Night VFR and Fuse/Breaker Accessibility
jeffrey_davidson(at)earth
PostPosted: Thu Jul 17, 2008 8:36 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
I have built my Zenair 601 with the fuse block on the cabin side of the firewall. It is not accessible to the pilot in flight. I don't plan to try to debug electrical problems in the air. I do, however, want to be able to fly my craft at night in VFR conditions. I have read most of the posts on this subject in the archives. All told, the crucial question seems to be "What fuses/breakers control a circuit that is critical to night flight?" I have gone down the list instruments and avionics in my plane and found that either I have provided a backup power supply (battery) outside of the ship's power or that I can fly without the item in question. I understand flight can continue with inoperative navigation lights. (Actually, what other option is there? Stop right there?) The transponder is the only item that doesn't have some sort of backup, and I can't find any applicable requirement for it as far as night operating limitations are concerned.
Here is my question: Has anyone been successful in getting their OBAM given Night VFR operating priviledges by an FAA Inspector without any fuses/breakers being accessible in flight? This refers to 91.205. Locally, I have gotten answers on both sides of this issue from those that should know.
Jeff Davidson
BobsV35B(at)aol.com
PostPosted: Thu Jul 17, 2008 8:49 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Good Morning Jeff,
No expert here, but this is my take!
There is no requirement for any sort of an approval for you to fly night, or for that matter, IFR.
Your operating limitation should say something to the effect that the airplane is supposed to be operated in day VFR unless it meets the appropriate requirements of 91.205. It is up to you, the operator, to make that determination. No other action is required.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 7/17/2008 11:37:44 A.M. Central Daylight Time, jeffrey_davidson(at)earthlink.net writes:
Jeff Davidson
Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
frank.hinde(at)hp.com
PostPosted: Thu Jul 17, 2008 9:01 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Sure...Not only Night VFR but IFR as well...Actually all this is a bit of a misnomer because its you the builder that determines whether the airplane is equipped for Night VFR or IFR.
The DAR/FSDO is only approving for issueing a DAY VFR airworthiness certificate...I.e for phase 1..After that its up to you to equip as necessary.
Either way none of my fuses are accessible in flight
Frank
601 HDS 400 hours
Rv 7a 300
dennis.glaeser(at)eds.com
PostPosted: Thu Jul 17, 2008 11:12 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Interestingly, the wording of FAR 91.205 says that spare fuses must be
accessible to the pilot in flight, but never states that the fuses must
be replicable in flight! I guess the reg writers just assumed that if
you have fuses, there would be access to them in flight Smile
My fuseblocks are not accessible in flight. The DAR asked if I had
spare fuses, and I showed him a zip-lock bag of spares I keep in the
pouch on the back of the pilot seat. That was fine with him (and he was
observed by an FAA Inspector for my inspection).
Dennis Glaeser
RV7A
firewall.
debug
my craft
subject
fuses/breakers
the
provided
can fly
inoperative
there?)
operating
given Night
being
answers
Jeff Davidson
gyoung
PostPosted: Thu Jul 17, 2008 11:38 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
The standard Op Limitations wording has approval for day VFR and night or
IFR when equipped. If your concern is the FAR wording about replacement
fuses, read it carefully. It says, IF the fuses are accessible in flight,
then you need to carry spares. It does not say that the fuses MUST be
accessible in flight, only that if they are you need to carry spares.
Greg Young
[quote] --
mprather(at)spro.net
PostPosted: Thu Jul 17, 2008 12:39 pm    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
While experimentals generally don't have to comply with the normal
certification standards, I think it's useful to read what the normal
standards say. Here's FAR 23.1357:
Sec. 23.1357 Circuit protective devices.
(a) Protective devices, such as fuses or circuit breakers, must be
installed in all electrical circuits other than--
(1) Main circuits of starter motors used during starting only; and
(2) Circuits in which no hazard is presented by their omission.
(b) A protective device for a circuit essential to flight safety may not
be used to protect any other circuit.
(c) Each resettable circuit protective device ("trip free" device in which
the tripping mechanism cannot be overridden by the operating control) must
be designed so that--
(1) A manual operation is required to restore service after tripping; and
(2) If an overload or circuit fault exists, the device will open the
circuit regardless of the position of the operating control.
(d) If the ability to reset a circuit breaker or replace a fuse is
essential to safety in flight, that circuit breaker or fuse must be so
located and identified that it can be readily reset or replaced in flight.
(e) For fuses identified as replaceable in flight--
(1) There must be one spare of each rating or 50 percent spare fuses of
each rating, whichever is greater; and
(2) The spare fuse(s) must be readily accessible to any required pilot.
Item (d) seems most interesting to me. Only if the ability to
reset/replace the protection is required for safety of flight must the
protection be located to be easily accessible while in flight. All other
circuit protection can be located at the convenience of the designer.
Further, if a fault tolerant design is adopted, the failure of no single
item should put the outcome of the flight in jeopardy. That says that no
breakers or fuses need be accessible while in flight. A nice side benefit
of fault tolerant designs. Lots of airplanes have been built this way..
As far as paragraph (c) item (6) (from 91.205 that you mentioned):
"(6) One spare set of fuses, or three spare fuses of each kind required,
that are accessible to the pilot in flight."
I take the important part of that to be "fuses of each kind required".
Since no circuit protection need be accessible according to our good and
proven design, no spare fuses are "required" to be accessible by the
pilot...
Matt-
<dennis.glaeser(at)eds.com>
Dennis Glaeser
RV7A
firewall.
debug
my craft
subject
fuses/breakers
the
provided
can fly
inoperative
there?)
operating
given Night
being
answers
Jeff Davidson
BobsV35B(at)aol.com
PostPosted: Thu Jul 17, 2008 4:21 pm    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Good Evening Dennis,
Jut as a point of interest, the later Bonanzas have a whole passel of fuses on the forward side of the firewall, They are quite obviously not replaceable in flight!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 7/17/2008 2:14:40 P.M. Central Daylight Time, dennis.glaeser(at)eds.com writes:
Dennis Glaeser
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
PostPosted: Fri Jul 18, 2008 12:36 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Thank you everyone for the replies. My fuse block will stay where it is.
If the Inspector/DAR takes a contrary opinion, I'll just have to ask him to
educate me as Bob suggests in an old post.
Jeff Davidson
bakerocb
PostPosted: Fri Jul 18, 2008 3:11 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
7/18/2008
Hello Jeff, You wrote: "Has anyone been successful in getting their OBAM
given Night
being
accessible in flight?"
A) It is true that FAR Secs 23.1357 (d) and (e) read as follows:
"(d) If the ability to reset a circuit breaker or replace a fuse is
(1) There must be one spare of each rating or 50 percent spare fuses of each
(2) The spare fuse(s) must be readily accessible to any required pilot."
B) But you are not building an airplane that must comply with Part 23, you
are building an amateur built experimental airplane that instead needs only
to comply with certain parts of FAR Part 91 under certain circumstances.
C) The paragraph in FAR Sec 91.205 that applies to this issue reads as
follows:
Since you also wrote:
"I have built my Zenair 601 with the fuse block on the cabin side of the
firewall. It is not accessible to the pilot in flight."
Therefore from a regulatory viewpoint there is no need to be concerned
about:
Or your access to those specific fuses while in flight.
Since your airplane will be in compliance with applicable regulations the
inspector should not have this subject as an issue unless he has a personal
fetish in this regard.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PS: Also note that the inspector does not: "...... give(n) Night VFR
operating priviledges......" Instead he issues you a set of Operating
Limitations for your specific airplane which contain this statement:
"After completion of Phase I flight testing, unless appropriately equipped
for night and/or instrument flight in accordance with 91.205, this aircraft
is to be operated under VFR, day only."
This places the burden upon you to have your aircraft properly equipped for
night and/or instrument flight after completion of Phase I flight testing,
not on the inspector at the time of initial airworthiness inspection.
Time: 09:36:03 AM PST US
From: Jeff Davidson <jeffrey_davidson(at)earthlink.net>
Subject: Fw: Night VFR and Fuse/Breaker Accessibility
firewall.
craft
fuses/breakers
provided
fly
inoperative
there?)
Night
being
answers
Jeff Davidson
longg(at)pjm.com
PostPosted: Fri Jul 18, 2008 5:36 am    Post subject: Night VFR and Fuse/Breaker Accessibility Reply with quote
Folks,
Let's be mindful of the size of text that is continually appended to the
news list. With your thoughts exploding it's easy to forget all of what
you write and send including previous comments are duplicated on the
server. We don't want to choke that bugger.
Strip the previous person's comments from these emails (your thoughts
are not lost) before sending. If you don't care to preserve your
comments, do not archive will drop them from record.
