Arksey(at)aol.com Guest
Posted: Wed Jul 09, 2008 8:22 am Post subject: static thrust question |
hi group.
have any of you run a static thrust test on a 503 rotax and if so what were the results? thanks in advance. Jim Swan
firestar ll N-663S 503 rotax michigan
Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
rowedenny
Posted: Wed Jul 09, 2008 6:40 pm Post subject: static thrust question |
Rotax 503 SI-SC on my Loehle Sport Parasol, 2.47 reduction, 66 dia by 40 pitch Tennesee wood prop. Static thrust checked with a strain gauge hooked up to an industrial electronic scale head that was properly calibrated with test weights.
262 pounds of thrust.
Denny Rowe, Mk-3, PA
gliderx5
Posted: Tue Jul 15, 2008 6:36 pm Post subject: static thrust question |
gliderx5
Posted: Tue Jul 15, 2008 6:56 pm Post subject: static thrust question |
gliderx5
Posted: Fri Jul 18, 2008 7:05 am Post subject: static thrust question |
