jan(at)claver.demon.co.uk Guest
Posted: Tue Jul 22, 2008 1:21 pm Post subject: RV-List: Andair Corrosion |
Hi,
That looks bad .. Have you been in contact with Andair about it …??
Jan
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: 21 July 2008 22:34
To: 'Lancair Mailing List'; rv10-list(at)matronics.com; rv-list(at)matronics.com
Subject: RV-List: Andair Corrosion
Here's a picture of an Andair GAS500 fuel bowl showing the nice little nozzle created by corrosion all the way through the bowl. The pilot was complaining of fuel smell. The plane is a Legacy that started flying in 2003. It has about 500 hours.
Before the corrosion got all the way through, the inside of the bowl had a small, shiny, unanodized patch where the corrosion started. The outside looks perfect except for a small black speck where the hole comes through.
Check carefully!
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
sam(at)fr8dog.net Guest
Posted: Tue Jul 22, 2008 3:23 pm Post subject: RV-List: Andair Corrosion |
I've seen this many times on certified aircraft, it source is water in
the fuel.
jan wrote:
Hi,
Jan
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Dave Saylor
*Sent:* 21 July 2008 22:34
*To:* 'Lancair Mailing List'; rv10-list(at)matronics.com;
*Subject:* RV-List: Andair Corrosion
comes through.
Check carefully!
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
