Posted: Tue Jul 08, 2008 5:36 pm Post subject: Tool list for the 601HDS |
Hi guys,
I just finished an AOPA article on tools for minor emergencies like a
flat tire, cracked canopy, a dinged wing or prop, belt or electrical
problem. I’d started one, but after reading this article I visited
Harbor Freight, O’Rielly’s and Farm and Fleet. The tools, spares, bag,
and rags weigh in at 10lbs. I spent a little over $50.00 for the tools I
didn’t have, bought lightest and least costly where possible and only
good wrenches and sockets where necessary. I looked over my motorcycle
tool kit for what constitutes /essential /before hand. It was probably
worth the effort if only for peace of mind. Do "yard-sale" the sockets
and wrenches that don't fit anything on the plane.
TOOL KIT FOR THE 601HDS w/Stratus Subaru EA-81
Tire inner-tube replacement w/valve core and core removal tool.
Tire gage – slider type 4-inch
Tube silicone sealant
Spark plug gapping tool
Tube anti-seize
6-inch adjustable wrench
Pliers, long nose, duck bill and wire cutter
Vise grips medium
Hammer, Small (kept in the tie-downs bag)
Screw driver, 4-in-1 combination, flat, Phillips, one right angle
Awl, 6-inch, 0 to 5/16-inch-dia.
Hex wrenches, metric and AS
Torque wrench – 3/8-inch max 200 inch-lbs
Feeler gages - set valves
Small open-end wrenches 8mm-19mm
Open-end wrench set 3/8 - ¾-inch
Socket set ¼-inch with medium sockets 1/4-inch thru 3/4-inch
With 3/8 to ¼-inch socket adapter
Spark plug socket 13/16-inch
Batteries 8 pack AA
Flashlight with 2 AA batteries
Voltmeter with continuity tone
Oil Filter wrench strap type with 10-inch x ¼ in dia. extension w/tee
Fuses, 3-5-7.5-10-15-20 amp
Tie-ties, 8-inch 12-pc
Duct tape, new 100-inch roll
.032 safety wire x 36-inch coiled
Hand cleaner packets (10)
Rags – zip locked bagged shop rags and micro-fiber towels 4-each
3-oz sealed container, 10 washers, cotters 2 bolts, 8 screws, 4 nuts,
24-inches Tefzel 16-ga wire and 2-each common electrical terminals. 1
radiator hose elbow, 1 hose clamp, 1 pump belt.
Nylon Bag with zippers and belted nylon handles, 6 x 6 x 13-inches
Total weight = 10-lbs
Each of you would obviously have only similar requirements, so.........
Anyway, do fly safe guys,
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
