DAquaNut(at)aol.com Guest
Posted: Mon Mar 06, 2006 10:51 pm Post subject: Evening Flight |
Kolbers
Flew my first cross country today to an airport 17.3 miles away. Not
much of a cross country but it is a start. The Firefly burned about 3.2 gal
and took about 40 minutes ,to make the round trip. The weather is warm enough
down here that the mosquitos are starting to be a pest. I am still glad I
decided to build a KOLB. I think I saw 80 mph once when I was not keeping an eye
on the airspeed. The really good part is my leading edge did not fail on
either wing. I have the fold up time down to 15 minutes! Starting to trust Her
a little more each time I fly Her!
Ed Diebel ( In Houston Firefly # 62 , 6.5 hrs.)
jdm(at)wideworld.net Guest
Posted: Tue Mar 07, 2006 3:58 am Post subject: Evening Flight |
I guess we are all paranoid now! I saw 90 once and mine didn't fail either.
| Quote: | I think I saw 80 mph once when I was not keeping an eye
either wing.
rlaird
Posted: Tue Mar 07, 2006 6:31 am Post subject: Evening Flight |
Ed --
Where'd ya go... Volk? or Bailes?
-- Robert
On 3/7/06, DAquaNut(at)aol.com <DAquaNut(at)aol.com> wrote:
Kolbers
Not
much of a cross country but it is a start. The Firefly burned about 3.2gal
enough
an eye
trust Her
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Eugene Zimmerman
Posted: Tue Mar 07, 2006 7:57 am Post subject: Evening Flight |
On Mar 7, 2006, at 6:56 AM, John Murr wrote:
| Quote: | I guess we are all paranoid now! I saw 90 once and mine didn't
fail either.
Hey now,
If you fly 90 mph in that 5 rib I promise I will deny I never knew a
John Murr.
Please slow down.
Posted: Tue Mar 07, 2006 8:26 am Post subject: Evening Flight |
I assure you it was by accident.
flht99reh(at)netzero.net Guest
Posted: Tue Mar 07, 2006 9:37 am Post subject: Evening Flight |
Good for you Ed. I envious a little. But soon, perhaps within the early part
of summer, there I will also be. I am also somewhat envious of your mosquito
problem. That means heat and here in the Ohio area, we ain't got none! (my
spell checker hates me).
Eugene Zimmerman
Posted: Tue Mar 07, 2006 10:09 am Post subject: Evening Flight |
On Mar 7, 2006, at 11:25 AM, John Murr wrote:
Ok,
Think about that last eight letter word.
Posted: Tue Mar 07, 2006 11:50 am Post subject: Evening Flight |
In a message dated 3/7/2006 5:59:33 A.M. Central Standard Time,
jdm(at)wideworld.net writes:
either wing.
This was sarcastically!!!!!!!!!
Ed DO NOT ARCHIEVE
DAquaNut(at)AOL.COM Guest
Posted: Tue Mar 07, 2006 12:12 pm Post subject: Evening Flight |
In a message dated 3/7/2006 8:32:29 A.M. Central Standard Time,
rlaird(at)cavediver.com writes:
Ed --
-- Robert
| Quote: | From Volks To Bube's in Alvin and back to Volks, Where I hangar. Not a long
trip, but I just have a little over 6 hours flying time in her. Slowly
gaining confidence in the plane and 447. I kept what I thought was a suitable
landing spot in sight most of the way. I still have not made a decision whether
it would be better to use flaps If the engine quit. All this talk about wing
failure seems a waste of time. Of course I built mine, and I fly within the
parameters it was designed. I think the chances of the 447 quitting are far
more realistic than the leading edge failing ! I feel more attention should be
focused on the 2- stroke. I think that is the weakest link in any Kolb
product.
Ed Do Not Archieve
Posted: Tue Mar 07, 2006 12:18 pm Post subject: Evening Flight |
I filled my whole leading edge with cement. I can do a 150 mph dive
without a sign of deformation.
-BB, trowel in hand.
On 7, Mar 2006, at 2:47 PM, DAquaNut(at)aol.com wrote:
either.
> fail on
> either wing.
Ed DO NOT ARCHIEVE
rlaird
Posted: Tue Mar 07, 2006 12:32 pm Post subject: Evening Flight |
I keep forgetting you're at Volk... I don't know why I keep thinking you're
at Alvin.
Yeah, the Volk to Alvin trek is nice, but unless you go wide around to the
south, you fly over a lot of houses in Alvin. If you start feeling
comfortable with that, then add in Ray's turf strip and make it a triangle.
Have you done many practice emergency landings yet? If not, you need to get
busy and practice. Until you do them, and get the plane down to about 20
feet before powering up and flying away, you won't know how the plane flies
without power (I'm not suggesting you power off, just power down to idle).
If you have a VSI, you can easily find your best-glide speed. If you don't
have a VSI, it will take you several tries, taking notes on time/altitude.
I'd start at 50mph, then 45mph, etc.
My friend, Rick, kept putting off practicing the engine-out's, and he got
"bit" by that. When his engine quit, he realized he had no idea how quickly
the plane would descend, and how little time he had. And he didn't realize
that when you get below 100 feet, you should have already committed to a
landing spot, because any changes below that altitude could be fatal. He
was very, very lucky and walked away, but his plane was totaled.
Learning how to slip and lose a lot of altitude fast, but recover quickly
and get to best-glide again, is a very useful skill to have, too. You could
pick out a landing and realize you're going to over-shoot it, and not be
able to get down fast enough (and yet still retain enough energy to flare at
the end). Being good at that could save you from running into a fence after
you landed, or worse.
I hope to see your plane in the near future. I'm still tweaking different
things on my MkIII and not going to far from home, but I hope to make most
of the local fly-in's this spring...
-- Robert
long
suitable
decision whether
wing
the
far
should be
product.
Ed Do Not Archieve
Robert Laird
Houston, TX area
Eugene Zimmerman
Posted: Tue Mar 07, 2006 1:51 pm Post subject: Evening Flight |
On Mar 7, 2006, at 3:10 PM, DAquaNut(at)aol.com wrote:
| Quote: | I think the chances of the 447 quitting are far
attention should be
Kolb
product.
I've never had a leading edge fail or a 2-stroke Rotax quit.
Ah but I think the weakest link in any Kolb product is always the
critter in the seat.
ElleryWeld(at)aol.com Guest
Posted: Tue Mar 07, 2006 3:22 pm Post subject: Evening Flight |
I have been over 95 indicated many times I wont say how much over it might
scare you But in my 5 rib wings and it doesn't bother me of coarse I have been
told I am a bit crazy anyway and not by just one person Fly it like you built
it and enjoy it You only have one chance to do your life's missions before the
Great gods remove you from this place and, That I do! they will be talking
about the things I have done a long time after I am gone and I dont think a
Kolb will be the reason I will go. Face it when its your time thats it . There
are many inferior kits out there flying compared to what we are all flying
and you don't hear anything scary about them well at least I haven't heard
anything
Ellery in a 5 Rib wing and lovin it
Eugene Zimmerman
Posted: Wed Mar 08, 2006 5:16 am Post subject: Evening Flight |
On Mar 7, 2006, at 11:12 PM, DAquaNut(at)aol.com wrote:
In a message dated 3/7/2006 3:52:10 P.M. Central Standard Time,
etzim62(at)earthlink.net writes:
How many hours do you have with a 447? I only have 6 hours on
mine! I
think it would be interesting to poll everyone on the list and get
an hours flown
to rotax quitting ratio along with the cause of quitting. Anyone
ever done
anything like that???
Ed
Hey Ed,
As soon as I hit send on that post I realized I missed one key three
letter word.
" Y-E-T "
I have been flying ultralights since 1980 and have sons and now a
grandson flying 2-stroke Kolbs.
Ironically I personally have no actual experience with a 447 but have
had hundreds of hours with the 377, 503, and 582 Rotax engines and
have never had one unexpectedly quit. Oh yeah, I forgot son Earl did
have a 447 in a Minimax also.
It is no doubt a significant advantage that my sons and I have
experience as professional engine mechanics with a good sense what
can be expected of things mechanical and what is at the root of
mechanical failures.
It is my opinion that the Rotax engines used on Kolb planes today are
well made mechanical devices providing excellent performance
designed to last hundreds, yes , and in some cases even thousands of
hours, if operated within their unique design parameters.
In my opinion most engine failures are due to the software, not the
hardware.
In other words, as I said, the weakest link is not the mechanical
part, but the operator.
Having said that,,,,,,,,,,,
A good operator always knows that everything mechanical is subject to
failure and is prepared to deal with it.
ulflyer(at)verizon.net Guest
Posted: Wed Mar 08, 2006 9:09 am Post subject: Evening Flight |
Ed,
How much do you weigh and what's the empty weight of your
FireFly? What wheels are you using?
jerb
At 02:10 PM 3/7/2006, you wrote:
Ed --
-- Robert
Not a long
a suitable
decision whether
attention should be
product.
Ed Do Not Archieve
Posted: Wed Mar 08, 2006 9:45 am Post subject: Evening Flight |
In a message dated 3/8/2006 7:17:08 A.M. Central Standard Time,
Eugene,
Are you suggesting that a majority of Rotax failures come as a result of
improper maintenance, Not paying attention to warning signs or sounds,
improper oil mix ratio, which would fall into the category of pilot ERROR? I had a
Kawasaki 440 that served me well for 117 hours till I sold the plane. Never
quit once. I never heard of one quitting! I heard of Cayunas quitting a few
times. There were not many Rotaxes around in 82 so I didn't hear much about
them! I understand without proper care and maintenance no engine will
last long, but I do know 2-cycles are less forgiving and more prone to seizure
than a 4-stroke. Maybe this list has made me paranoid. I know I was worried
about bending an axle because of all the talk on the list. So far I have made
28 landings and have not bent a gear yet. Im sure my time will come , but I
hope my fear of the Rotax is like my fear was of bending a leg.
Ed (Firefly # 62)
do not archieve
Posted: Wed Mar 08, 2006 10:04 am Post subject: Evening Flight |
In a message dated 3/8/2006 11:10:41 A.M. Central Standard Time,
ulflyer(at)verizon.net writes:
jerb
Jerb,
My Firefly weighed 252 when I weighed it with small wheels. The way she
sits with BRS ,and 6" auzusa plastic wheels, with disc brakes made from table
saw blade discs is 286 lbs. According to the scales I used I am over weight
by 8 lbs., but I feel safer with brakes. I weigh 185lbs. Am I exceeding
gross? What is gross weight for the Firefly. I cannot find it in the Kolb Manual
or the Plans.
Ed
Posted: Wed Mar 08, 2006 11:26 am Post subject: Evening Flight |
At 01:03 PM 3/8/06 EST, you wrote:
or the Plans.
Ed
500 pound gross weight.
Jack B. Hart FF004
Winchester, IN
Eugene Zimmerman
Posted: Wed Mar 08, 2006 4:38 pm Post subject: Evening Flight |
On Mar 8, 2006, at 12:44 PM, DAquaNut(at)aol.com wrote:
| Quote: | Are you suggesting that a majority of Rotax failures come as a
result of
sounds,
pilot ERROR?
Yep, that IS what I am saying.
Let me give you an example of a very common problem Ive seen over
the years.
I've seen guys who think they have an exhaust temp problem, so they
start changing needles and jets and chase the temp gauge all over the
place because they are sure the standard Rotax setup is all wrong.
They put more faith in the reliability and accuracy of a little cheap
temp gauge and sensor than they do in the experience and
recommendations of the company that designed and manufactured the
engine.
Just because the pilot really likes the numbers he see on a gauge
does not mean the engine does.
Because the 2-stroke engine has a much higher output of horsepower
per displacement than the average 4-stroke engine, the 2-stroke also
has much less tolerance and margin for error in its operational
requirements.
If a Rotax engine is running too lean with a stock setup, changing
the needles and jets is almost always merely camouflaging and
temporarily covering up another often more serious problem.
