CHT/EGT wire routing
rshannon
PostPosted: Thu Jul 10, 2008 9:18 am    Post subject: CHT/EGT wire routing Reply with quote
How have others have routed and secured their CHT/EGT wires around the
engine? Photos would be especially appreciated. TIA.
Ron
View user's profile Send private message AIM Address Yahoo Messenger
Clive J
PostPosted: Fri Jul 11, 2008 12:24 am    Post subject: CHT/EGT wire routing Reply with quote
EGT/Oil temp pressure are hung off the induction pipes under the
barrels, gives you something to tyrap to that's cold and keeps them away
from the exhaust.
CHT cables are run along top of barrels just under heads, looping over
to the top of each one, whole lot under the cooling ducts.
Regards, Clive
