BobbyPaulk(at)comcast.net Guest
				 Posted: Sat Jul 12, 2008 1:22 pm    Post subject: Inspection note |
				601 XL
 i finished up the Conditional on my bird yesterday.
  	  | Quote: | 	 		   i discovered a problem at the rear spar attach point on the right wing.
  the fitting on the fuselage slides between 2 rivets ( top & bottom ) on
  the rear spar.
  on my right wing the bottom rivet was into the fuselage attach fitting
  about 1/8" causing a serious bending load and stress point on the attach fitting.
  please look at yours thru the small rectangular holes in front of the rear
  spar attach bolt. i would think it could cause a crack in time.
 we checked 2 other A/C in the area and found one of the two had the same problem.
 i can send a photo if you contact me off line.
 bobby
 N131BP
 65 hrs.
 ps does anyone have a Part number for a K& N Air Filter or other brand i could purchase locally. i have the large airbox with a filter size of 11" x 6  9/16"
 thanks
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
