TELEDYNMCS(at)aol.com Guest
Posted: Tue Jun 10, 2008 3:46 am Post subject: Lightning bonding |
In a message dated 6/10/2008 3:00:42 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
Quote: | Before I head off to Asia, I plan to put aluminium mesh right along
the aileron and flap close outs joining to the rear lift pin to allow wing
tip to wing tip lightning travel |
Hi David,
FWIW, my wife and I had lightning strike very near us while flying our Ximango last summer on a 500K attempt. We were deep in a drought here and it hadn't rained in 4 months. The lift was fantastic for this area during this time, i.e, greater than 10 knots to going to 10,000'+ agl every day. I had been flying long cross country flights every day for about 3 weeks, including several successful 500k attempts. There had not been even a hint of weather overdevelopment during that time. We were about 300K into the attempt and were approaching a nearby gliderport that was our last turnpoint for the final home run leg to complete the 500K. There was a fairly large storm about 20 miles away, but we were in clear air between puffy, friendly cumulus clouds at about 9000'. We were gliding along engine off�at about 80 knots between thermals when a lightning bolt struck right out in front of us out of clear blue sky. I'd always heard that this could happen, but I'd never witnessed it first hand. We saw where it hit the ground and where that was in relation to our turn point. According to the GPS and our observation, the lightning was no more than 1/4th of a mile or so in front of us. The flash and the resulting boom were almost simultaneous. Needless to say it got our attention. I immediately aborted the course in an abrupt 90 degree wingover and proceeded to put as much distance between us and that storm as possible. The rest of the flight was uneventful. Whether or not we triggered the strike is unknown. It didn't hit us and there was no damage to the aircraft. I probably hyper-extended my sphincter muscle, though.
After we returned to my strip I began to wonder if the Ximango was bonded. So, I started inspecting. Turns out that Aeromot did bond virtually every metal surface in the aircraft together. They used fairly heavy gauge braided jumpers made from tinned copper to tie everything metal together to prevent arcing. I'm considering doing the same to my Europa.
I certainly give thunderboomers a much wider berth these days.
John Lawton
Whitwell, TN (TN89)
N245E - Flying
Vote for your city's best dining and nightlife. City's Best 2008.
fklein(at)orcasonline.com Guest
Posted: Tue Jun 10, 2008 6:04 am Post subject: Lightning bonding |
On Tuesday, Jun 10, 2008, at 04:43 US/Pacific, TELEDYNMCS(at)aol.com wrote:
Quote: | They used fairly heavy gauge�braided jumpers made from tinned
copper�to tie everything metal�together to prevent arcing.
Nice, thoughtful post John...thanks...If you locate a source for this
braided jumper material, spread it around...I've known there was a
reason I haven't closed my wings yet...Fred
believed to be clean.
carl(at)flyers.freeserve. Guest
Posted: Tue Jun 10, 2008 7:35 am Post subject: Lightning bonding |
Not sure thats a terribly good idea.
The lightning will take the path of least resistance and probably travel through the aileron push rods and accross the fuselage (where the control rods pass within an inch of the fuel tank !!!!) If the current is high enough, the alloy pushrods will melt like a piece of fusewire.
If you dont believe me, read this. It is a sobering story - The Dunstable glider lightning strike.
Not sure if there is an easy solution.
christoph.both(at)acadiau Guest
Posted: Tue Jun 10, 2008 7:43 am Post subject: Lightning bonding |
Time to take chutes up again like glider pilots do...
Best,
Christoph Both
#223
Wolfville, Nova Scotia Canada
wdaniell(at)etb.net.co Guest
Posted: Tue Jun 10, 2008 8:48 am Post subject: Lightning bonding |
Displaying my ignorance yet again could somebody explain the principle involved?
I am assuming that the lightning needs a conductive path to travel into, through and out the other side of the aircraft. Is this correct? Any gaps will acts as a giant spark plug gap and cause structural damage??
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of TELEDYNMCS(at)aol.com
Sent: Tuesday, June 10, 2008 06:44
Subject: Lightning bonding
[i]the aileron and flap close outs joining to the rear lift pin to allow wing
tip to wing tip lightning travel[/i] |
Hi David,
FWIW, my wife and I had lightning strike very near us while flying our Ximango last summer on a 500K attempt. We were deep in a drought here and it hadn't rained in 4 months. The lift was fantastic for this area during this time, i.e, greater than 10 knots to going to 10,000'+ agl every day. I had been flying long cross country flights every day for about 3 weeks, including several successful 500k attempts. There had not been even a hint of weather overdevelopment during that time. We were about 300K into the attempt and were approaching a nearby gliderport that was our last turnpoint for the final home run leg to complete the 500K. There was a fairly large storm about 20 miles away, but we were in clear air between puffy, friendly cumulus clouds at about 9000'. We were gliding along engine off at about 80 knots between thermals when a lightning bolt struck right out in front of us out of clear blue sky. I'd always heard that this could happen, but I'd never witnessed it first hand. We saw where it hit the ground and where that was in relation to our turn point. According to the GPS and our observation, the lightning was no more than 1/4th of a mile or so in front of us. The flash and the resulting boom were almost simultaneous. Needless to say it got our attention. I immediately aborted the course in an abrupt 90 degree wingover and proceeded to put as much distance between us and that storm as possible. The rest of the flight was uneventful. Whether or not we triggered the strike is unknown. It didn't hit us and there was no damage to the aircraft. I probably hyper-extended my sphincter muscle, though.
John Lawton
Whitwell, TN (TN89)
N245E - Flying
Checked by AVG.
08-Jun-08 17:32
Checked by AVG.
08-Jun-08 17:32
pete(at)lawless.info Guest
Posted: Tue Jun 10, 2008 9:32 am Post subject: Lightning bonding |
The problem is that the Europa is made of Tupperware so there is no metal skin for the electricity to flow through, hence it is possible for it to flow though the aileron push rods or the elevator push rod and possibly vapourise them in the process. Some glass aeroplanes have a metal or carbon mesh built into the structure to conduct the lightning around the outside. There was a glider over Dunstable a couple of years ago that had a wing literally blown apart by the effect of a lightning strike.
Pete
Posted: Tue Jun 10, 2008 11:23 am Post subject: Lightning bonding |
Thanks that explaines it. Hope they were wearing a parachute.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Pete Lawless
Sent: Tuesday, June 10, 2008 12:27
Subject: RE: Lightning bonding
Pete
-----Original Message-----
Checked by AVG.
08-Jun-08 17:32
rampil
Posted: Tue Jun 10, 2008 12:06 pm Post subject: Re: Lightning bonding |
Lightning and composite a/c are just a bit more complicated than the
discussion so far suggests:
wing mesh is more useful for static dissipation rather than lightning
protection. Static dissipation is important to assure your Nav/Comm
works in the clouds. The reason it does not work for lightning is that the
tiny conductors of a mesh will melt, or vaporize explosively if hundreds
to thousands of Amps pass through. You can't put enough metal into
a composite a/c to safely conduct a direct lightning strike. Even metal a/c
burn through at the points of entry and exit where the current density is
highest. The same applies to bonding straps to control surfaces - for
conduction of and reduction of microamps of static charge, not lightning protection.
Posted: Tue Jun 10, 2008 1:51 pm Post subject: Lightning bonding |
They were and both lived to tell the tale. The lad in the back seat got burns to his neck.
Posted: Tue Jun 10, 2008 2:14 pm Post subject: Lightning bonding |
Fred & al, As I see it the problem with bonding aileron push rods is that
they don't go to the end of the wings.Ideally I think you need a conductor
that extends to the wing tips and also possibly one that is not inside the
wing cavity. In the quoted glider incident (which happened in 1999 at
Northall, just North of London, CAA occurrence no. 199902166) the heat
generated by the lightning arcing through the wing surface to the control
runs was thought to be enough to massively expand the contained air and blow
the wing skins off. There is a caveat however to basing too much on that
incident as investigation showed that the power of that particular lightning
bolt was exceptional, in fact seven times higher than the power that
certified aircraft are designed to withstand. Nevertheless I like the notion
of a conductor that isn't connected to the bit I am holding, and feel there
is a good chance of the aluminium mesh in the close out approach conducting
lesser bolts straight through without giving me or my avionics a nasty
shock!
As an amusing postscript to the glider story the passenger in the 2
seat glider was having a trial flight. As he hadn't had his money's worth
the club offered him a free repeat, but he is said to have declined!
Regards, David Joyce, G-XSDJ
Posted: Tue Jun 10, 2008 2:28 pm Post subject: Lightning bonding |
So they managed to jump?
Posted: Wed Jun 11, 2008 4:10 am Post subject: lightning bonding |
In a message dated 6/11/2008 3:03:20 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
Quote: | Not sure thats a terribly good idea. |
Hi Carl, et al,
Apparently, the FAA and Aeromot think it is a good idea. The Ximango is a certified aircraft, has aluminum fuel tanks and they, too, are bonded to the rest of the metallic parts in the aircraft. In their parts manual, Aeromot refers to these bonding straps installed as "lightning bonding."
As it has been explained to me by our resident composite Guru here at the 'Possum Werks, what happens in composite airplanes in a lightning strike to make them explode is the super heating of residual moisture that is trapped within the layers of epoxy and cloth at the time of manufacture. When the strike passes through the composite, trapped moisture rapidly heats, expands and the structure comes apart explosively.
Having designed, installed and tested lightning protection systems on over 7000 cellular telephone sites, I've seen this phenomenon quite a bit with fiberglass antenna masts on poorly grounded sites. When a cell antenna takes a direct hit it explodes. The tower can take a direct hit and only slight discoloration will result. The result of an exploded antenna mast is similar to what you see after one of those exploding cigars goes off. If the site is properly grounded and bonded, this almost never happens, though.
What you are trying to do with bonding metallic parts in a plastic airplane is give the lightning a low resistance path to pass through and exit the airplane so that it doesn't take a high resistance (i.e., through the composite) path to exit and destroy the airplane. Low resistance is the key here. By providing a low resistance path for the lightning to pass though you reduce or eliminate the instantaneous heating that occurs in high resistance paths during a discharge. You also want to prevent arcing that would occur at loose metallic fittings, such as rod ends and any metallic parts that are bolted together. These are points of high resistance and arcing (and welding) can result. What you are doing here is making all the metallic parts equal in resistance, therefore equal in potential when charged. Ohm's law at work. I've heard of more than one occurrence of gliders that did not have bonded control systems being struck in flight and having their control rods welded to the point where the aircraft was no longer controllable and the occupant(s) were forced to bail out.
These bolted connections are precisely where the bonding straps are installed on the Ximango. The bonding straps that are installed, given their size, are designed to take a lot more current than a simple static discharge. They are essentially the same thing we install to bond and protect towers, transmission equipment, batteries, fencing, coax, antennae, etc., in cell sites from lightning. The reason braided cable is used is surface area. The more surface area, the more current it can handle. Braided cable has much, much more surface area than typical Tefzel aircraft wire or a solid wire, thus more current handling capacity.
Is it a cure all? No. There is no such thing as perfect lightning protection. Will it help save your bacon in a residual discharge situation? Probably. Will it save your bacon in a direct hit? Probably not.
Fred, as far as a source on the bonding straps, try Harger. www.harger.com. If it has anything to do with lightning protection, Harger carries it.
Hope it helps!
John Lawton
Whitwell, TN (TN89)
N245E - Flying
