best fuel economy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Homebuilt-List
rubber314chicken
PostPosted: Mon Jun 23, 2008 12:04 pm    Post subject: best fuel economy Reply with quote
If you were to to choose a kit/plans based on the best fuel economy, what would you choose? The KR-2S looks like it has the best at 30ish miles per gallon in cruise. Are there any more fuel economic choices out there?
- The Matronics Homebuilt-List Email Forum -
http://www.matronics.com/Navigator?Homebuilt-List
nwolfe(at)stealthturtle.c
PostPosted: Mon Jun 23, 2008 1:07 pm    Post subject: best fuel economy Reply with quote
The Cozy IV is pretty good and quick to boot.
-Nate
On Mon, Jun 23, 2008 at 4:04 PM, rubber314chicken <rubber314chicken(at)gmail.com (rubber314chicken(at)gmail.com)> wrote:
--> Homebuilt-List message posted by: "rubber314chicken" <rubber314chicken(at)gmail.com (rubber314chicken(at)gmail.com)>
If you were to to choose a kit/plans based of the best fuel economy, what would you choose? The KR-2S looks like it has the best at 30ish miles per gallon in cruise. Are there any more fuel economic choices out there?
http://forums.matronics.com/viewtopic.php?p=189404#189404
Nathan Wolfe
Building an Experimental Airplane
http://www.stealthturtle.com [quote][b]
franz(at)lastfrontierheli
PostPosted: Mon Jun 23, 2008 1:57 pm    Post subject: best fuel economy Reply with quote
There are many parameters that needs to be considered before a question like that can be answered. For instance: what would the application for the plane be, are ypou going to use for travel or recriation, how many seats do you need and so on and so fort,
Franz
On 23/06/08 2:04 PM, "Nathan Wolfe" <[url=nwolfe(at)stealthturtle.com]nwolfe(at)stealthturtle.com[/url]> wrote:
-Nate
On Mon, Jun 23, 2008 at 4:04 PM, rubber314chicken <[url=rubber314chicken(at)gmail.com]rubber314chicken(at)gmail.com[/url]> wrote:
--> Homebuilt-List message posted by: "rubber314chicken" <[url=rubber314chicken(at)gmail.com]rubber314chicken(at)gmail.com[/url]>
Franz Fux
Director of Operations
Last Frontier Heliskiing
TLH Heliskiing
Box 1118 Vernon, BC, V1T 6N4
www.lastfrontierheli.com
www.tlhheli.com
Ph: 250 558-7980
cell: 250 260-0433
gregoryf.flyboy(at)comcas
PostPosted: Mon Jun 23, 2008 2:57 pm    Post subject: best fuel economy Reply with quote
The Europa and the Long-EZ can compete easily with that number. The Europa
uses either the Rotax 912,912s, or 914 engine combo's. With the 912, it will
do 50mph in economy mode. Not sure which engine the Long-EZ's use.
ceengland(at)bellsouth.ne
PostPosted: Mon Jun 23, 2008 5:08 pm    Post subject: best fuel economy Reply with quote
Most of the Van's RV-x line will do close to 30 statute miles per gallon
if you fly them at the lift/drag intersection, somewhere around 140 mph.
They will do it even with the big engines. You never hear about it
because most owners can't make themselves fly that slow when the plane
will cruise at close to 200 (where they get 18-20 mpg if you're up at
10-11k feet).
They will probably cost a bit more to build than a KR, but have a lot
more room, short/grass field capability & much stronger resale market if
you ever have to part with one.
Charlie
mlas(at)cox.net
PostPosted: Mon Jun 23, 2008 5:15 pm    Post subject: best fuel economy Reply with quote
Here are the Lancair Legacy numbers
Low Speed
nm/hr
fuel rate
fuel total
rangenm
range sm
mpg nm
mpg sm
200
8
67
1675.0
1926.3
25.0
28.8
Normal cruse
225
10.5
67
1435.7
1651.1
21.4
24.6
High Speed
250
18
67
930.6
1070.1
13.9
16.0
aerofabco(at)juno.com
PostPosted: Mon Jun 23, 2008 7:23 pm    Post subject: best fuel economy Reply with quote
Yes, there are plenty of choices that get far better mpg figures than
"...30ish...":
They are called =sailplanes= and they get virtually infinite mpg.
<sigh> Sorry, I couldn't resist: but seriously, the Moni
self-launching
(motor-glider) is a case-in-point that sips fuel while the small KFM
or
similar engine is running for takeoff and initial climb, then burns
nothing
at all ( infinite mpg ) while soaring cross-country with the engine
turned off.
It's one solution to the question, given that the question imposed no
restraints
such as "...more than 150-mph cruise speed with seating for four
275-lb. each
adult males plus their golf clubs..." If one wants to go flying with
minimal fuel
expenses, the motor-gliders deserve a closer look.
....and, FWIW, the Rand-Robinson folks even proposed a motor-glider
variant
of their KR-1....
art
On Mon, 23 Jun 2008 13:04:06 -0700 "rubber314chicken"
<rubber314chicken(at)gmail.com> writes:
choices out there?
Comfort your feet with a new pair of slippers. Click here!
http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3lwW2vq0CYXkXlIXjdXLHX0yKNZ28p7lTZIoKwgVrb1amVTJ/
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Homebuilt-List All times are GMT - 8 Hours
