jlsk1(at)frontiernet.net Guest
Posted: Sat Jul 19, 2008 5:06 am Post subject: Painting Lexan |
Hi all, A few of you have painted Borders around your Window & Door frames, My question is what Kind of paint works well on the Lexan we have on our Kolbs?? Thanks, Jim Kmet
Cookeville, TN
MK-3C
Steven Green
Posted: Sun Jul 20, 2008 9:19 am Post subject: Painting Lexan |
Jim,
I have not painted any lexan on my plane but the bodies on most RC cars are lexan and they paint them. I do not know if the paint is anything special or not. Got any scraps to test on?
Steven
_________________ Steven Green |
Posted: Sun Jul 20, 2008 9:39 am Post subject: Painting Lexan |
Steven Green wrote:
[quote] Jim,
Steven
tkrolfe(at)toast.net Guest
Posted: Sun Jul 20, 2008 10:20 am Post subject: Painting Lexan |
Jim Kmet wrote:
| Quote: | Hi all, A few of you have painted Borders around your Window & Door
Cookeville, TN
MK-3C
Jim,
I painted my gap seal which is made out of Lexan with the same Poly-Tone
paint I used on the FireFly. Sticks real good, in fact you don't want
to change your mind later and try to remove it!!
Terry - FireFly #95
bartmo(at)sbcglobal.net Guest
Posted: Sun Jul 20, 2008 1:18 pm Post subject: Painting Lexan |
I painted the top part of the canopy on a Dragonfly MK II with the same paint as the plane. Just tape it off and rough up the lexan with sandpaper so the paint will have better grip.
Bart Morgan
Firestar II [in progress]
Charlie England <ceengland(at)bellsouth.net> wrote:
[quote]--> Kolb-List message posted by: Charlie England
Steven Green wrote:
[quote] Jim,
I have not painted any lexan on my plane but the bodies on most RC cars are lexan and they paint them. I do not know if the paint is anything special or not. [quote][b]
customersupport(at)tnkolb Guest
Posted: Tue Jul 22, 2008 10:57 am Post subject: Painting Lexan |
JIM, WE USE A SINGLE STAGE WITH A LITTLE FLEX , YOU CAN GET THIS MIXED IN A SPRAY CAN IF YOU LIKE. THANKS DONNIE.
by0ung(at)brigham.net Guest
Posted: Tue Jul 22, 2008 6:58 pm Post subject: Painting Lexan |
I painted with poly tone and after 5 or 6 years I am seeing some minor cracking in the lexan. The poly tone seems to melt into the plastic so no scuffing is necessary.
Boyd
| Quote: | >>>>>>>>>>>>
Cookeville, TN
MK-3C
