quote
Thanks Joe
I did find that with the smoke pump it took less wire and the hot wire is considerably shorter. I will look at this situation knowing either way would work.
Jonsey
