aadamson(at)highrf.com Guest
Posted: Thu Jun 26, 2008 5:29 pm Post subject: EL Lighting |
Ok, so the docs on the UMA EL lighting says to twist the wires on the AC
wiring for 8 turns per inch... Ok, but has anyone used shielded wire?
I'm wondering if there is an advantage to using a 2 conductor shielded
tefzel wire (which is twisted internally) and then just ground the shield at
one end. Will it be any better or worse than just twisting the 2 wires -
unshielded that UMA gives you?
For those that don't know, the EL lights use AC (around 100V) to cause the
lights to glow, it's low current, but AC and I'd just as soon limit any
source for Hmmmmmmmm...
Thots?
Alan
mrspudandcompany(at)veriz Guest
Posted: Fri Jun 27, 2008 6:09 am Post subject: EL Lighting |
Alan,
The twisting of the pair of wires tends to cancel the hmmmmmmmmmm, so you
should be OK with that.
Keep in mind that it is usually best to follow the manufacturer's
recommendation.
Roger
nuckolls.bob(at)cox.net Guest
Posted: Thu Jul 03, 2008 7:34 am Post subject: EL Lighting |
At 09:22 PM 6/26/2008 -0400, you wrote:
<aadamson(at)highrf.com>
Unshielded, twisted pair is quite adequate and preferred.
You can use your drill motor to fabricate short lengths
of twisted wire.
