		jeff(at)westcottpress.com Guest
				 Posted: Fri Jun 27, 2008 1:15 pm    Post subject: Cabin Floor Panels |
				I'm at the point of riveting in the cabin floor panels and wonder if
 I should hold off for any antennae or electrical run considerations.
 What say you?
 Jef Carpenter
 40304
		wcurtis(at)nerv10.com Guest
				 Posted: Fri Jun 27, 2008 1:49 pm    Post subject: Cabin Floor Panels |
				No reason I see to hold off.  You can put the transponder antenna in the tunnel and for any belly antenna, they are typically located under the rear seats / baggage area.
 William
 http://nerv10.com/wcurtis/08fuselage/index35.html
		daveleikam(at)wi.rr.com Guest
				 Posted: Fri Jun 27, 2008 8:05 pm    Post subject: Cabin Floor Panels |
				Jeff,  nothing under the floors for me.  Never even removed them from the
 QB.
 I mounted two commant antennas and ran conduit under the rear baggage floors
 similar to Tim Olson and Deems Davis.  Then bought an air blind rivet gun
 and locked 'em all down.
 PS - It's much warmer here now.
 Dave Leikam
 #40496  N89DA (Reserved)
 Muskego, WI
