		bj.hussey(at)ns.sympatico Guest
				 Posted: Thu Jun 05, 2008 5:25 pm    Post subject: Kitfox Suber EA81   (2nd message) |
				Plane had TT 329hr. A friend coached me on the  tailwheel and other traits of the Kitfox and I finished the year with 20 hours  total.  The previous owner stated he checked  the compression in  Jan 07  cold at 142,151,140 and 132.  There was no work done on the  plane from time of purchase until I drained the oil Tuesday past. I removed  the filter today and when checking it the oil seemed to have a different smell  and was very thin.  Seems like gas may have got into it.  I was not  told to shut the fuel supply off and it was on until it was noted when  going through the manual during the winter.  Did anyone ever hear of the  Ellison
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Fox5flyer Guest
				 Posted: Thu Jun 05, 2008 5:43 pm    Post subject: Kitfox Suber EA81   (2nd message) |
				Barrie, yes the Ellison having a very small needle  and seat can sometimes leak gas into the intake manifold that can migrate down  into the engine oil pan.  The manual specifically states to use the fuel  shut off valve to kill the engine and leave it off until next engine  start.
  It's possible that's what happened in your  case.
  If you have the normally aspirated EA81, those  compression numbers seem a bit low.  Try a complete oil change, warm the  engine up to at least 150 degrees, shut it down, then do another compression  check using a good quality tester.  Ensure that ignitions are off, all  plugs removed, and use wide open throttle with at least ten prop blades per  cylinder.  Let us know what numbers you get.
  Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP  375+ TT
 "The aim of an argument or discussion should not be victory, but  progress."
 - Joseph Joubert
  [quote]   ---
		Lynn Matteson
				 Posted: Fri Jun 06, 2008 6:56 am    Post subject: Kitfox Suber EA81   (2nd message) |
				Just for my curiosity, Deke, is there only one plug per cylinder on
 the EA81?
 Lynn
 On Jun 5, 2008, at 9:38 PM, fox5flyer wrote:
 [quote] Barrie, yes the Ellison having a very small needle and seat can
  engine start.
  Deke Morisse
  Mikado Michigan
  progress."
  - Joseph Joubert
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Fox5flyer Guest
				 Posted: Fri Jun 06, 2008 7:15 am    Post subject: Kitfox Suber EA81   (2nd message) |
				Yes.  Dual ignition, single plug.
 Deke
		WurlyBird
  Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
				 Posted: Wed Jun 11, 2008 4:14 pm    Post subject: Re: Kitfox Suber EA81   (2nd message) |
				To the two of you who are flying EA81s, how do you like them?  I am considering one as an option for my plane and it is hard to find testimonials for some reason.  Thanks for the help.
  _________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
		avtar412
				 Posted: Thu Jun 26, 2008 12:28 am    Post subject: Re: Kitfox Suber EA81   (2nd message) |
				I'm running an EA 81 T in my Series 5 and very pleased with it. 2.2:1 PSRU and performs very well. 72" WD prop and intercooler.
