Dimmer trick
trigo(at)mail.telepac.pt
PostPosted: Sun Jun 22, 2008 4:12 am    Post subject: Dimmer trick Reply with quote
Listers
I completed my instrument lights circuit, in which I have a dimmer, and all works OK.
Nevertheless, when I tested it at night (still at my garage) I noticed that there are a couple of instruments (e.g. the Trutrak ADI) which have a brighter light than the others, and obviously the single dimmer, operating all lights simultaneously, doesn’t get me an optimal dimming position for all lights at the same time.
Is there a trick to obtain similar brightness in all lights?
Can that be achieved by simply installing resistors in the brighter ones?
Carlos
nuckolls.bob(at)cox.net
PostPosted: Sun Jun 22, 2008 4:43 am    Post subject: Dimmer trick Reply with quote
At 01:08 PM 6/22/2008 +0100, you wrote:
Listers
all works OK.
all lights simultaneously, doesn t get me an optimal dimming position for
Whatever you want to try is fair game. While heading
the electrical avionics group on the GP-180 at Lear,
I crafted a specification for a 4-channel panel dimmer
that featured separate dimming curves for incandescent,
EL, gas discharge and LED lighting. We were able to
make the entire suite of technologies track each other
from one knob.
It's not a trivial task and many builders install
separate dimmers for each technology. Setting
up cockpit lighting was probably the worst job
any electron-herder could contemplate for a
complex TC aircraft back then. We had a real
witches brew of technologies and every program
manager, test-pilot and vp of engineering had
his/her own idea of how things should work.
No matter what you did, somebody was less than
thrilled about it.
( -Thomas Paine 1776- )
rv9jim(at)juno.com
PostPosted: Sun Jun 22, 2008 5:28 am    Post subject: Dimmer trick Reply with quote
Carlos,
The ADI Tru Trak instrument has a seperate dimmer circuit inside
it. It requires a seperate 12v input to make it work. If I remember, by
applying the 12v to this wire, it dims the lighting on the instrument. I
added a seperate mini toggle along side the instrument that says "dim".
Check your wiring schematic for the ADI and I think you will find the
input required. I havn't used it as I'm just about to do my first
flight. Its been at the airport for about two months while I "put it
together" for the last time so I can not tell you how it worked.
Jim Nelson
N15JN
RV9-A
The Two Coreys-New Season
Child Stars. Adult Issues. New season of the Two Coreys airs Sundays 1
http://thirdpartyoffers.juno.com/TGL2141/fc/JKFkuJi7WQr3rI2jU1sRgD264LX2qc79rxhctcWIsJha9dEa2CfXwV/
plaurence
PostPosted: Sun Jun 22, 2008 1:42 pm    Post subject: Dimmer trick Reply with quote
Carlos,
Try this site.
http://www.a-and-t-labs.com/products.htm
Peter
RV9A N60PL
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Sunday, June 22, 2008 8:08 AM
Subject: Dimmer trick
Listers
Carlos
Peter Laurence
RV9A Fuse
N601RT
PostPosted: Mon Jun 23, 2008 2:58 pm    Post subject: Re: Dimmer trick Reply with quote
Carlos,
My ADI is on a dimmer circuit with several NuLites and an internally lit Garmin GI-106A. The ADI was initially too bright relative to the other instruments. I moved the dimmer wire from the +12V dimmer input (pin 3) to the +24V dimmer input and found the 'balance' and tracking between the ADI illumination and the illumination of the other instruments on the circuit to be much better. This does require having max brightness during the day for reading the ADI display.
Roy
N601RT: CH601HDS, nose gear, Rotax 912ULS, All electric, IFR equipped, 990hrs
longg(at)pjm.com
PostPosted: Fri Jun 27, 2008 6:06 am    Post subject: Dimmer trick Reply with quote
I have another dimmer question that can be described in the same thread. Last night I installed the B & C 1.5 A dimmer which went off as described in the instructions.
After adding power, my panel dimmed as expected but the dimmer knob control (rheostat) seems to have very limited variability. Turning the knob all the way left turns off the panel lights as expected. Turning it very slowly for the first 1/8 inch turns the lights from completely off to everything in between and then full on. How can I modify the sensitivity such that the dimming effect works throughout the full range of the dimmer switch?
Glenn
mprather(at)spro.net
PostPosted: Fri Jun 27, 2008 7:10 am    Post subject: Dimmer trick Reply with quote
Sounds like the devices on the bus are drawing a smaller amount of current
than the dimmer circuit was intended to control. If you're only driving
LED's and the dimmer circuit was designed to support incandescent bulbs, I
could see this happening.
It could be something as simple as being at the end of the range for the
potentiometer (the thing the knob is controlling) in the dimmer circuit.
If this is the case, you might swap the pot for one with a more
appropriate range (lower peak resistance). Or possibly you can put a
bypass resistor across the pot - while still getting adequately dark. Or,
swap out some of those super efficient LED's for a couple of hog-heater
light bulbs. Smile
You could talk with B&C about what to do - product support.. It would be
a bit surprising if they haven't run into this before.
Matt-
[quote] I have another dimmer question that can be described in the same thread.
Glenn
longg(at)pjm.com
PostPosted: Mon Jun 30, 2008 6:06 am    Post subject: Dimmer trick Reply with quote
Matt,
I did some checking against the diagram which provides very
ambiguous instructions based on the 9 pin connector. I had one of the
potentiometer wires switched with the power lead. All better now.
