		Deems Davis
				 Posted: Tue Jul 08, 2008 6:54 pm    Post subject: SLICK MAGs |
				I recently became aware of what appears to be a developing  and
 potentially significant problem. Slick (Unison industries) has issued 2
 service bulletins for their Mags and LASAR ignitions. depending upon
 serial number applicability,  they require recurrent inspections (at)  5
 hours of ops and then at 15-20  hour intervals.  There has been some
 chatter on VAF about  this,  however the problem seems to be bigger
 than  reported, with  several magnetos failing  at relatively short
 time in service durations.  I recently heard of an RV-10 experiencing a
 mag failure (at) 50 hours . With nearly 150 RV-10's flying I'm curious as
 to the extent this problem has been seen in the community.  What are
 people experiencing/hearing?
 Deems Davis # 406
 'Its all done....Its just not put together'
 http://deemsrv10.com/
		Tim Olson
				 Posted: Tue Jul 08, 2008 7:20 pm    Post subject: SLICK MAGs |
				I checked my s/n this weekend (didn't do an internal inspection of
 the mag) and found that mine is before the S/N's listed, so I breathed
 a huge sigh of relief.  But, I just heard of our pal Wayne up in
 Alaska...y'all know him, and he hasn't had THAT many hours on his
 plane, but I guess his mag was one affected and he just had it
 go out up there....sounds like it was just a wreck inside.
 I don't know what the heck Unison did...would be nice to know the
 history, but it sure sounds like if you're in that s/n range, it's
 a disaster waiting to happen....so I'd keep close tabs on it.
 Deems Davis wrote:
  Deems Davis # 406
		sam(at)fr8dog.net Guest
				 Posted: Tue Jul 08, 2008 8:49 pm    Post subject: SLICK MAGs |
				The cap failed on my Bendix mag (at) 50 hours, could be a product wide problem.
 Deems Davis wrote:
  2 service bulletins for their Mags and LASAR ignitions. depending upon
  a mag failure (at) 50 hours . With nearly 150 RV-10's flying I'm curious
  as to the extent this problem has been seen in the community.  What
  are people experiencing/hearing?
  Deems Davis # 406
		ron.mcgann(at)baesystems. Guest
				 Posted: Tue Jul 08, 2008 9:09 pm    Post subject: SLICK MAGs |
				I knew nothing about this SB until Deems' email - thanks for the heads
 up!!
 Since my engine ex Vans was shipped mid last year, I expect that I will
 have two problematic mags that need treatment.  With luck and since they
 have not been used, I may be able to have them replaced under warranty.
 I have never pulled a mag apart before and have little clue about what
 may be involved to perform these inspections.  Can anyone shed any light
 on basic mag maintenance, or provide a pointer to the relevant Slick
 docs (eg L1363)?
 I thought I was almost finished, but with 2 Vans SBs, one on the
 Injector servo and now this, I doubt I will ever get there and wonder
 what I've gotten myself into.
 Ron
 187
		Deems Davis
				 Posted: Tue Jul 08, 2008 9:27 pm    Post subject: SLICK MAGs |
				If I read the SB's correctly (that's a bif IF). the 1st one which
 contains the most restrictive and more frequent inspection cycles has a
 narrower serial number range. The implication is that this issue is
 related to more recent production (say within the last couple of years.
 However, the second SB, essentially broadens the serial number range,
 but makes the inspection cycle somewhat less onerous for the earlier
 produced units. I didn't know of Wayne's incident, but that's the 2n'd
 RV-10 with a mag failure that I've heard of with relatively few hours on
 the mag/s
 Deems
 Tim Olson wrote:
 > upon serial number applicability,  they require recurrent inspections
 > (at)  5 hours of ops and then at 15-20  hour intervals.  There has been
 > some chatter on VAF about  this,  however the problem seems to be
 > bigger than  reported, with  several magnetos failing  at relatively
 > short  time in service durations.  I recently heard of an RV-10
 > experiencing a mag failure (at) 50 hours . With nearly 150 RV-10's
 > flying I'm curious as to the extent this problem has been seen in the
 > community.  What are people experiencing/hearing?
 > Deems Davis # 406
		Deems Davis
				 Posted: Tue Jul 08, 2008 9:34 pm    Post subject: SLICK MAGs |
				I'm hoping the Kelly McMullen ,  John Cox, or Pat Thysen will chime in
 here on this, and shed some A&P insight. Some of the other lists have
 chatter that's pretty critical towards Unison.
 Deems
 Tim Olson wrote:
 > Deems Davis # 406
				 Posted: Tue Jul 08, 2008 9:41 pm    Post subject: SLICK MAGs |
				Ron,
 	Now I feel awful when I goofed you about "almost being done."
 Sorry, you will get there we have no doubts.
 	I asked someone from the RV list to cross post his info on
 inspection of his mags. Worth reading.
 Robin
		dlm46007(at)cox.net Guest
				 Posted: Tue Jul 08, 2008 11:30 pm    Post subject: SLICK MAGs |
				One of the things to note is that the 0409xxxx series seem to be the retard
 breaker mags and the 0408xxxx seem to be the non retard breaker mags.
		Tim Olson
				 Posted: Wed Jul 09, 2008 3:35 am    Post subject: SLICK MAGs |
				Yeah, and lucky me, after seeing your post I went back digging
 for the SB's and saw the 2nd one, which DOES incorporate my
 mag.  The nice thing is, I have over 250 hours, which puts
 me at a less frequent inspection timing.....but it still doesn't
 give me lots of warm fuzzies.  The real big thing that DOES
 give me warm fuzzies is that I have a Lightspeed unit, so even
 if my mag fails, my LSE should be working good....but hopefully
 the mag timing isn't so far off if the mag fails that it
 makes the engine run bad.
 Deems Davis wrote:
  the mag/s
  Deems
 > Tim Olson - RV-10 N104CD - Flying
 > do not archive
 >> Deems Davis # 406
				 Posted: Wed Jul 09, 2008 4:06 am    Post subject: SLICK MAGs |
				I also have a Lightspeed unit on the right, (top) side, and when my mag failed, I experienced no noticeable difference in engine operation. Until the next preflight run!
  Tim Olson wrote: [quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
  Deems Davis wrote:
     	  | Quote: | 	 		  --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net> (deemsdavis(at)cox.net)
  If I read the SB's correctly (that's a bif IF). the 1st one which contains the most restrictive and more frequent inspection cycles has a narrower serial number range. The implication is that this issue is related to more recent production (say within the last couple of years. However, the second SB, essentially broadens the serial number range, but makes the inspection cycle somewhat less onerous for the earlier produced units. I didn't know of Wayne's incident, but that's the 2n'd RV-10 with a mag failure that I've heard of with relatively few hours on the mag/s
  Deems
  Tim Olson wrote:
       	  | Quote: | 	 		  --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
  I recently became aware of what appears to be a developing  and potentially significant problem. Slick (Unison industries) has issued 2 service bulletins for their Mags and LASAR ignitions. depending upon serial number applicability,  they require recurrent inspections (at)  5 hours of ops and then at 15-20  hour intervals.  There has been some chatter on VAF about  this,  however the problem seems to be bigger than  reported, with  several magnetos failing  at relatively short  time in service durations.  I recently heard of an RV-10 experiencing a mag failure (at) 50 hours . With nearly 150 RV-10's flying I'm curious as to the extent this problem has been seen in the community.  What are people experiencing/hearing?
  Deems Davis # 406
		wayne.e(at)grandecom.net Guest
				 Posted: Wed Jul 09, 2008 5:13 am    Post subject: SLICK MAGs |
				Thought I would chime in on the Slick mag issue  since I'm the recipient of one of their failures. On June 21st I left TX  starting on a flying trip up to and through Alaska that ended this last Sunday  July 6th back in TX. When I was in Anchorage getting ready to head  to Ketchican I had my right mag fail. I don't mean run rough it completely  drop off the earth and went to mag heaven. I don't know the technical  term but basically the lobe on the cam in the mag that lifts  the points to allow them to open was completely worn off, they call it the  breaker point cam. I'm sure all of you already know this but it's Lycoming  Service Bulletin 583 & 584 dated June 3rd.
  I have the Lasar system so I had that plus the left  mag remaining so if I had been where there was no repair station I still had  some options left to me. At the time of failure I had about 165 hours on the  engine.
  I was lucky and found a great shop on the  field in Anchorage to work on my problem, Aero Twin. These guys were probably  this best group I've ever worked with. I was flying with 12 other planes that  had to go on without me and the shop was trying their damndest to get me  back in the air so I could catch up with the group. They even worked through  their lunch hour to get me back in the air. Great bunch of guys.
  My first problem was finding a mag, since as all of  you know that electronic ignition isn't widely used and available for general  aviation. So the shop manager was able to talk to Joe at Unison and he over  nighted me a new mag. The mag that he sent me is under their same service  bulletin as the one that was being replace, since they really don't have a know  fix yet, that I'm aware of. So I've just traded a bad problem for a known  problem. Sue at Aero Sport told me that probably all Slick mags from 2004 on  are affected. Isn't this amazing, they've been making these parts forever  and they find someone who will make them for $3 less and we end up with their  mess because of this.
  My second problem came when the shop didn't have  the Lasar timing tool. I called Unison and he didn't have any available to send  me with the mag and I then called Aero Sport Power, Sue, who I had been  communicating with on this, and she had one but they had a Canadian holiday this  next day and couldn't get it to me. I ended up calling my friend Steve Gross who  hangars his RV6 in my hangar, and he overnighted me my timing tool. I thought  this was kind of a funny statement, but maybe not, Joe from Unison said I should  always carry my timing tool with me in the plane. Boy that's confidence don't  you think! Oh well.
  Anyway I was able to get back up and running and  was able to catch up with the group in Ketchican, so I guess the saying is all's  well that ends well. I guess for now :>}
  If any of you have any interest in seeing some of  the Alaskan photos that we took I created a blog for my grandkids where I made a  daily  posting
  triptoalaska2008.blogspot.com
   Actually with the lack of WIFI at one  location and this mag failure I got behind a little but I'm trying to get  it caught back up know. At the very bottom of the blog is a daily  folder of all the photos we took. There is some pretty interesting  country side in Alaska for those of you who haven't been there.
  Wayne Edgerton N602WT
              Time:      07:54:09 PM PST  US            From:      Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>            Subject:      SLICK  MAGs
       Deems Davis #  406
				 Posted: Wed Jul 09, 2008 6:38 am    Post subject: SLICK MAGs |
				By the way I forgot to mention that I lost a mag on  my first flight, so this is the second mag that I've lost. Makes a guy feel warm  and fuzzy huh!
  Wayne edgerton N602WT
		Kelly McMullen
				A Bendix mag is very different than a Slick and generally is very
 reliable. Slick has had its ups and downs. Mainly use of forms of
 plastic that aren't as heat resistant as needed.
 On Tue, Jul 8, 2008 at 9:46 PM, Sam Marlow <sam(at)fr8dog.net> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
		Kelly McMullen
				 Posted: Wed Jul 09, 2008 7:15 am    Post subject: SLICK MAGs |
				Makes one want to specify a Bendix mag or two when buying from one of
 our favorite specialty engine shops, eh?
 On Wed, Jul 9, 2008 at 7:25 AM, Wayne Edgerton <wayne.e(at)grandecom.net> wrote:
  	  | Quote: | 	 		   By the way I forgot to mention that I lost a mag on my first flight, so this
KCHD |
				 Posted: Wed Jul 09, 2008 1:19 pm    Post subject: SLICK MAGs |
				That's what I thought to, until I read this last post, describing how
 the points failed. It described my failure exactly.
 Kelly McMullen wrote:
		GenGrumpy(at)aol.com Guest
				 Posted: Wed Jul 09, 2008 3:22 pm    Post subject: SLICK MAGs |
				Guys:
  As a reminder, the corrected copy of the SB contains the applicable serial  numbers that are affected.
  grumpy
  N184JM
  In a message dated 7/9/2008 6:36:35 A.M. Central Daylight Time,  Tim(at)MyRV10.com writes:
 do not    archive
     the mag/s
  Deems
 > do    not archive
 >> Deems Davis #    406
 Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
				 Posted: Wed Jul 09, 2008 6:06 pm    Post subject: SLICK MAGs |
				[quote]I am the proud owner of two brand spanking new defective SLICK Mag’s that are covered under the SB. Gezzz another thing to worry about on First Flight. RobinDo Not Archive  [b]
				 Posted: Thu Jul 10, 2008 4:05 pm    Post subject: SLICK MAGs |
				 	  | Quote: | 	 		  | I emailed BPE this morning regarding the joy of having TWO brand spanking new mags that fall under the SB. Rhonda did a little research and found a solution that gets around the SB / future inspections. She OK’d me to post this to the list:  |
 Here is the pricing from the local accessory shop in Tulsa, Quality Aircraft Accessories.  Replace the carbon brush and cam, including labor for any Slick mag at or around 100 hours for $75/mag.  This would be Aero-Accessory replacement parts, so they would not be affected by the SB after the repair.
    [quote]Justin Hicks at Quality can be reached directly at (918) 835-6948 for assistance.   I am not sure what it takes to do this yourself. The SB makes the replacement seem pretty simple.  Robin[b]
				 Posted: Thu Jul 10, 2008 4:27 pm    Post subject: SLICK MAGs |
				I expect any new engine or rebuilt engine with  new mags will be affected by the SB.  I bought my engine from Vans mid '07  and I too have dud mags.  I contacted Unison to see if I could have them  replaced under warranty - mine are brand new never run.  The simple issue  is that they have NO solution and have nothing better to replace them  with.  Given our deeeep south location, there are not many options with  alternate brush/cam suppliers, so I have no choice other than inspections every  15-20 hrs until 50hrs per the SB.  I just hope the mags are not difficult  to remove - I am having nightmares about dropping a support bracket or nut into  the engine accessory case already.
  cheers,
  Ron
  -187, Tailcone SB done, back to  finishing.
  [quote]         From: owner-rv10-list-server(at)matronics.com    [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin    Marks
 Sent: Friday, 11 July 2008 9:32 AM
 To:    rv10-list(at)matronics.com
 Subject: SLICK    MAGs
   	  | Quote: | 	 		  Justin Hicks at Quality can be reached directly at (918) 835-6948 for assistance.   I am not sure what it takes to do this yourself. The SB makes the replacement seem pretty simple.  Robin
 p://www.matronics.com/Navigator?RV10-List
 ics.com
 .matronics.com/contribution
  | 	  "Warning:
 The information contained in this email and any attached files is
 confidential to BAE Systems Australia. If you are not the intended
 recipient, any use, disclosure or copying of this email or any
 attachments is expressly prohibited.  If you have received this email
 in error, please notify us immediately. VIRUS: Every care has been
 taken to ensure this email and its attachments are virus free,
 however, any loss or damage incurred in using this email is not the
 sender's responsibility.  It is your responsibility to ensure virus
 checks are completed before installing any data sent in this email to
 your computer."
		wcurtis(at)nerv10.com Guest
				 Posted: Fri Jul 11, 2008 7:11 am    Post subject: SLICK MAGs |
				Just Checked my TMX IO-540 delivered in '07 and it looks like my engine is good.  My serial number is 0604 1519, model 6351 rev C.  The affected range is 0610xxxx thru 0804xxxx.
 William
 http://nerv10.com/wcurtis/
