icubob(at)newnorth.net Guest
Posted: Tue Jul 08, 2008 11:48 am Post subject: tail wheel leaf spring. |
hi lowell, thanks for the reply and good info.
right now my tailwheel is matco and 2 leaf springs. the springs are attached with thru bolts at the fuselage end and at the wheel. my thought would be to replace 2 leaf springs with 3 , each of 1/10'' thickness. this should be more flexible than 2 of each 1/4''. also, one leaf must be firmly attached to the matco wheel but the other 2 could have an elongated hole which would allow them so slide a bit against each other, allowing more flex. maybe a paper thin matreial like delrin between them.
i guess i am sold on 2 leaf redundancy but i would like to put more flex in the spring setup. i dont know if the spring shop supplies any other thickness than 1/4 and 1/10.
bob noffs
Fox5flyer Guest
Posted: Tue Jul 08, 2008 12:53 pm Post subject: tail wheel leaf spring. |
The elongated hole has some merit, but how would you allow for the necessary movement between the two leaves when tightening up the tailwheel bolt to the springs? Those things need to be pretty tight.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 377+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Posted: Tue Jul 08, 2008 1:13 pm Post subject: tail wheel leaf spring. |
deke, i figured the elongated hole had to be large enough to fit over the nut holding one leaf tight to the wheel. i dont nearly have the answers yet but i am thinking anyway.
bob boffs
