Leading edge that has never failed in normal operation
herbgh
PostPosted: Wed Mar 08, 2006 5:25 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
Guys
Changed the subject line to better reflect the conversation..
Let me see if I have it straight?? No Kolb wing has been documented
to fail in normal operation! That would include running headlong at
speed into some mean thermals in the south west..
Only two leading edges have failed and this was the result of flight
way ,way,way above and beyond normal operation.. Aerobatic flight!
Even Dennis told us that he was young and heroic at one time..
I think we have a couple of guys here who are doing damage to the
Kolb Reputation.. Well deserved that it is...
So what are we really talking about?? Someones fears?? That
conversation will last a long time...
Herb --pining for the good old days when Sea Foam and oil choices
ruled!! Smile
On Wed, 08 Mar 2006 16:50:26 -0500 "John Murr" <jdm(at)wideworld.net>
writes:
If you exert pressure on the leading edge until it fails it won't
break the
rib tubing. It has to bend. Since being "in column" is not an
exacting
flykolb(at)pa.net
PostPosted: Wed Mar 08, 2006 6:10 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
Good words well spoken. I should have thought of saying that - but I didn't
- so thank you Herb!
Dennis
PostPosted: Wed Mar 08, 2006 6:18 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
flight
the
| Herb --
Herb/Gang:
I don't believe Dennis Souder intended to test the Ultrastar to
destruction, but it happened. Was not the result of a leading edge
failure, but a drag strut which allowed the wing to fold. The US
Dennis was flying had no drag strut brace. The drag strut brace came
along as the result of Dennis folding the US wing.
My original FS normally never pulled more than 3 to 3.5 G's indicated
on a certified accelerometer (G meter). I can only remember pulling
more than 3.5 G's once, in an attempt to see how much I could pull,
which was 5.0 G's and I really had to work hard to accomplish that.
The aerobatics I flew were well within the stress allowance of the FS.
However, the FS was not and is not an aerobatic aircraft. Have not
flown any aerobatics since 11 March 1990. Think I learned my lesson.
Those of you that like to push the envelope, raise Hell, have fun, but
don't hurt any innocent bystanders.
Please explain the second paragraph above. I am not sure what you
mean and who you are talking about.
If you are referring to me, I do not think sharing my experience,
mistakes, failures, successes is in any way going to damage the
reputation of The New Kolb Aircraft Company. If it was, I am sure
Bruce Chesnut, Donnie Sizemore, and Travis Brown would rap me up side
my hard head or put a boot up my butt to get my attention.
I'm working on a post to the Kolb List now. Hopefully, it will
explain what has happened and how "I" prepared to preclude this from
happening again.
I have never stopped flying Kolbs, mine and factory, since I made my
first flight July 1984. If I had any doubt about the reliability or
safety of Kolb aircraft, I would never get in another one.
I think it is very important, especially on the 5 rib wings, to insure
the lateral bracing is in place. Contrary to popular belief, those
little 5/16" fabric braces on the leading edge will break from
vibration and end up riding on the bottom wing fabric. You can smack
the bottom fabric of the wing with the palm of your hand in all the
rib bays to see if there is anything in there riding around freely.
If there is, you will hear it rattle.
The best way to check the leading edge bracing, which is really fabric
bracing, is make a small slit with a razor blade in the inboard rib
fabric. Get a flashlight and look inside to see what you have. When
you are finished, get a roll of 2" plastic electrical tape and seal up
the hole to keep the windstream and bugs out.
If I was going to fly a 5 rib of my own, I would make the "hauck" mods
to insure I was going to land under the wings and not a parachute. My
own personal desire because I have experienced wing failure and do not
want to ever go through that again. OK? If you had walked in my
shoes, you would understand where I come from.
Take care,
hauck's holler, alabama
What others do is their business. Based on history of Kolb aircraft,
there ain't no problem. Wink
WhiskeyVictor36(at)aol.co
PostPosted: Wed Mar 08, 2006 7:24 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
In a message dated 3/8/2006 8:26:33 P.M. Eastern Standard Time,
herbgh(at)juno.com writes:
ruled!! Smile
Oh Herbie,
You are so funny. hehehe
Billy Varnes
herbgh
PostPosted: Wed Mar 08, 2006 7:26 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
John
Uh! Uh!! You would be the last on my list... I do not even want to go
back and look at the last several days of mail to make any named
acusations..
My understanding of your failure was that it did not happen in the
normal flight envelope.. Same for the fatility..
Seems that both accidents have been written about before?
I would be the last to discourage sharing info of any type about
Kolbs and flying them.. Think I have griped about my Firefly going over
on its nose easily... Cannot think of one gripe about the mkIII that I
owned..
Perhaps my building a set of single lift wings muddied the water a
bit? I am doing that just because I like the idea.. Ain't going to toss
the current set of wings... Adding the d cell might have implied some
concern--not so---Just like the idea.
What I was referring to was the harrangue that has gone on about
structural reliability when flown normally with a subject line that was
clearly wrong..
I sensed that a real fear was developing about the Kolb
aircraft,particularly the 5 rib Firestar, with no evidence of a problem..
While TNK does not build a 5 rib wing Firestar, they are clearly
identified with the name..
Ain't gonna defend anyone when they are wrong... Nor out of mis placed
loyalty.. Smile
What I think and likely the last 20 or so years tends to indicate
is:---Kolb makes the strongest airplane of its type in the country. The
aproval by the Brits is a clear indication of that!
Herb
the
| Herb --
Herb/Gang:
side
aircraft,
Its what we learn after we know everything that is the most important.
PostPosted: Wed Mar 08, 2006 7:39 pm    Post subject: Leading edge that has never failed in normal operation Reply with quote
| Herb
That's why I chose it in 1983, finally got the $3,495.00 to buy my
first one in March 1984, and still flying them in 2006.
I looked for 6 months at what was available before I made my final
decision. Back then, nothing came close. Today, it is still my first
choice, because these little airplanes do for me what I want to do in
aviation. Satisfy all my flying desires.
Well...........I wouldn't mind cruising at 150 mph when I get in a
hurry, but I'll give up the unrealistic cruise for all the other
attributes of the Kolbs.
Take care,
MKIII (SN: M3-011)
Kirk Smith
PostPosted: Thu Mar 09, 2006 12:22 am    Post subject: Leading edge that has never failed in normal operation Reply with quote
You certainly have a valid point. No more posts from me on that subject.
Eugene Zimmerman
PostPosted: Thu Mar 09, 2006 5:52 am    Post subject: Leading edge that has never failed in normal operation Reply with quote
John,
I saw that nice Firestar of yours at Bill Lock's Flight Farm when
you were in route to Oshkosh. I dont remember if I met you in
person there or not but I remember it as being an excellent fly-in.
Bert Howland was there with his two little planes and I forgot the
guys name with his Monarch flying wing glider, which Bill Lock towed
to altitude with his 582-powered Terratorn.
Bill Martin trailered in Kolbs demonstrators but someone forgot to
pack the struts for their Firestar so the guys back home quickly UPS-
ed them up the next day and I remember being impresses with the fast
shipping service ,,,,,,,,,,,,, but then again Homer was still working
for UPS back then. Smile
Earl flew in that year with our modified Mark II with a 582 while I
provided ground support, hauling all our fuel, gear and grub.
This plane is the one pictured in Earls Frapper profile and is still
flying great with that same engine.
I gave it a face-lift and Earl rebuilt the engine this winter and it
will likely be flown to Homers place again by grandson Eddie as it
was last year on Fathers Day weekend.
Like you, I too am still flying a Kolb with no regrets.
PS
Sure would be nice to have you join the event at Homers this year.
Gene
PostPosted: Thu Mar 09, 2006 7:24 am    Post subject: Leading edge that has never failed in normal operation Reply with quote
| Gene
Gene/Gang:
Yep, those were the days. Wink That would have been the 1989 Flight
Farm Flyin. That was the second year I flew the FS up there. And
yes, I was enroute to Oshkosh. Powered with the old point ign 447, I
had flown to Homer Kolb's for a few days, then up to Bert Howland's in
Maryland, NY, for a week, then flew through all the New England
States, over to the Flight Farm at Monterey, NY. Spent about a week
there, then flew over Niagra Falls for the second time, around
Detroit, up to Sault St Marie, Canada, and finally west and south into
Oshkosh 1989. Weather was terrible the day I flew into OSH. Had been
scud running, right on the deck all the way from Manistique, MI, where
I had RON'd. The "dealers show case" was in full bloom when I circled
the UL strip to land. Before I got out of the FS someone stuck a
microphone in my face. Very exciting times. My little bird won OSH
Grand Champion UL that year. Was a very happy two day flight home to
Alabama from OSH. I think this flight was 25 days and over 3,000
miles, the longest I had done in an UL.
This was 17 years ago with a single point ign 447, and you all are
wondering if your new Rotax will get you around the patch. hehehe
Eugene, that was the year Bert put me in his Honey Bee. Little did he
know he would have a hard time getting me out of it. Was a fun
airplane to fly, landed by itself at 25 mph, but it wasn't a Kolb.
The next year, 1990, is when Homer and Dick Rahill forgot the lift
struts for the FS and had to go back to get them. By that time I had
lost my FS and was ground bound and making plans to build the MKIII I
am flying today.
Got a bc email from Dennis Souder last night. In my reply to him I
mentioned I was considering making the Father's Day Flyin at Homer's
this year. Been 12 years since I have been to the Kolb Farm, 1994,
when I was on my way home from Alaska via the US border. Unless
something unforeseen happens between now and then, I will be at
Homer's for the flyin.
Time sure is flying.
Eugene Zimmerman
PostPosted: Thu Mar 09, 2006 8:32 am    Post subject: Leading edge that has never failed in normal operation Reply with quote
On Mar 9, 2006, at 10:25 AM, John Hauck wrote:
Unless
Good! Looking forward to meeting you there at the Kolb Farm with all
the "classic" pilots and planes. Smile
Someone should put a marker on the Kolb Frapper satellite map for
Homers place. It can be found easily on the road map. Just look for
Homers little lake between Spring City and Phoenixville then click
satellite and zoom in for amazing detail.
>> Time sure is flying. <<
Yes, for sure! ,,,,,,,,,,,,,,,,,, pun intended Smile
