heaysr(at)telus.net Guest
Posted: Wed Jun 25, 2008 7:59 pm Post subject: Wgt and CG difference between V-530 and MTV-9-K-C/CL250-29 p |
Many of your have chucked your 2 blade V-530 for a 3 blade
MTV-9-K-C/CL250-27 or 29 prop.
What is the impact on weight and balance, assuming a K flange that, without
an adaptor, matches the radial spline flange of the M14P?
I've read the V-530 without spinner weighs around 90 lb and the MTV-9-K-C/CL
250-29 with spinner weighs around 80 lb. Can anyone confirm or better the
accuracy of those approx. weights.
I guess the CG of the V-530 (without spinner)is approx. 6 in ahead of the
flange and the MTV-9-250 (with spinner) is approx. 7 in ahead, such that the
moment is approximately the same by intention of the MTV designers. Can
anyone confirm or better the accuracy of those moment arms.
Royden Heays
C-GRED
Yak 55M
kregg(at)balancemyprop.co Guest
Posted: Wed Jun 25, 2008 8:37 pm Post subject: Wgt and CG difference between V-530 and MTV-9-K-C/CL250-29 p |
V530 prop and spinner (Yak18 Clown nose style) weighs 98lbs
MTV-9-260-29 and spinner weight 88lbs.
No adapter on the MT
Both without oil.
Kregg Victory
