iworonko(at)cox.net Guest
Posted: Sun Jul 06, 2008 3:35 pm Post subject: 912 UL runing on 3 cylinders |
Hi folks,
had a new problem show up about a week ago. Before I start the engine I crank it with the mags off and choke on for 2-3 seconds then turn the mags on and it fires right up.
This time when I cranked it I noticed it didn't sound right, when I turned the mags on and started it, it ran very rough. Before shutting it down did a mag check and both sides were working. Checked the exhaust pipes and one was cold. pulled the cover off the cold cylinder to check the valve train- everything looked good. Removed lower plugs on all cylinders and did a compression test- all cylinders were same. So I put everything together and tried running it again-ran just fine.
This same scenario has repeated several consecutive days. Its getting to a point where I can predict when its going to run on 3 cylinders by turning the prop by hand. There is a point where there should be a compression stroke but its not there, prop spins free past it. Everyday I have been able to get it to run ok by either alternately cranking it with a starter and by hand or doing a compression test. After a good start I go flying and it performs flawlessly. Right after shut down it restarts fine, but next day I can almost guaranty that it will do it all over again.
Any ideas?
Eric Speedster N58EW
Fox5flyer Guest
Posted: Sun Jul 06, 2008 5:21 pm Post subject: 912 UL runing on 3 cylinders |
Sticking valve, rocker?
Deke
kitfoxmike
Posted: Sun Jul 06, 2008 5:29 pm Post subject: Re: 912 UL runing on 3 cylinders |
carbon buildup. try marvel mystery oil in the fuel. What you really need to do is decarbon the engine. And yes, mine has done this. Not in the last 2 years tho.
JetPilot
Posted: Mon Jul 07, 2008 8:10 am Post subject: Re: 912 UL runing on 3 cylinders |
My Rotax 912-S has also done something like this. It is not to the point of running on 3 cylinders, but every couple months I spin the prop cold by hand and there is no compression on one cylinder... I start it up, it flys perfect, and on the ground I have compression on all cylinders cold for the next several weeks when I spin the prop. Its only every couple months that I spin the prop and find no compression on one cylinder. I don't think its carbon though, as my engine did this with less than 25 hours on it, and its never seen a drop of 100LL
Mike
Kolb MK-III Xtra, 912-S |
