shinco(at)bright.net Guest
Posted: Mon Jul 07, 2008 1:14 am Post subject: Tail wheel spring set up |
I have a KF2,,I have replaced the stock,1 leaf spring.It worked
fine..but to be safe for off airport.I replaced to 3 leaf spring from
Kitfox..BUT now the rear tail wheel does not coster around right.does
not lock in to place.On better looking at the two different leaf
springs,the single+ the Triple sets the angle is different.A big
different .in them...as is now with the new set up..it is in danger of
even ground handing it.it wants to ground loop.braking does not help
much...Could this be the wrong set of leaf springs??does the KF2
different ,or does all KF springs fit all KFs??may be I have the wrong
KF springs??I can not fly this way... What can I do??grounded in
OHIO.....STEVE SHINABERY,,N554KF KF2 582
Michel
Posted: Mon Jul 07, 2008 2:13 am Post subject: Tail wheel spring set up |
Steve,
I have a Kitfox 3 and last year, after maybe 900 landings, the single leaf broke. I replaced it with two leafs and I feel quite happy.
What kind of tailwheel do you have? The Maule? The point is: the vertical axis must be just a tiny bit tilted forward. That is the key to good tailhweel control. But I don't understand why your wheel now won't free-castor. Have you checked the unlocking mechanism?
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
helili(at)chahtatushka.ne Guest
Posted: Mon Jul 07, 2008 6:42 am Post subject: Tail wheel spring set up |
Check rudder cable tension, tailwheel centering springs tension, and
possibly cable length. Could be that the new leaf spring is a bit longer or
shorter than the original, or is arced differently, effectively lengthening,
or shortening the distance from rudder pedal to rudder control horn.
John Hart
KF IV
Wilburton, OK
Lynn Matteson
Posted: Mon Jul 07, 2008 9:12 am Post subject: Tail wheel spring set up |
Look at the caster angle of the new setup versus the old setup. They
should be similar. In order for the tailwheel to caster (follow the
plane) a projected line drawn through the centerline of the pivot
must hit the ground ahead of the contact point of the wheel on the
ground. It sounds like you have done this, right? If that angle is
off, it could be that the new spring has too much arch in it...or too
little.
I'd check with the seller of the spring.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/545 hrs
On Jul 7, 2008, at 5:14 AM, steve shinabery wrote:
from Kitfox..BUT now the rear tail wheel does not coster around
right.does not lock in to place.On better looking at the two
different leaf springs,the single+ the Triple sets the angle is
different.A big different .in them...as is now with the new set
up..it is in danger of even ground handing it.it wants to ground
loop.braking does not help much...Could this be the wrong set of
leaf springs??does the KF2 different ,or does all KF springs fit
all KFs??may be I have the wrong KF springs??I can not fly this
way... What can I do??grounded in OHIO.....STEVE
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Guy Buchanan
Posted: Mon Jul 07, 2008 4:55 pm Post subject: Tail wheel spring set up |
At 02:14 AM 7/7/2008, you wrote:
| Quote: | Could this be the wrong set of leaf springs??does the KF2
wrong KF springs??I can not fly this way... What can I do??
If the angle is the only thing different, (meaning you swapped the
entire tailwheel assembly from one to the other,) that has to be the
reason. The pivot should be nearly vertical, with the top slightly
behind the bottom so the wheel doesn't shimmy. I'm guessing yours has
the top WAY behind the bottom, so the wheel wants to flop sideways.
That would be bad. If your pivot angle looks wrong, have a spring
shop bend it for you to the right angle.
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar
Deceased K-IV 1200
A glider pilot too. |
Posted: Mon Jul 07, 2008 5:18 pm Post subject: Tail wheel spring set up |
Guy Buchanan wrote:
That would be bad. If your pivot angle looks wrong, have a spring shop
Guy Buchanan
San Diego, CA
270.4.6/1538 - Release Date: 7/7/2008 7:40 AM
Thanks Guy,,every one has helped me..and these are all good ideas..today
I am sending pictures of springs to Kitfox ..what I have..and what needs
to be done.. but grounded 4 now in Ohio.I can not keep doing loops
all down the way.of the run way.trying to get off the ground..all so
looks kind of stupid.. But with all of the kitfox family and
John+Deb at kitfox.hope to have her back in the air again..soon....STEVE
SHINABERY N554KF KF2 582..
dave
msm_9949(at)yahoo.com Guest
Posted: Tue Jul 08, 2008 6:13 am Post subject: Tail wheel spring set up |
Some will say I'm nuts but if your original 1 leaf spring is intact (no cracks), why not put it back on and keep flying until you get the problem with 3-leafer sorted out? So long as you inspect it carefully at every preflight and unload the tailwheel when trailering or storing with wings folded, you'll get hundreds of hours of safe service out of that 1-leafer.
Just one aviator's thought to keep you in the air Steve.
Marco Menezes N99KX
Model 2 582-90 C-Box
--- On Mon, 7/7/08, steve shinabery <shinco(at)bright.net> wrote:
[quote]From: steve shinabery <shinco(at)bright.net>
Subject: Re: Tail wheel spring set up
Date: Monday, July 7, 2008, 9:18 PM
[quote]--> Kitfox-List message posted by: steve shinabery <shinco(at)bright.net> Guy Buchanan wrote: > --> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com> > > At 02:14 AM 7/7/2008, you wrote: >> Could this be the wrong set of leaf springs??does the KF2 >> different ,or does all KF springs fit all KFs??may be I have the >> wrong KF springs??I can not fly this way... What can I do?? > > If the angle is the only thing different, (meaning you swapped the > entire tailwheel assembly from one to the other,) that has to be the > reason. The pivot should be nearly vertical, with the top slightly > behind the bottom so the wheel doesn't shimmy. I'm guessing yours has > the top WAY behind the bottom, so the wheel wants to flop sideways. > That would be bad. If your pivot angle looks wrong, have a spring shop > bend it for you to the right angle. > > > Guy Buchanan > San Diego, CA > K-IV/1200 w/ 582 C-box & Warp 3 blade > 100% and flying thanks mostly to Bob Ducar > > > > > > 270.4.6/1538 - Release Date: 7/7/2008 7:40 AM > > > Thanks Guy,,every one has helped me..and these are all good ideas..today I am sending pictures of springs to Kitfox ..what I have..and what needs to be done.. but grounded 4 now in Ohio.I can not keep doing loops all down the way.of the run way.trying to get off the ground..all so looks kind of stupid.. But with all of the kitfox family and John+Deb at kitfox.hope to have her back in the air again..soon....STEVE SHINABERY N554KF KF2 582.. [quote][b]
