Fuel routing
madriver(at)wildblue.net
PostPosted: Mon Jun 23, 2008 3:45 pm    Post subject: Fuel routing Reply with quote
Now down to the planing for the fuel lines on a kit CH 701 with 912 ULS 100 hp Rotax. The plans show the fuel line routed down the left side of the cockpit and I assume thru the fire wall on the left side. However, from all the pics I've seen of the demonstrator the fuel line doesn' show at the left fire wall. The motor has the fuel hose on the right side. What's the best way to route the line, I've seen pics of a Spruce type gascolator / filter assy on the right fire wall in the engine compartment on one project, or does one just use the gascolator supplied by ZAC and then put a filter in the line. Also what's the best way to hook up the different "types" of gas lines - one supplied by ZAC and the one on the engine. All suggestions appreciated. You could contact me direct by email if you like.
Thanks Phil
ruruny(at)aol.com
PostPosted: Mon Jun 23, 2008 5:13 pm    Post subject: Fuel routing Reply with quote
Philip,
You will find some pics of my install. My battery is behind the right seat, gascolators for main and aux tanks behind left.
My fuel line goes up the left side of cabin then crosses to right side behind rudder pedals. 1/4 inch into gascolators and then
5/16 the rest of the way into rotax fuel pump which has a 5/16 nipple.
http://www.701builder.com/fuelsystem.htm
Brian Unruh
Long Island, NY
Get the Moviefone Toolbar. Showtimes, theaters, movie news, & more!
georgerace
PostPosted: Mon Jun 23, 2008 6:16 pm    Post subject: Fuel routing Reply with quote
I ran my fuel line down the right side of the fuse. Have the Zenith gascolator behind the right seat and the shutoff just in front of the right seat near the outside of the fuse. Can reach it very easily from the left seat. My fuel pump line is also on the right side of the Jabiur 2200.
George
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of ruruny(at)aol.com
Sent: Monday, June 23, 2008 9:13 PM
To: Zenith701801-list(at)matronics.com
Subject: Re: Fuel routing
Philip,
Brian Unruh
Long Island, NY
href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
Check out my CH-701 project at:
http://www.mykitairplane.com
Phil Owens
PostPosted: Tue Jun 24, 2008 11:53 am    Post subject: Fuel routing Reply with quote
Phil Owens
CH-801 Builder
