		phcarter(at)aol.com Guest
				 Posted: Mon Jun 30, 2008 3:17 pm    Post subject: Spark Plug Adapter |
				Does anyone sell adapters from U.S. standard shielded aviation spark plugs to automotive spark plugs?
 Preston Carter
 N6209F  [quote] [b]
				 Posted: Mon Jun 30, 2008 4:17 pm    Post subject: Spark Plug Adapter |
				Why not do the entire changeover to the automotive conversion  using my kit?  I've shipped over a hundred of these kits all over the world  without problems.  Read about it and see a few photos of the installation  on my web site.  http://www.yak-52.com/plug_conversion.htm   You can also download the complete 14 page installation instructions with lots  of color photos of the entire process.
  Dennis
  [quote]   ---
		n395v
				 Posted: Wed Jul 02, 2008 4:35 am    Post subject: Re: Spark Plug Adapter |
				Dennis,
 Are their any problems with the automotive plugs at high altitude ie: 18K+?  Any of your customers routinely fly them this high?
  _________________ Milt |
				 Posted: Wed Jul 02, 2008 4:48 am    Post subject: Spark Plug Adapter |
				Not that I'm aware of.  But then again, I don't know if anyone is flying at
 18K+ altitudes either with the conversion kit.  You may want to post the
 question to the RV list since some of the RV's are flying with automotive
 conversions and some may also be flying at the flight levels.
 Dennis
		sd737(at)aol.com Guest
				 Posted: Wed Jul 02, 2008 5:09 pm    Post subject: Spark Plug Adapter |
				I've flown my Lancair 360 up to 22K and it has a set of auto plugs in the bottom holes fired by electronic ignition and the thing ran well at high altitudes.  The upper plugs were running on a magnetto.
		cjpilot710(at)aol.com Guest
				 Posted: Wed Jul 02, 2008 5:57 pm    Post subject: Spark Plug Adapter |
				In a message dated 7/2/2008 9:10:08 P.M. Eastern Daylight Time,  sd737(at)aol.com writes:
  Years ago I remember hearing about engine problem the Hellcat was having at  high altitudes.  The test folks couldn't figure it out, because it only  happened high up and all system tested normal on the ground.  The test  pilot went to talk to the Republic test pilot because the P-47 was using the  same engine and readily got to 30K.  It turns out the ignition harness  system on the P-47 was pressurized and the Hellcat not.  The lack higher  density air, the wiring was shorting out.  Many of the bombers had  pressurized ignition harness.
  Jim "Pappy" Goolsby
  [quote]   I've flown my Lancair 360 up to 22K and it has a set of auto plugs in the    bottom holes fired by electronic ignition and the thing ran well at high    altitudes.  The upper plugs were running on a magnetto.
		petervs(at)knology.net Guest
				 Posted: Thu Jul 03, 2008 7:33 am    Post subject: Spark Plug Adapter |
				I don't think there is any correlation between the plugs and wires and
 misfires at high altitudes. The occurrence of high altitude misfires is
 typically due to arc over inside the magneto. On the ground the arc occurs
 in the combustion chamber in the spark plug. The gap is set so that under
 pressure this is the most likely place for the arc to occur. As you go up in
 altitude the pressure inside the combustion chamber stays relatively the
 same, but the air pressure inside the mag gets lower and thus it is easier
 for an arc over in the mag to occur. Airplanes that fly to higher altitudes
 have pressurized magnetos and ignition systems to keep the most likely place
 for the arc to occur in the combustion chamber. Another thing to do is to
 keep your plug gap at a minimum, typical plug gaps are 0.016 to 0.021 inches
 and if you fly at high altitudes you want to check your plug gap more often
 and set it to the smallest end of the range.
 Squatch out.
