kitfoxnick
Joined: 13 Apr 2008 Posts: 33 Location: Northern Maryland
Posted: Sun Jun 22, 2008 9:55 am Post subject: Rudder seems stiff |
I bought my kitfox at the end of April. The plane had low times and was finished back 1996 so it sat more than flew. I decided to replace the fuel lines firewall forward new carb boots. I replaced the gsc with a warp drive. A friend of mine who owns a model IV flew the five hours off on the new prop as I don't have my license yet. Yesterday was my 1st flight it and seems that the rudder is really stiff at cruising speed. The rudder and stabilizer is not the airfoil style and is not gap sealed. My friend who's plane has the speedster tail said his rudder is alot easier than mine.
It seems that the rudder pedals would fatigue with this much pressure as these are the older style that have not been gusseted. What is the best remedy? I would like to make the rudder input easier. Or should I just deal with as this is normal. I really appreciate this forum and your guys expertise.
Thanks again,
Nick
_________________ Nick Weiskopf
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
kitfoxmike
Posted: Sun Jun 22, 2008 10:14 am Post subject: Re: Rudder seems stiff |
You can gap seal just like the elevator. 2" tape stuck on top of each other then put along one side, slide into the gap and then stuck on the other side, make sure the rudder is pulled to one side before doing the final stick. Closing the gap will ease up the force applied to the peddles.
Lynn Matteson
Posted: Sun Jun 22, 2008 10:18 am Post subject: Rudder seems stiff |
Are the rudder pedals stiff when operating on the ground with the
tailwheel off the ground? You might look for stiff bearings at the
rudder hinge, or misaligned rudder bearings...if the rudder bearings
don't all line up with each other, that condition will require high
input force. Also, make sure that the rudder pedal bushings are
free...you can lube them up nicely when you have them out for
installation of the gussets. You ARE going to gusset them, aren't you?
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/530 hrs
On Jun 22, 2008, at 1:55 PM, nick4853 wrote:
Thanks again,
Nick
kitfox !V-1200
Rotax 912ul
http://forums.matronics.com/viewtopic.php?p=189084#189084
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kitfoxnick
Posted: Sun Jun 22, 2008 12:11 pm Post subject: Re: Rudder seems stiff |
I haven't raised the tail and tried it, I'll try tomorrow. It taxis with less effort than at cruise. It has 103 hrs on it with no sign of fatigue But yes I am going to gusset the post and cable attachment.
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
Guy Buchanan
Posted: Sun Jun 22, 2008 4:42 pm Post subject: Rudder seems stiff |
At 10:55 AM 6/22/2008, you wrote:
| Quote: | It seems that the rudder pedals would fatigue with this much
Doesn't sound like it's normal, according to the other guy. Try:
1. Gusset the rudder pedals. It's a known problem and the rudder
pedals take a hell of a load. (Not from the rudder, but from the brakes.)
2. Try the rudder with the tail lifted. Is it very free? It should
be. If not, find out why.
3. Are the rudder tillers too long? Do you have too much rudder
throw? +/-30 degrees should be enough.
4. If you gap seal the rudder, you'll get a lot more effect around
zero, a lot more "sensitivity".
5. Stupid question time. Are you pushing on both pedals when you use
rudder? (Don't laugh, I've caught myself doing this innumerable
times. Why? I don't know. Maybe I'm trying to be precise.)
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Mon Jun 23, 2008 1:34 am Post subject: Re: Rudder seems stiff |
on the ground all controls should be free and easy.
elevator should fall with gravity. Rudder should be totally free. IF not something is binding and that is not good.
In the air all controls will get "stiffer" with speed.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
kitfoxnick
Posted: Mon Jun 23, 2008 2:21 pm Post subject: Re: Rudder seems stiff |
I raised the tail today seems pretty free. Took off the rudder pedals to gusset them. I guess this is just due to to the non airfoil vertical fin? Both kitfox IV's I flew in had the airfoil and seemed like less effort than this one. I'll tape the gap and see if that doesn't make a difference. No I'm not pushing both pedals but I agree that would be stupid.
thanks,
Nick
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Thu Jun 26, 2008 2:13 pm Post subject: Re: Rudder seems stiff |
I have a Vixen (Series 5). When I purchased the plane I felt the rudder was a bit tight. I guess I got used to it. Over time my rudder started getting stiffer and stiffer. It turned out to be the rudder pedal bushings. They were almost locked in place. I had to actually machine them down a little bit to make them fit without binding. The difference was amazing. ...smooth an easy!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
dave
Posted: Thu Jun 26, 2008 2:45 pm Post subject: Re: Rudder seems stiff |
like I said a few days a go.....
| Quote: | Posted: Mon Jun 23, 2008 5:34 am Post subject: Re: Rudder seems stiff
n85ae
Posted: Thu Jun 26, 2008 3:00 pm Post subject: Re: Rudder seems stiff |
If you have a Maule tailwheel it might have too many friction washers in it.
See if the tailwheel is the culprit.
Jeff
peteohms
Posted: Thu Jun 26, 2008 3:20 pm Post subject: Rudder seems stiff |
If your rudder is stiff for more than 4 hours, please see a doctor.
Sorry I couldnt resist.
Pete
Kitfox III
912 ul
Hell Paso, TX
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
kitfoxnick
Posted: Fri Jun 27, 2008 5:50 pm Post subject: Re: Rudder seems stiff |
Thanks for all the suggestions. I Jacked the tail up everything seemed pretty easy and smooth no noticeable binding or friction. I took the pedals off and gusseted with 4130. Going to install tomorrow. After I took the pedals off I was able to pull the rudder easily with my hands using the cables. Another question What should I lubricate the rudder pedal pivot bushings with?
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Mon Jun 30, 2008 9:46 am Post subject: Rudder seems stiff |
Or call a producer!
Sent via BlackBerry by AT&T
_________________ Mark Scott
Winston-Salem, NC |
kitfoxnick
Posted: Mon Jun 30, 2008 5:34 pm Post subject: Re: Rudder seems stiff |
Hey Mark noticed your in Elkton I'm in Northern Harford county. Just wondering were your flying out of maybe hook up some time.
Nick W.
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
mscotter
Posted: Sat Jul 05, 2008 11:44 am Post subject: Rudder seems stiff |
Hi Nick, I fly with my father out of N57, New Garden, which is in Toughkenamon, Pa, ~25minute drive north from Elkton. It's a neat little airport. It's a bit run down, but has a real variety of aircraft from warbirds to antiques & classics, homebuilts, etc.
I have yet to fly in a Kitfox myself. Grew up around aviation due to my father's military career and flying with him in his airplanes (various spam cans). He currently has a Cirrus which he graciously lets me get some stick time on.
Would love to hook up some time. Maybe seeing a Kitfox flying would be just the motivation I need to get to work. If you'd rather call then email my cell# is 443-907-7200. Of course, email is fine too.
-Mark S
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: "nick4853"
Nick W.
kitfox !V-1200
Rotax 912ul [b]
Winston-Salem, NC |
